Old 04-12-2006, 11:54 AM
kickit kickit is offline
Default Digi Stand Alone Driver Flakey?
Any one know how to get the stand alone driver to work all the time. Sometimes it works, sometimes it does not. If I use Protools then it does not after I close PT7.0 .
2.7 Dual G5
10.4.5
Old 04-13-2006, 08:27 AM
DigiTechSupt's Avatar
Default Re: Digi Stand Alone Driver Flakey?
Are you making sure to launch the Core Audio Manager first and make sure it shows 'Connected' before launching whichever core audio application you want to use?
If not, try it and most likely your problems will go away.
Also make sure to give Pro Tools sufficient time after quitting to 'release' the hardware for core audio use. If you launch CAM too quickly after quitting Pro Tools, it may not be able to grab the hardware properly.
Avid Audio Tech Support
Support FAQ
Old 04-13-2006, 09:34 AM
audiodepar audiodepar is offline
Check out my Digidesign Core Audio Bug post from this week. It may help.
-Brad
Old 04-13-2006, 12:59 PM
Ed Kish Ed Kish is offline
ok- here is what it does for me... If the sample rate of the LAST session I worked on in PT is above 48k... no audio will play from the stand alone driver.
I have to then reopen PT with a 44.1 session, close and then the stand alone driver will work..
G5 dual 2.7 Tiger
PT 7.1
www.roguewaverecording.com
Dual 2.7Ghz PPC G5/2.5 Ram/OSX.4.9
PT 7.3.1 cs3/HD Core/Accel/Process
Old 04-21-2006, 10:52 AM
Thanks to you all. I have tried those things & still get crap. Like now I'm getting only the left side.
Old 04-21-2006, 11:19 AM
bassntreble bassntreble is offline
trash your digicoreaudiomanager prefs in your user preferences folder... this worked for me.
G5 1.8X2/3gigRAM/Mbox/7.4 (retired)
MBP C2D 2.4/4GigRAM/Mbox/8.0.1
iMac i7 3.4/16GigRAM/10.0.1
11.1.1 Stand Alone Driver Fixed x9blade Pro Tools 11 0 01-07-2014 01:28 PM
003 stand alone driver question kckel FireWire & USB Audio Interfaces (Mac) 3 05-18-2013 06:27 AM
CoreAudio Driver stand alone 8.0.3 mshires Post - Surround - Video 1 11-02-2010 04:03 PM
Mbox Stand alone driver problem PRS-1 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 01-14-2010 06:53 PM
Stand-alone driver for Intel Mac? ranren 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 06-22-2006 10:27 AM
