Hey Guys,
I've seen some info on here about the "Search in selected areas" being buggy, but I'm wondering if anyone has found a workaround? It seems like no matter what directory I choose for PT to search in, it always looks in the same folder. For example, if I tell PT to search in folder A and expand matches, then switch to searching in folder B, it still expands matches from folder A (which don't exist in folder B). It also seems to not like that my guide track references a 24 bit file, but the files I'm conforming are 32 bit float. Anyone had any luck conforming files at different bit depths? From what I understand, the Field Recorder function should only look at timecode (and other match criteria) for conforming, while ignoring things like bit depth. Can anyone confirm? |
There's one main flaw in the "areas to search" routine. You can not stop PT from matching also what's already in your session.
It has been a long time feature request to give us a "only search areas to search" or a "ignore clip list" feature to keep PT from matching again what's already in your session. This causes a lot of work when expanding AVID AAF to their original BWAVs too. Might be the reason for what you are seeing. Frank.
PTHDn 2021.12 (OSX10.14.6), 8x8x8, MacPro 5,1 3.33Ghz 12-Core, BM DeckLink SDI, SYNC HD, all genlocked via AJA GEN10, 48GB RAM, Xilica Neutrino, Meyersound Acheron |
We have abandoned PT11 for field recorder functions for this reason. PT10 works and that's what we use for conforming
Field recorder guide track "select areas to search" doesn´t work | kwassen | Post - Surround - Video | 6 | 04-12-2017 11:53 PM |
BRAND NEWBIE HERE: 1st error message - couldn't locate info in a "search" | csrMark | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 18 | 02-16-2010 02:41 PM |
"conforming" quicktime movies | Dan Pinder | Post - Surround - Video | 9 | 03-11-2003 04:36 PM |
Export selected as"Aiff" interleave doesn't works on Avid NT | maxserg | Pro Tools TDM Systems (Mac) | 2 | 01-31-2003 06:36 PM |
I can't "Back" to Search results, after reading a message?? | el biciclista | General Discussion | 0 | 06-15-2001 04:57 PM |
