Old 01-31-2006, 11:40 PM
Keith Moore Keith Moore is offline
Default Drumagog V4...
Hey I'm using the Drumagog V4 demo right now and it seems pretty cool. I was wondering if anyone out there has had any luck with the midi output. I'm looking to have it trigger reason and I can't seem to figure it out. I'm ready to buy it tomorrow if this feature will work.
Thanx in advance,
Keith Moore
Pro Tools HDX 2021.6.0
Lynx Aurora 16
Ross Martin PCM4222
Ross Martin Super Beast
Apple Mac Pro 8 Core 2.66Ghz 16GB RAM
OSX 10.14.6
http://www.keith-moore.org
Old 02-01-2006, 12:00 AM
Steve MacMillan Steve MacMillan is offline
Default Re: Drumagog V4...
Nice plug-in, but the midi out never worked for me.
STeve
macmandigital.com
Old 02-01-2006, 12:28 AM
crizdee's Avatar
crizdee crizdee is offline
The midi isn't implemented yet in the Mac version! it should be coming in the future!
Chris
Producer, Engineer,
www.ukmastering.com
Old 02-01-2006, 12:42 AM
Howardk Howardk is offline
I bought it as well and the features are very in depth. I would really like to see the midi out happening, so I can use other libraries etc. . .. . . not sure what the hold up is on Mac.
...for system configuration info see my profile
(Click on member name)
Old 02-01-2006, 04:41 AM
brianjanthony's Avatar
brianjanthony brianjanthony is offline
has anyone got the MIDI in working? I've never been able to trigger it from my Midi keyboard, etc. I know midi out isn't happening yet, but i thought midi in was supported.
brian
Brian
www.brianjanthony.com
MacPro 6 core 3.46 Cheese Grater
HDX and HD NATIVE
48 gig Ram
PT 2019. Something
Sierra
192 IO and 96 IO
TDM user way back. PT user since 98.
Old 02-01-2006, 04:45 AM
thin ice thin ice is offline
Saw this on the Drumagog forum:
"MIDI is supported for all hosts / platforms now. But most hosts don't have direct support for MIDI out from a plugin, so if you're trying to route MIDI from Drumagog to another plugin or instrument, you need to set Drumagog's MIDI out to either a loopback (or IAC on the Mac), or your physical interface, with a midi cable connecting IN to OUT.
Note: IAC is only available on Mac OSX 10.3 and above... If you're using a PC, a good loopback program to use is Midi Yoke (www.midiox.com)."
Mac Mini M1 16 GB
OS 12.4
PT 2021.12.0
Old 02-01-2006, 05:43 AM
Yeah, I saw that. Somehow I still cannot get it to work right. Probably just something I am misconfiguring. I have a midi track out to IAC bus. Drumagog in as IAC bus. Still not working. Again, I have to really check my settings.
brian
Brian
HDX and HD NATIVE
48 gig Ram
PT 2019. Something
Sierra
192 IO and 96 IO
Old 02-01-2006, 06:09 AM
I got the midi to work on home setup of M Box on a PC. The midi output still seemed a bit hit and miss sometimes. That was with the help of Midi Yoke. However, I have not tried with the Mac studio setup. I have been using APTrigga and soundreplacer while waiting for the Drumagog midi. Also want to see what happens to Drum Rehab now it might come out. Hoping for midi on that!
Mac Mini M1 16 GB
OS 12.4
PT 2021.12.0
Old 02-01-2006, 07:45 AM
Do you have APTrigga working within ProTools? I thought that was AU only.
STeve
macmandigital.com
Old 02-01-2006, 08:55 AM
I have it working on the vst to rtas wrapper. APTrigga is very simple, cheap and accurate. It's just the features are more limited than Drumagog and no hope of midi. Make sure you get an up to date wrapper though or it won't work.
Mac Mini M1 16 GB
OS 12.4
PT 2021.12.0
Drumagog 56BelAir The Drum Room 3 01-21-2010 11:50 AM
Drumagog and PT8 mozart Pro Tools TDM Systems (Mac) 6 12-29-2008 03:44 PM
Drumagog to midi or drumagog to BFD options? crizdee Pro Tools TDM Systems (Mac) 36 11-04-2008 02:16 PM
Drumagog? michael c Pro Tools TDM Systems (Mac) 4 01-26-2007 03:37 AM
Drumagog rock15478 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 8 12-24-2005 12:03 AM
