Commit Tracks and HEAT
Hey guys,
Does Commit Tracks include HEAT in the process? Or not? |
Re: Commit Tracks and HEAT
I just tried a null test, it appears that it does not! Good to know.
My recollection is commit does include HEAT in pre only.
I'm using it in post, and it doesn't either.
From the manual. Only in Pre does HEAT commit.
What Gets Committed Committing a track always renders the following: • Clip Gain • All Inserts (or Commit to Insert) • HEAT, if Pre-Insert (Pro Tools HD only) • Elastic Audio The following source track data is always copied to the new track when committed: • Timebase • Elastic Audio Algorithm • Solo Safe • Track Input assignment (unless the channel width changes) • Track Output assignment • HEAT settings (Pro Tools HD only) |
I didn't realize there was a 'pre' & 'post' setting. Does anyone know if it makes a diff in overall sound? Reading thru manual indicates that it 'defaults' to pre setting. But in looking at my system, audio tracks seem to default to post. Which is probably better for the way I work, since I like to put any native plugins first before DSP. Apparently using native plugs in 1st slot uses extra voices when Heat is set to 'pre'. Maybe I need to send Dave a note to help explain all this…..
Awesome, thanks for the info dude! |
I always use pre HEAT
Pre HEAT makes sure the oven is hot enough to bake. Mmmmmmmm cookies!
From your username I thought you were going someplace totally different with that one!! LOL!
www.montabonsound.com www.29counts.com Pro Tools HD 2019.12 | HD Native PCIe & HD Native Thunderbolt | Lynx Aurora 16 HD | HD I/O | Digi 192 | 2010 Mac Pro 12 Core 3.46ghz | macOS Mojave 10.14.4 | 48 gigs RAM | Tascam DM3200 | Crane Song Avocet II | Antelope Isochrone OCX | Universal Audio Quad & Duo | Waves Mercury + Studio Classics v10 & Abbey Road Collection |
SSD and 12.3 commit | harryk | Pro Tools 12 | 11 | 11-08-2015 09:49 AM |
Does comping to a Heat enabled track print the Heat? | joshdrucker | macOS | 0 | 03-12-2014 10:17 PM |
To Commit or not to Commit, that is the question. | georgejw22 | Pro Tools 10 | 10 | 12-20-2011 05:30 AM |
HEAT on stereo bus as well as tracks | Picture Start | Pro Tools TDM Systems (Mac) | 11 | 11-22-2011 10:56 PM |
Heat on Aux Tracks? Bus output to Audio Track? | Rule62 | Pro Tools TDM Systems (Mac) | 9 | 09-19-2011 09:22 AM |
