Old 11-02-2015, 10:34 AM
ColinSound ColinSound is offline
Default "Selected ASIO Device could not be Initialized" After Reinstalling PT10 on Same Machi
So I used to have ProTools 10.3.10 installed on my computer, and it all seemed to work fine. A year or two ago I had to uninstall it, and now I am installing it back into this machine. However, now I am faced with ""Selected ASIO Device could not be Initialized.", with no options to select a device - so all it can do is quit. No upgrades were done to the computer, speakers are the same, all Windows & Speaker drivers are up to date. I have looked at about ten different threads about the issue and they did not seem to help. I have uninstalled & reinstalled PT10 again, and haven't had any similar issues running Nuendo with it. I also do not nor have ever used any sort of Fireface/MBox etc interfaces with this computer. (PS - running DxDiag also comes up with "Error:Problem getting extra sound info".
Any help is much appreciated. SandraReport below:
SiSoftware Sandra
ID
Host Name : C************
Workgroup : WORKGROUP
Computer
Model : OEM System Product Name
Serial Number : System Ser**********
Chassis : Desktop
Mainboard : ASUS P8Z68-V LE
Serial Number : MT7018K********
BIOS : AMI (OEM) 0504 07/12/2011
Total Memory : 8GB DIMM DDR3
Processors
Processor : Intel(R) Core(TM) i5-2500 CPU @ 3.30GHz (4C 3.51GHz/3.7GHz, 3.5GHz IMC, 4x 256kB L2, 6MB L3)
Socket/Slot : FC LGA1155
Chipset
Memory Controller : ASUS Core (Sandy Bridge) DRAM Controller 100MHz, 8GB DIMM DDR3 1.33GHz 64-bit
Memory Module(s)
Memory Module : Corsair CMZ8GX3M2A1600C9 4GB DIMM DDR3 PC3-12800U DDR3-1600 (9-9-9-24 5-34-10-5)
Video System
Monitor/Panel : ACI ASUS VS228
(1920x1080, 21.7")
Monitor/Panel : ProView MEDION 22-inch BP2219AFW (1680x1050, 22.0")
Video Adapter : AMD Radeon HD 6900 Series (24CU 1536SP SM5.0 880MHz, 2GB DDR5 5.5GHz 256-bit, PCIe 2.00 x16)
Graphics Processor
OpenCL GP Processor : AMD Radeon HD 6900 Series (1536SP 24C 880MHz, 2GB DDR5 5.5GHz 256-bit)
Compute Shader Processor : AMD Radeon HD 6900 Series (1536SP 24C 880MHz, 2GB DDR5 5.5GHz 256-bit)
OpenGL Processor : AMD Radeon HD 6900 Series (1536SP 24C 880MHz, 2GB DDR5 5.5GHz 256-bit)
Storage Devices
WDC WD5000AAKX-003CA0 (500.1GB, SATA300/600, 3.5", 7200rpm, 16MB Cache) : 466GB (E:)
OCZ-VERTEX3 (120GB, SATA600, SSD) : 112GB (C:)
ATAPI iHES112 3 (7.4GB, SATA150, BD-R, DVD+-RW, CD-RW, 2MB Cache) : 7GB (D:)
Logical Storage Devices
Side Drive (E:) : 466GB (NTFS, 4kB) @ WDC WD5000AAKX-003CA0 (500.1GB, SATA300/600, 3.5", 7200rpm, 16MB Cache)
Colin Main (C:) : 112GB (NTFS, 4kB) @ OCZ-VERTEX3 (120GB, SATA600, SSD)
U13002W_001_D01 (D:) : 7GB (UDF, 2kB, Read-Only) @ ATAPI iHES112 3 (7.4GB, SATA150, BD-R, DVD+-RW, CD-RW, 2MB Cache)
Peripherals
LPC Hub Controller 1 : ASUS Cougar Point LPC Controller
Audio Device : ASUS Cougar Point High Definition Audio Controller
Audio Codec : Realtek Semi High Definition Audio
Audio Device : PC Partner Cayman/Antilles HDMI Audio [Radeon HD 6900 Series]
Audio Codec : ATI (AMD) HDMI Audio
Serial Port(s) : 1
Disk Controller : ASUS Cougar Point 6 port SATA AHCI Controller
USB Controller 1 : ASUS Cougar Point USB Enhanced Host Controller #2
USB Controller 2 : ASUS Cougar Point USB Enhanced Host Controller #1
USB Controller 3 : ASUS ASMedia XHCI Controller
USB Controller 4 : ASUS ASMedia XHCI Controller
CardBus/PCMCIA Controller 1 : 53244 CB-1410 CardBus Controller
SMBus/i2c Controller 1 : Intel ICH SMBus
Printers and Faxes
Printer : Send To Microsoft OneNote 2010 Driver (1200x1200, Colour)
Printer : Microsoft XPS Document Writer (600x600, Colour)
Printer : HP Deskjet 3050A J611 series (600x300, Colour)
Printer : HP Deskjet 3050A J611 series (600x300, USB, Colour)
Scanners and Cameras
Scanner : Hewlett-Packard HP Deskjet 3050A J611 series (NET) (Scanner, USB)
Network Services
Network Adapter : Realtek PCIe GBE Family Controller (Ethernet, 1Gbps)
Operating System
Windows System : Microsoft Windows 7 Home Media Center 6.01.7601 Service Pack 1
Platform Compliance : x64
Old 11-04-2015, 07:25 AM
DigiTechSupt's Avatar
Default Re: "Selected ASIO Device could not be Initialized" After Reinstalling PT10 on Same M
Hello ColinSound,
Do you remember if you installed ASIO4ALL before? Check this FAQ it might help.
Good luck,
RC
Avid Audio Tech Support
Support FAQ
Old 11-05-2015, 09:03 AM
YUP. That was it. Thanks
Old 11-06-2015, 05:07 AM
I'm glad I could help.
Good luck,
RC
Support FAQ
"Selected ASIO audio device could not be initialized" Protools 10/11 Die2siN Windows 3 09-22-2014 02:32 PM
"The Selected ASIO audio device could not be initialized." jakevegas79 Windows 15 05-27-2014 02:13 PM
"The selected ASIO audio device could not be initialized..." error PResin Windows 12 06-07-2013 02:49 AM
Selected ASIO Device could not be Initialized. (PT10, 003) knorbert6 Windows 20 06-30-2012 09:25 AM
can't open 9.0.3 "selected ASIO audio device could not be initialized" Timbo18 Windows 2 07-28-2011 08:51 AM
