Digi 003 spdif outputs and no headphones
Hi
I have been using my Digi 003 rack for some time with my monitors connected to analog outputs 1/2 with no dramas. I have just bought a Presonus Central Station Plus unit and firstly connected it via the same analog outputs1/2 and all works well monitors fine Headphones1 on digi is fine. When I hook it up via Spidf and adjust the I/O in protools monitors are fine but no headphones. I always thought that the Spdif output mirred the Analog 1/2 ouputs?...anyone know what is going on?
Windows 7 64bit, DigiRack 003, Presonus Digimax LT, Focusrite Voicemaster Pro, Presonus Firestudio 26/26, Presonus Central Station Plus, ProTools 9, |
Re: Digi 003 spdif outputs and no headphones
Did you select SPDIF in the headphone section of the CS?. Did you notice that you select the source for each section(main outputs and headphones) with separate buttons? No mirroring, but there is a way to assign multiple outs. You could also use SPDIF as your main feed, and use analog outs 1&2 to feed the headphone section(and feed them with an AUX send on all your tracks). Lots of possibilities here
thanks for the reply Albee... problem isn't on the Control Station... that is working fine... its the headphone jacks on on the Digi003 that have no signal... I am trying to set up headphone monitoring for myself without sacrificing analog outputs as you have described. Spdif main outs and headphone outs on digi003 simultaneously is what I am after
Aha! Hopefully someone else can chime in here. I haven't used the headphone jacks on my 003.......ever
Digi SPDIF outputs.. | Jeff E | Pro Tools TDM Systems (Mac) | 3 | 07-20-2009 01:42 AM |
No Sounds from Headphones or Rear outputs after upgrade to 8.0 LE | CuBi | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 6 | 01-27-2009 06:54 AM |
M-BOX Micro only outputs MONO to headphones?! | blacknight582 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 05-26-2008 09:02 PM |
003 outputs/ headphones? | tracktensionrecords | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 05-11-2008 08:41 PM |
Using single Outputs on 002 for Headphones??? | cscottshepherd | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 05-11-2007 09:49 PM |
