Digi001 Help.
Can the Digi 001 be compatiable with Pro Tools 7. I have Melodyne plugin and the highest version of Pro Tools I have is 6.4. It shows up when the plugins are loading up. But when I search for it, it is not there I once Had Pro Tools 7 and thought I saw that it recocgnized it but I don't remember. Can someone please help!!. Luckily, I haven't opened the melodyne box yet. I am trying to set up the demo for now.
Re: Digi001 Help.
Digi stopped including drivers for the 001 after 6.4. They claimed that they could not technically support the unit any longer but that has been widely rumoured to be false.
001, LE6.4cs69, XP Pro SP1, P4 2.8, 1 G Ram, Asus P4GE-MX board |
Re: Digi001 Help.
The highest version of Protools that supports the 001 is 6.4. I'm not sure on how far back Melodyne supports Protools.
Scott Formerly Hobo Wan Kenobi Core 2 Specs Page ASUS P6T6 Revolution | i7 930 | 12GB OCZ DDR3 1600 7-7-7-20 | PTLE 10 | CPTK | 003 | Presonus D8 | 11Rack | Alesis AI3 | Presonus HP60 | Mercury + Studio Classics | Sound Toys | MasseyPack | Axiom61 | MAudio Keystation Pro 88 |
Re: Digi001 Help.
Does anyone have any suggestions?
Re: Digi001 Help.
I beleive you can use a stand alone version of Melodyne, load the Audio file you wish to correct and save the corrected audio. Presumably you would load or be able to import into your session at that point.
I checked the Celemony website and they list the plugin version as being compatible with 7.1-7.3. According to the FAQ at Celemony at one time Melodyne ran under Windows98 so I would assume that there is a compatible version of Melodyne for 6.4 but it looks like the plug is not going to work. I suspect you may be out of luck if its not showing on any the plugin lists. This would be best answered by Celemonys tech support....Although if their is a way of geting it to work with 6.4 Post back and let us know. Also you might be able to use Celemony Via ReWire in 6.4 (assuming 6.4 supports rewire- I beleive it does) Probably not what you wanted to hear though. I don't have 6.4 so I'm guessing at a few things here.
Re: Digi001 Help.
6.4 does support Rewire but in my experience you'll only have one stereo out pair and the rest will be mono (no biggie if you don't mind using two seperate tracks for stereo). I believe there is a way to combine two rewire multi-mono outs on a stereo track which I've used before but I'm not at my pc at the moment.
Re: Digi001 Help.
Were you looking for the pitch correction feature? I use this in my 6.4 setup. It works great and it is FREE!
http://www.gvst.co.uk/gsnap.htm
***help with Digi001*** | DJDelphi | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 05-12-2006 07:10 AM |
Digi001? | Vengeance | Pro Tools TDM Systems (Win) | 1 | 01-13-2003 02:46 PM |
Digi001 vs. Digi001 Factory? | geminirand | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 6 | 01-07-2002 10:17 AM |
Mixer into Digi001 or Digi001 into Mixer? Please discuss... | MikeC | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 06-21-2001 12:29 AM |
Digi001 | misrule | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 7 | 05-23-2000 10:41 AM |
