how do I find out what chipset I have?
I am still having severe problems with my mbox. I can only think that it must be an incompatible chipset. The intel chipset identifier program does not seem to work on my computer. Any other way of finding out what chip set it is?
If it is an in compatable chip set, is there any chance of it becoming compatable or do I have to get cubase et al to get my mbox running? All I know is that it is a pentium 4 and is 3.06 ghz. The computer is a Dell inspiron 5150 that I bought in January 2004. Thanks
cheers spong |
Re: how do I find out what chipset I have?
I tried it, but the results flash accross the screen in DOS and disappear. Anyway of slowing this down so I can read it?
thanks
cheers spong |
Odd that. Mine doesn't disappear. Mind you, I now remember other DOS windows closing - XP doesn't like them. Try the 'pause' button.
Or restart in DOS and run it from there? Put it on a floppy first so you can find it. Also, correct me if I'm wrong someone, but when you start up the PC the relevant info is briefly at the bottom of your screen. You have to hit 'pause' quickly to be able to read it. |
download CPU-Z to determine basic information about your system without having to install any software.
unzip the file and double click cpuz.exe which has the cpu-like icon. once it appears, click the mainboard tab and your chipset will be revealed! if you require more detailed analysis, download sisoft sandra lite. |
Rather cool. But...
It tells me how much memory I have, but not the type. F this! Take the case off and have a look! |
FatBelly Slim Oh no, not the sprinklers again. |
"Chipset: unspecified"
Intel G33 Chipset & Doogz & Can't Find His Post & Pro Tools | Willosy | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 7 | 11-30-2007 07:15 PM |
How to Find Out What Chipset you have?? | Noxious | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 08-19-2005 10:26 AM |
915P chipset versus the 915PM chipset | valleyarts | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 03-28-2005 02:22 AM |
875P chipset or 865PE chipset | Josh K | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 10-27-2003 06:21 PM |
find firewire drive with oxford chipset | earprint | Pro Tools TDM Systems (Mac) | 2 | 08-21-2001 03:24 AM |
