What the hell is wrong here??!!!
Specs: MBox, current firmware PT LE 6.4/Corre Audio 6.5.1 G4 Dual 1GHz, 1.5 GHz RAM 1-80GB main drive (where PT and the OS is sitting), 1-40GB, secondary drive All the audio is going through a mixer into the MBox, I usually record one track at a time. I decided to upgrade to an MBox from an AMII/Toolbox and I might be regretting it unless someone can help. I searched the board for everything pertaining to an MBox problem, tried it all, and nothing works. The blast of white noise. Out of nowhere, a searing blast of white noise. I figured out how to stop it by going into the playback engine and changing the CPU usage to another setting and this clears it up...for about 3 more minutes. It does it in PT, it does it in iTunes.....constantly. This is completely unacceptable. If I try to save a file to my main drive, I get this error: Could not save as "file name" because: NeoAccess Error... This worked fine with the AMII and I have no problems saving to the secondary drive. One of the troubleshooting threads said I should unplug any USB hardware that I have. I haven't done this yet because what I have on USB is a Bass POD XT Pro, a MOTU Exress XT MIDI interface, the mouse and a ShuttlePro. There's no way I should have to remove THINGS I"LL BE USING WITH THE APPLICATION!!! Pissed off? Yes I am. I needed to upgrade to either an MBox or a 002R because I need to keep the system upgraded. I work from home occasionally and I need to keep current and this includes PT. Everything was fine and dandy with the AMIII. Any ideas? Core audio driver? Bad MBox? Anything? |
Anyone?
I just tried it with Core Audio 6.4 to see if that was it. Nope. Same thing. Works for a few minutes then bursts into the white noise problem and only goes away if I change the playback engine percentage so it's not coreaudio 6.5.1.
Do I have a defective MBox or what's the trick? ProTools is completely unusable at this point (unless I want to get used to working at three minute intervals with the sound almost completely off to prevent my ears from being blown out). Can anyone help? |
MBox Pro, PT 10 New User - Problems | BDJ1229 | FireWire & USB Audio Interfaces (Mac) | 0 | 07-14-2013 03:24 PM |
Please Help!! AMIII problems | swpowe | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 01-18-2006 08:19 AM |
New Mbox User having Problems | Vay | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 01-18-2005 05:37 AM |
NEW MBOX LE USER HAVING PROBLEMS | NeXuS LE | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 07-07-2004 08:19 AM |
problems with AMIII | ustrata | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 01-16-2003 05:06 PM |
