Preset names for Kurzweil PC1x in ProTools
I'm a ProTools user on OSX and I use a Kurzweil PC1x synth. I'd like to select the preset names for my Kurzweil sounds in ProTools, but CoreMidi doesn't know the PC1x, so ProTools doesn't know it's preset names (I can connect a Motif Rack without problems, since OSX knows this one). Anyone suggestions how to fix this? Thanks, Marcel |
Re: Preset names for Kurzweil PC1x in ProTools
Hi Marcel
Google 'Kurzweil PC1x .midnam' and there is someone that has created this on the Cubase forum, you might be able to obtain this and transfer it to Pro Tools. From what I understand .midnam files are txt files and might work in Pro Tools, if not you can always create the .midnam file with CherryPicker with the existing Patch Name from this guy. filosofem
Aaron Mulqueen - 001 HD Native |
This is a modified version of the PC2r Orch shipped with Pro Tools. The "Model Name" name in the header has to match your Audio-Midi Setup name. Copy everthing between the lines and save to a file named pc1x.midnam. Place that file in the Library -> Audio -> Midi Patch Names -> Digidesign -> Kurzweil folder. Then attach the patchlist to your PC1x in the patch selection dialog for the track.
<font class="small">Code:<hr /><pre> <?xml version="1.0" encoding="UTF-8"?> <!DOCTYPE MIDINameDocument PUBLIC "-//MIDI Manufacturers Association//DTD MIDINameDocument 1.0//EN" ""> <MIDINameDocument> <Author>CherryPicker</Author> <MasterDeviceNames> <Manufacturer>Kurzweil</Manufacturer> <Model>PC1x</Model> <CustomDeviceMode Name="" > <ChannelNameSetAssignments> <ChannelNameSetAssign Channel="1" NameSet="Programs" /> <ChannelNameSetAssign Channel="2" NameSet="Programs" /> <ChannelNameSetAssign Channel="3" NameSet="Programs" /> <ChannelNameSetAssign Channel="4" NameSet="Programs" /> <ChannelNameSetAssign Channel="5" NameSet="Programs" /> <ChannelNameSetAssign Channel="6" NameSet="Programs" /> <ChannelNameSetAssign Channel="7" NameSet="Programs" /> <ChannelNameSetAssign Channel="8" NameSet="Programs" /> <ChannelNameSetAssign Channel="9" NameSet="Programs" /> <ChannelNameSetAssign Channel="10" NameSet="Programs" /> <ChannelNameSetAssign Channel="11" NameSet="Programs" /> <ChannelNameSetAssign Channel="12" NameSet="Programs" /> <ChannelNameSetAssign Channel="13" NameSet="Programs" /> <ChannelNameSetAssign Channel="14" NameSet="Programs" /> <ChannelNameSetAssign Channel="15" NameSet="Programs" /> <ChannelNameSetAssign Channel="16" NameSet="Programs" /> </ChannelNameSetAssignments> </CustomDeviceMode> <ChannelNameSet Name="Programs" > <AvailableForChannels> <AvailableChannel Channel="1" Available="true" /> <AvailableChannel Channel="2" Available="true" /> <AvailableChannel Channel="3" Available="true" /> <AvailableChannel Channel="4" Available="true" /> <AvailableChannel Channel="5" Available="true" /> <AvailableChannel Channel="6" Available="true" /> <AvailableChannel Channel="7" Available="true" /> <AvailableChannel Channel="8" Available="true" /> <AvailableChannel Channel="9" Available="true" /> <AvailableChannel Channel="10" Available="true" /> <AvailableChannel Channel="11" Available="true" /> <AvailableChannel Channel="12" Available="true" /> <AvailableChannel Channel="13" Available="true" /> <AvailableChannel Channel="14" Available="true" /> <AvailableChannel Channel="15" Available="true" /> <AvailableChannel Channel="16" Available="true" /> </AvailableForChannels> <PatchBank Name="Internal" > <MIDICommands> <ControlChange Control="32" Value="0" /> </MIDICommands> <UsesPatchNameList Name="Internal" /> </PatchBank> <PatchBank Name="Int2" > <MIDICommands> <ControlChange Control="32" Value="6" /> </MIDICommands> <UsesPatchNameList Name="Int2" /> </PatchBank> <PatchBank Name="Orchestral" > <MIDICommands> <ControlChange Control="32" Value="2" /> </MIDICommands> <UsesPatchNameList Name="Orchestral" /> </PatchBank> <PatchBank Name="General Midi" > <MIDICommands> <ControlChange Control="32" Value="4" /> </MIDICommands> <UsesPatchNameList Name="General Midi" /> </PatchBank> <PatchBank Name="GM Drum Kits" > <MIDICommands> <ControlChange Control="32" Value="7" /> </MIDICommands> <UsesPatchNameList Name="GM Drum Kits" /> </PatchBank> <PatchBank Name="User Voices" > <MIDICommands> <ControlChange Control="32" Value="1" /> </MIDICommands> <UsesPatchNameList Name="User Voices" /> </PatchBank> </ChannelNameSet> <PatchNameList Name="GM Drum Kits" > <Patch Number="7:000" Name="GM Standard Kit" ProgramChange="0" /> <Patch Number="7:001" Name="GM Room Kit" ProgramChange="1" /> <Patch Number="7:002" Name="GM Power Kit" ProgramChange="2" /> <Patch Number="7:003" Name="GM Elec Kit" ProgramChange="3" /> <Patch Number="7:004" Name="GM Synth Kit" ProgramChange="4" /> <Patch Number="7:005" Name="GM Jazz Kit" ProgramChange="5" /> <Patch Number="7:006" Name="GM Brush Kit" ProgramChange="6" /> <Patch Number="7:007" Name="GM Orch Kit" ProgramChange="7" /> </PatchNameList> <PatchNameList Name="Int2" > <Patch Number="6:000" Name="Sweet Ivories" ProgramChange="0" /> <Patch Number="6:001" Name="Nice Touch Grand" ProgramChange="1" /> <Patch Number="6:002" Name="Piano Solitude" ProgramChange="2" /> <Patch Number="6:003" Name="Piano Recital" ProgramChange="3" /> <Patch Number="6:004" Name="Full Bloom Piano" ProgramChange="4" /> <Patch Number="6:005" Name="Pianetta" ProgramChange="5" /> <Patch Number="6:006" Name="Suite Piano" ProgramChange="6" /> <Patch Number="6:007" Name="Dreamy Piano" ProgramChange="7" /> <Patch Number="6:008" Name="Basement Upright" ProgramChange="8" /> <Patch Number="6:009" Name="Chiano" ProgramChange="9" /> <Patch Number="6:010" Name="Way Back Piano" ProgramChange="10" /> <Patch Number="6:011" Name="Dance Piano" ProgramChange="11" /> <Patch Number="6:012" Name="Cloud Ride Piano" ProgramChange="12" /> <Patch Number="6:013" Name="Organic Piano" ProgramChange="13" /> <Patch Number="6:014" Name="Piano 38; Wash" ProgramChange="14" /> <Patch Number="6:015" Name="Piano 38; Vox Pad" ProgramChange="15" /> <Patch Number="6:016" Name="Mello E Piano" ProgramChange="16" /> <Patch Number="6:017" Name="Tines Square" ProgramChange="17" /> <Patch Number="6:018" Name="Brunch In Seoul" ProgramChange="18" /> <Patch Number="6:019" Name="Classy Roadz" ProgramChange="19" /> <Patch Number="6:020" Name="Barking Tines" ProgramChange="20" /> <Patch Number="6:021" Name="Clean and Soft" ProgramChange="21" /> <Patch Number="6:022" Name="Ballad Keys" ProgramChange="22" /> <Patch Number="6:023" Name="Lotus Keys" ProgramChange="23" /> <Patch Number="6:024" Name="Soft Ballad" ProgramChange="24" /> <Patch Number="6:025" Name="'70s FM Tines" ProgramChange="25" /> <Patch Number="6:026" Name="'90s FM Ballad" ProgramChange="26" /> <Patch Number="6:027" Name="Chorus Rock Pno" ProgramChange="27" /> <Patch Number="6:028" Name="Bright Pianotone" ProgramChange="28" /> <Patch Number="6:029" Name="Family Portrait" ProgramChange="29" /> <Patch Number="6:030" Name="Harpsi-Piano" ProgramChange="30" /> <Patch Number="6:031" Name="Fantasy Keys" ProgramChange="31" /> <Patch Number="6:032" Name="Janet's Comp" ProgramChange="32" /> <Patch Number="6:033" Name="Mild Sheen" ProgramChange="33" /> <Patch Number="6:034" Name="Scrape Glass" ProgramChange="34" /> <Patch Number="6:035" Name="Air Society" ProgramChange="35" /> <Patch Number="6:036" Name="Push Air" ProgramChange="36" /> <Patch Number="6:037" Name="Dronin'" ProgramChange="37" /> <Patch Number="6:038" Name="Alien Salt Mine" ProgramChange="38" /> <Patch Number="6:039" Name="Imperfect Storm" ProgramChange="39" /> <Patch Number="6:040" Name="Mod Clavier" ProgramChange="40" /> <Patch Number="6:041" Name="Belly Celeste" ProgramChange="41" /> <Patch Number="6:042" Name="Harpsichordion" ProgramChange="42" /> <Patch Number="6:043" Name="Circus Keys" ProgramChange="43" /> <Patch Number="6:044" Name="Cosmic Calliope" ProgramChange="44" /> <Patch Number="6:045" Name="Calliope Keys" ProgramChange="45" /> <Patch Number="6:046" Name="Chiff Attack" ProgramChange="46" /> <Patch Number="6:047" Name="Spaced Harmonix" ProgramChange="47" /> <Patch Number="6:048" Name="BackgroundOrgan" ProgramChange="48" /> <Patch Number="6:049" Name="Mello Tone Wheel" ProgramChange="49" /> <Patch Number="6:050" Name="Piped Organ" ProgramChange="50" /> <Patch Number="6:051" Name="Playful Piper" ProgramChange="51" /> <Patch Number="6:052" Name="Peter's Pan" ProgramChange="52" /> <Patch Number="6:053" Name="Imaginary Flute" ProgramChange="53" /> <Patch Number="6:054" Name="Bright Koreana" ProgramChange="54" /> <Patch Number="6:055" Name="Bouncin'BassBall" ProgramChange="55" /> <Patch Number="6:056" Name="Goosed Riff Sect" ProgramChange="56" /> <Patch Number="6:057" Name="Fatso Sax" ProgramChange="57" /> <Patch Number="6:058" Name="Big38;Beefy Saxes" ProgramChange="58" /> <Patch Number="6:059" Name="Goosed Unison" ProgramChange="59" /> <Patch Number="6:060" Name="Anabrass" ProgramChange="60" /> <Patch Number="6:061" Name="Honk'n Dyn Sax" ProgramChange="61" /> <Patch Number="6:062" Name="Saxy Lush" ProgramChange="62" /> <Patch Number="6:063" Name="Classical Brass" ProgramChange="63" /> <Patch Number="6:064" Name="Fast Vtrig Rosin" ProgramChange="64" /> <Patch Number="6:065" Name="Emotional String" ProgramChange="65" /> <Patch Number="6:066" Name="Octave Strings" ProgramChange="66" /> <Patch Number="6:067" Name="Emphatic Strings" ProgramChange="67" /> <Patch Number="6:068" Name="Rosin Section" ProgramChange="68" /> <Patch Number="6:069" Name="Resolute Section" ProgramChange="69" /> <Patch Number="6:070" Name="Tender Strings" ProgramChange="70" /> <Patch Number="6:071" Name="Flute 38; Strings" ProgramChange="71" /> <Patch Number="6:072" Name="Bright Voices" ProgramChange="72" /> <Patch Number="6:073" Name="Crystal Voices" ProgramChange="73" /> <Patch Number="6:074" Name="Vox 38; Organ" ProgramChange="74" /> <Patch Number="6:075" Name="BIG Ooh Voices" ProgramChange="75" /> <Patch Number="6:076" Name="BIG Voices" ProgramChange="76" /> <Patch Number="6:077" Name="Bright Syn Vox" ProgramChange="77" /> <Patch Number="6:078" Name="Vox Orgel" ProgramChange="78" /> <Patch Number="6:079" Name="Vox 38; Strings" ProgramChange="79" /> <Patch Number="6:080" Name="Subdivide" ProgramChange="80" /> <Patch Number="6:081" Name="Rezzy Bass/Poly" ProgramChange="81" /> <Patch Number="6:082" Name="Technicolor" ProgramChange="82" /> <Patch Number="6:083" Name="Elan Lead" ProgramChange="83" /> <Patch Number="6:084" Name="Sun Spot Lead" ProgramChange="84" /> <Patch Number="6:085" Name="Dinosaur's Lead" ProgramChange="85" /> <Patch Number="6:086" Name="Sawyer's Bomb" ProgramChange="86" /> <Patch Number="6:087" Name="Reverse Feedback" ProgramChange="87" /> <Patch Number="6:088" Name="Poseidon" ProgramChange="88" /> <Patch Number="6:089" Name="Analogica" ProgramChange="89" /> <Patch Number="6:090" Name="Anti Rez" ProgramChange="90" /> <Patch Number="6:091" Name="Spider's Web" ProgramChange="91" /> <Patch Number="6:092" Name="Ethereal Strings" ProgramChange="92" /> <Patch Number="6:093" Name="FreeResAhh Notch" ProgramChange="93" /> <Patch Number="6:094" Name="Ooh><Ahh Pad" ProgramChange="94" /> <Patch Number="6:095" Name="Vocalicious" ProgramChange="95" /> <Patch Number="6:096" Name="Titanium Guitar" ProgramChange="96" /> <Patch Number="6:097" Name="Latin Lover" ProgramChange="97" /> <Patch Number="6:098" Name="Roto 12 String" ProgramChange="98" /> <Patch Number="6:099" Name="Electric 12" ProgramChange="99" /> <Patch Number="6:100" Name="Twangy Guitar" ProgramChange="100" /> <Patch Number="6:101" Name="Chr Elec 38; Mute" ProgramChange="101" /> <Patch Number="6:102" Name="Comp Chr E Gtr" ProgramChange="102" /> <Patch Number="6:103" Name="Trashed Tubes" ProgramChange="103" /> <Patch Number="6:104" Name="Gimme The Finger" ProgramChange="104" /> <Patch Number="6:105" Name="Bright E Bass" ProgramChange="105" /> <Patch Number="6:106" Name="Bright A Bass" ProgramChange="106" /> <Patch Number="6:107" Name="Triangle Bass" ProgramChange="107" /> <Patch Number="6:108" Name="Yow Bass" ProgramChange="108" /> <Patch Number="6:109" Name="Mono Synth Bass" ProgramChange="109" /> <Patch Number="6:110" Name="400 HP Bass" ProgramChange="110" /> <Patch Number="6:111" Name="Base in Face" ProgramChange="111" /> <Patch Number="6:112" Name="Radio Kings/Rods" ProgramChange="112" /> <Patch Number="6:113" Name="Ripper Kit/Vinyl" ProgramChange="113" /> <Patch Number="6:114" Name="LA Drums/Brk Bt." ProgramChange="114" /> <Patch Number="6:115" Name="Compact/Raw Kit" ProgramChange="115" /> <Patch Number="6:116" Name="TubeTraps/lb.der" ProgramChange="116" /> <Patch Number="6:117" Name="Acoustric/HiPKit" ProgramChange="117" /> <Patch Number="6:118" Name="Dirt/Triphop Kit" ProgramChange="118" /> <Patch Number="6:119" Name="SumPumpKit MWsus" ProgramChange="119" /> <Patch Number="6:120" Name="Marimba" ProgramChange="120" /> <Patch Number="6:121" Name="Milky Way Vibes" ProgramChange="121" /> <Patch Number="6:122" Name="Percussionist" ProgramChange="122" /> <Patch Number="6:123" Name="Carnival" ProgramChange="123" /> <Patch Number="6:124" Name="Primitive Perc" ProgramChange="124" /> <Patch Number="6:125" Name="Bunch of Perc" ProgramChange="125" /> <Patch Number="6:126" Name="Perc Party" ProgramChange="126" /> <Patch Number="6:127" Name="Perc Circle" ProgramChange="127" /> </PatchNameList> <PatchNameList Name="Internal" > <Patch Number="0:000" Name="Stereo Grand" ProgramChange="0" /> <Patch Number="0:001" Name="Classic Grand" ProgramChange="1" /> <Patch Number="0:002" Name="Dynamic Grand" ProgramChange="2" /> <Patch Number="0:003" Name="Warm Grand" ProgramChange="3" /> <Patch Number="0:004" Name="Solo Grand Piano" ProgramChange="4" /> <Patch Number="0:005" Name="Concert Grand" ProgramChange="5" /> <Patch Number="0:006" Name="Mono Grand Piano" ProgramChange="6" /> <Patch Number="0:007" Name="Piano for layers" ProgramChange="7" /> <Patch Number="0:008" Name="Hard Rock Piano" ProgramChange="8" /> <Patch Number="0:009" Name="Rock Grand" ProgramChange="9" /> <Patch Number="0:010" Name="Grand Piano 440" ProgramChange="10" /> <Patch Number="0:011" Name="Mono Stage Piano" ProgramChange="11" /> <Patch Number="0:012" Name="Dyn Stage Piano" ProgramChange="12" /> <Patch Number="0:013" Name="Ragtime Piano" ProgramChange="13" /> <Patch Number="0:014" Name="Tack Piano" ProgramChange="14" /> <Patch Number="0:015" Name="Piano 38; Strings" ProgramChange="15" /> <Patch Number="0:016" Name="Classic E Piano" ProgramChange="16" /> <Patch Number="0:017" Name="Serious Classic" ProgramChange="17" /> <Patch Number="0:018" Name="That 70's E Pno" ProgramChange="18" /> <Patch Number="0:019" Name="Hard E Piano" ProgramChange="19" /> <Patch Number="0:020" Name="Lounge E Piano" ProgramChange="20" /> <Patch Number="0:021" Name="Dyno My E Pno" ProgramChange="21" /> <Patch Number="0:022" Name="Soft E Piano" ProgramChange="22" /> <Patch Number="0:023" Name="Hybrid E Piano" ProgramChange="23" /> <Patch Number="0:024" Name="My Best Wurly" ProgramChange="24" /> <Patch Number="0:025" Name="Big Red Wurly" ProgramChange="25" /> <Patch Number="0:026" Name="Brkfst in Korea" ProgramChange="26" /> <Patch Number="0:027" Name="Soft Wurly" ProgramChange="27" /> <Patch Number="0:028" Name="Wurly Road" ProgramChange="28" /> <Patch Number="0:029" Name="Pearly Keys" ProgramChange="29" /> <Patch Number="0:030" Name="Digital E Piano" ProgramChange="30" /> <Patch Number="0:031" Name="Ballad E Piano" ProgramChange="31" /> <Patch Number="0:032" Name="C3PO" ProgramChange="32" /> <Patch Number="0:033" Name="Digital E Grand" ProgramChange="33" /> <Patch Number="0:034" Name="Rock E Grand" ProgramChange="34" /> <Patch Number="0:035" Name="FantAsmAtron" ProgramChange="35" /> <Patch Number="0:036" Name="Atmaz" ProgramChange="36" /> <Patch Number="0:037" Name="Celestial Comet" ProgramChange="37" /> <Patch Number="0:038" Name="Comp Time" ProgramChange="38" /> <Patch Number="0:039" Name="Ruth Buzzy" ProgramChange="39" /> <Patch Number="0:040" Name="Clav Classic" ProgramChange="40" /> <Patch Number="0:041" Name="Touch Clav" ProgramChange="41" /> <Patch Number="0:042" Name="Dual Wah Clav" ProgramChange="42" /> <Patch Number="0:043" Name="Harpsichord" ProgramChange="43" /> <Patch Number="0:044" Name="Modern Harpsi" ProgramChange="44" /> <Patch Number="0:045" Name="CrystalClavchd" ProgramChange="45" /> <Patch Number="0:046" Name="Accordion" ProgramChange="46" /> <Patch Number="0:047" Name="Celesta" ProgramChange="47" /> <Patch Number="0:048" Name="The Reverend's" ProgramChange="48" /> <Patch Number="0:049" Name="Ballad Of 3 Bars" ProgramChange="49" /> <Patch Number="0:050" Name="Prog Rocker's B" ProgramChange="50" /> <Patch Number="0:051" Name="All Out Full On" ProgramChange="51" /> <Patch Number="0:052" Name="Grungy Overdrive" ProgramChange="52" /> <Patch Number="0:053" Name="Uptown Gospel" ProgramChange="53" /> <Patch Number="0:054" Name="Retro Roto" ProgramChange="54" /> <Patch Number="0:055" Name="Pipe Organ" ProgramChange="55" /> <Patch Number="0:056" Name="Big Brass" ProgramChange="56" /> <Patch Number="0:057" Name="Saxes/Trumpets" ProgramChange="57" /> <Patch Number="0:058" Name="Split Section" ProgramChange="58" /> <Patch Number="0:059" Name="Broadway Brass" ProgramChange="59" /> <Patch Number="0:060" Name="Trombones" ProgramChange="60" /> <Patch Number="0:061" Name="Bari/Tenor Sect" ProgramChange="61" /> <Patch Number="0:062" Name="Solo Tenor Sax" ProgramChange="62" /> <Patch Number="0:063" Name="Williams Brass" ProgramChange="63" /> <Patch Number="0:064" Name="Lyrical Strings" ProgramChange="64" /> <Patch Number="0:065" Name="Slow Strings" ProgramChange="65" /> <Patch Number="0:066" Name="Marcato Strings" ProgramChange="66" /> <Patch Number="0:067" Name="Layer Strings" ProgramChange="67" /> <Patch Number="0:068" Name="Fast Strings" ProgramChange="68" /> <Patch Number="0:069" Name="Touch Strings" ProgramChange="69" /> <Patch Number="0:070" Name="Velocity Strings" ProgramChange="70" /> <Patch Number="0:071" Name="Phantom Strings" ProgramChange="71" /> <Patch Number="0:072" Name="Ooh><Aah" ProgramChange="72" /> <Patch Number="0:073" Name="Doo><>Daa" ProgramChange="73" /> <Patch Number="0:074" Name="Baa stacc. Bop" ProgramChange="74" /> <Patch Number="0:075" Name="Doo stacc. Doop" ProgramChange="75" /> <Patch Number="0:076" Name="Daa stacc. Dot" ProgramChange="76" /> <Patch Number="0:077" Name="Scatman" ProgramChange="77" /> <Patch Number="0:078" Name="The Croons" ProgramChange="78" /> <Patch Number="0:079" Name="Cathedral Vox" ProgramChange="79" /> <Patch Number="0:080" Name="Solar Lead" ProgramChange="80" /> <Patch Number="0:081" Name="Vox Lead" ProgramChange="81" /> <Patch Number="0:082" Name="Alazawi" ProgramChange="82" /> <Patch Number="0:083" Name="Slo Wood Flute" ProgramChange="83" /> <Patch Number="0:084" Name="Groove Bass" ProgramChange="84" /> <Patch Number="0:085" Name="1/3 Pulse Bass" ProgramChange="85" /> <Patch Number="0:086" Name="Sweeper Bass" ProgramChange="86" /> <Patch Number="0:087" Name="Lowdown Bass" ProgramChange="87" /> <Patch Number="0:088" Name="Rez Aah Pad" ProgramChange="88" /> <Patch Number="0:089" Name="Crypt" ProgramChange="89" /> <Patch Number="0:090" Name="Meteor Strings" ProgramChange="90" /> <Patch Number="0:091" Name="Orch Pad" ProgramChange="91" /> <Patch Number="0:092" Name="Neptune" ProgramChange="92" /> <Patch Number="0:093" Name="Analogy" ProgramChange="93" /> <Patch Number="0:094" Name="Dream Catcher" ProgramChange="94" /> <Patch Number="0:095" Name="U Say Tomita..." ProgramChange="95" /> <Patch Number="0:096" Name="Acoustic Guitar" ProgramChange="96" /> <Patch Number="0:097" Name="Strummer 12 Str" ProgramChange="97" /> <Patch Number="0:098" Name="Rich 6 String" ProgramChange="98" /> <Patch Number="0:099" Name="12 String Guitar" ProgramChange="99" /> <Patch Number="0:100" Name="Chorus Elec Gtr" ProgramChange="100" /> <Patch Number="0:101" Name="Elec 12 String" ProgramChange="101" /> <Patch Number="0:102" Name="Jazzy Frets" ProgramChange="102" /> <Patch Number="0:103" Name="Lead Rock Gtr" ProgramChange="103" /> <Patch Number="0:104" Name="Round and Wound" ProgramChange="104" /> <Patch Number="0:105" Name="Punch Bass" ProgramChange="105" /> <Patch Number="0:106" Name="Two Finger Bass" ProgramChange="106" /> <Patch Number="0:107" Name="Dual-Tri Bass" ProgramChange="107" /> <Patch Number="0:108" Name="Clav o' Bass" ProgramChange="108" /> <Patch Number="0:109" Name="Fret Not Bass" ProgramChange="109" /> <Patch Number="0:110" Name="Upright Bass 1" ProgramChange="110" /> <Patch Number="0:111" Name="Upright Bass 2" ProgramChange="111" /> <Patch Number="0:112" Name="Studio Drums 1+2" ProgramChange="112" /> <Patch Number="0:113" Name="Studio Drums 3+4" ProgramChange="113" /> <Patch Number="0:114" Name="Ambient Rock Kit" ProgramChange="114" /> <Patch Number="0:115" Name="Coliseum Kit" ProgramChange="115" /> <Patch Number="0:116" Name="Resonant Traps" ProgramChange="116" /> <Patch Number="0:117" Name="Tripkit/Trashkit" ProgramChange="117" /> <Patch Number="0:118" Name="Beat Box" ProgramChange="118" /> <Patch Number="0:119" Name="Electro Kit" ProgramChange="119" /> <Patch Number="0:120" Name="Virtuoso Perc" ProgramChange="120" /> <Patch Number="0:121" Name="Rhythm Maker" ProgramChange="121" /> <Patch Number="0:122" Name="Woody Marimba" ProgramChange="122" /> <Patch Number="0:123" Name="African Marimba" ProgramChange="123" /> <Patch Number="0:124" Name="Vibes" ProgramChange="124" /> <Patch Number="0:125" Name="New Fluid Vibes" ProgramChange="125" /> <Patch Number="0:126" Name="Aborigine Jam" ProgramChange="126" /> <Patch Number="0:127" Name="Drums 'n Bells" ProgramChange="127" /> </PatchNameList> <PatchNameList Name="Orchestral" > <Patch Number="2:000" Name="Fast Violin prs" ProgramChange="0" /> <Patch Number="2:001" Name="Med Violin vib" ProgramChange="1" /> <Patch Number="2:002" Name="Slo Violin p/v" ProgramChange="2" /> <Patch Number="2:003" Name="Fast Viola prs" ProgramChange="3" /> <Patch Number="2:004" Name="Med Viola prs" ProgramChange="4" /> <Patch Number="2:005" Name="Slo Viola p/v" ProgramChange="5" /> <Patch Number="2:006" Name="Fast Cello prs" ProgramChange="6" /> <Patch Number="2:007" Name="Med Cello p/v" ProgramChange="7" /> <Patch Number="2:008" Name="Slo Cello vib" ProgramChange="8" /> <Patch Number="2:009" Name="Studio Cello" ProgramChange="9" /> <Patch Number="2:010" Name="Studio Bass" ProgramChange="10" /> <Patch Number="2:011" Name="Recital Bass" ProgramChange="11" /> <Patch Number="2:012" Name="Slo Bass prs" ProgramChange="12" /> <Patch Number="2:013" Name="Slo Bass vib" ProgramChange="13" /> <Patch Number="2:014" Name="Slo String Orch" ProgramChange="14" /> <Patch Number="2:015" Name="Studio Strings" ProgramChange="15" /> <Patch Number="2:016" Name="Chamber Strings" ProgramChange="16" /> <Patch Number="2:017" Name="Baroque Strings" ProgramChange="17" /> <Patch Number="2:018" Name="Intense Strings " ProgramChange="18" /> <Patch Number="2:019" Name="Stacato Strings" ProgramChange="19" /> <Patch Number="2:020" Name="Fast Tremolando" ProgramChange="20" /> <Patch Number="2:021" Name="Med Tremolando" ProgramChange="21" /> <Patch Number="2:022" Name="Slo Tremolando" ProgramChange="22" /> <Patch Number="2:023" Name="VTrig Tremolando" ProgramChange="23" /> <Patch Number="2:024" Name="Full Pizzicato" ProgramChange="24" /> <Patch Number="2:025" Name="Medium Pizzicato" ProgramChange="25" /> <Patch Number="2:026" Name="Dry Pizzicato" ProgramChange="26" /> <Patch Number="2:027" Name="Solo Flute prs" ProgramChange="27" /> <Patch Number="2:028" Name="Solo Flute vib" ProgramChange="28" /> <Patch Number="2:029" Name="sfz Ens Flute" ProgramChange="29" /> <Patch Number="2:030" Name="Solo Oboe" ProgramChange="30" /> <Patch Number="2:031" Name="Slow Oboe" ProgramChange="31" /> <Patch Number="2:032" Name="Ens Oboe" ProgramChange="32" /> <Patch Number="2:033" Name="Solo Eng Hrn prs" ProgramChange="33" /> <Patch Number="2:034" Name="Eng Horn vib" ProgramChange="34" /> <Patch Number="2:035" Name="Slow EngHorn prs" ProgramChange="35" /> <Patch Number="2:036" Name="Solo Clarinet" ProgramChange="36" /> <Patch Number="2:037" Name="Slow Clarinet" ProgramChange="37" /> <Patch Number="2:038" Name="Ens Clarinet" ProgramChange="38" /> <Patch Number="2:039" Name="Solo Bassoon" ProgramChange="39" /> <Patch Number="2:040" Name="Solo Bassoon Vib" ProgramChange="40" /> <Patch Number="2:041" Name="Ens Bassoon/Oboe" ProgramChange="41" /> <Patch Number="2:042" Name="Solo Dbl Reeds" ProgramChange="42" /> <Patch Number="2:043" Name="Soft Trumpet" ProgramChange="43" /> <Patch Number="2:044" Name="Slow Soft Trp" ProgramChange="44" /> <Patch Number="2:045" Name="Hard Trumpet" ProgramChange="45" /> <Patch Number="2:046" Name="Slo Hard Trumpet" ProgramChange="46" /> <Patch Number="2:047" Name="Slo Horn 38; Trp" ProgramChange="47" /> <Patch Number="2:048" Name="Solo Fr Horn" ProgramChange="48" /> <Patch Number="2:049" Name="Ensemble FrHorn" ProgramChange="49" /> <Patch Number="2:050" Name="Fr Horn Sect 1" ProgramChange="50" /> <Patch Number="2:051" Name="Fr Horn Sect 2" ProgramChange="51" /> <Patch Number="2:052" Name="Horn Section" ProgramChange="52" /> <Patch Number="2:053" Name="Solo Trombone" ProgramChange="53" /> <Patch Number="2:054" Name="Ensemble Bone" ProgramChange="54" /> <Patch Number="2:055" Name="Solo Tuba" ProgramChange="55" /> <Patch Number="2:056" Name="sfz Orch Tuba" ProgramChange="56" /> <Patch Number="2:057" Name="Jazz Harmon Trp" ProgramChange="57" /> <Patch Number="2:058" Name="Ballad HarmonTrp" ProgramChange="58" /> <Patch Number="2:059" Name="sfz SoftTrp Sect" ProgramChange="59" /> <Patch Number="2:060" Name="sfz Jazz Brass" ProgramChange="60" /> <Patch Number="2:061" Name="St Jazz Brass sw" ProgramChange="61" /> <Patch Number="2:062" Name="Stereo Brass sw" ProgramChange="62" /> <Patch Number="2:063" Name="Solo Sax" ProgramChange="63" /> <Patch Number="2:064" Name="Stolen Moments" ProgramChange="64" /> <Patch Number="2:065" Name="Harmon Band" ProgramChange="65" /> <Patch Number="2:066" Name="Slo Dyn Orch" ProgramChange="66" /> <Patch Number="2:067" Name="Fast Dyn Orch" ProgramChange="67" /> <Patch Number="2:068" Name="Total Orch 1" ProgramChange="68" /> <Patch Number="2:069" Name="Total Orch 2" ProgramChange="69" /> <Patch Number="2:070" Name="sfz Orch prs" ProgramChange="70" /> <Patch Number="2:071" Name="Winds 38; ChmbStr" ProgramChange="71" /> <Patch Number="2:072" Name="Winds 38; Strings" ProgramChange="72" /> <Patch Number="2:073" Name="Horns 38; Strings" ProgramChange="73" /> <Patch Number="2:074" Name="Woodwind Section" ProgramChange="74" /> <Patch Number="2:075" Name="Reeds 38; Bells" ProgramChange="75" /> <Patch Number="2:076" Name="Pizz 38; Timp" ProgramChange="76" /> <Patch Number="2:077" Name="Cathedral Choir" ProgramChange="77" /> <Patch Number="2:078" Name="Aah Choir prs" ProgramChange="78" /> <Patch Number="2:079" Name="Mixed Choir" ProgramChange="79" /> <Patch Number="2:080" Name="Choir from Above" ProgramChange="80" /> <Patch Number="2:081" Name="DivineInterventn" ProgramChange="81" /> <Patch Number="2:082" Name="Chapel Organ" ProgramChange="82" /> <Patch Number="2:083" Name="Cathedral Organ" ProgramChange="83" /> <Patch Number="2:084" Name="Pipes 16'8',reed" ProgramChange="84" /> <Patch Number="2:085" Name="Full Pipes" ProgramChange="85" /> <Patch Number="2:086" Name="Orch Harp" ProgramChange="86" /> <Patch Number="2:087" Name="St Solo Harp" ProgramChange="87" /> <Patch Number="2:088" Name="Harp Oasis" ProgramChange="88" /> <Patch Number="2:089" Name="Under Harp" ProgramChange="89" /> <Patch Number="2:090" Name="Classical Guitar" ProgramChange="90" /> <Patch Number="2:091" Name="Silky Nylons" ProgramChange="91" /> <Patch Number="2:092" Name="Romantic Nylon" ProgramChange="92" /> <Patch Number="2:093" Name="Mando-Lute" ProgramChange="93" /> <Patch Number="2:094" Name="Orch Chimes" ProgramChange="94" /> <Patch Number="2:095" Name="Stereo Chimes" ProgramChange="95" /> <Patch Number="2:096" Name="Chime Bell" ProgramChange="96" /> <Patch Number="2:097" Name="Chimes/Glock" ProgramChange="97" /> <Patch Number="2:098" Name="Glockenspiel" ProgramChange="98" /> <Patch Number="2:099" Name="Orch Celeste" ProgramChange="99" /> <Patch Number="2:100" Name="Xylophone" ProgramChange="100" /> <Patch Number="2:101" Name="Orch Percussion" ProgramChange="101" /> <Patch Number="2:102" Name="Orch Timpani" ProgramChange="102" /> <Patch Number="2:103" Name="Solo Timpani" ProgramChange="103" /> <Patch Number="2:104" Name="Dynamic Timpani" ProgramChange="104" /> <Patch Number="2:105" Name="Temple Blocks" ProgramChange="105" /> <Patch Number="2:106" Name="Stereo Tam-tam" ProgramChange="106" /> <Patch Number="2:107" Name="Trap Set" ProgramChange="107" /> <Patch Number="2:108" Name="Modern Blockage " ProgramChange="108" /> <Patch Number="2:109" Name="Beaty Drum" ProgramChange="109" /> <Patch Number="2:110" Name="Cage's Ensemble" ProgramChange="110" /> <Patch Number="2:111" Name="New Touch Perc" ProgramChange="111" /> <Patch Number="2:112" Name="Perc 38; Blocks" ProgramChange="112" /> <Patch Number="2:113" Name="Puppet Strings Perc" ProgramChange="113" /> <Patch Number="2:114" Name="Pop Can Perc" ProgramChange="114" /> <Patch Number="2:115" Name="Onklungy Perc" ProgramChange="115" /> <Patch Number="2:116" Name="Skullophones " ProgramChange="116" /> <Patch Number="2:117" Name="Exotic Mallets" ProgramChange="117" /> <Patch Number="2:118" Name="Acoustic Mbira" ProgramChange="118" /> <Patch Number="2:119" Name="St Elec Mbira" ProgramChange="119" /> <Patch Number="2:120" Name="Perc Harp" ProgramChange="120" /> <Patch Number="2:121" Name="Pluck 38; Block" ProgramChange="121" /> <Patch Number="2:122" Name="Hybrid Pluck" ProgramChange="122" /> <Patch Number="2:123" Name="Bells/Mark Tree" ProgramChange="123" /> <Patch Number="2:124" Name="Circus Glitter" ProgramChange="124" /> <Patch Number="2:125" Name="Swing'n Chimes" ProgramChange="125" /> <Patch Number="2:126" Name="Crystal Lagoon" ProgramChange="126" /> <Patch Number="2:127" Name="Clang Clang" ProgramChange="127" /> </PatchNameList> <PatchNameList Name="General Midi" > <Patch Number="0" Name="Grand Piano" ProgramChange="0" /> <Patch Number="1" Name="Bright Piano" ProgramChange="1" /> <Patch Number="2" Name="Electric Grand" ProgramChange="2" /> <Patch Number="3" Name="Honky-Tonk Pno" ProgramChange="3" /> <Patch Number="4" Name="Electric Pno 1" ProgramChange="4" /> <Patch Number="5" Name="Electric Pno 2" ProgramChange="5" /> <Patch Number="6" Name="Harpsichord " ProgramChange="6" /> <Patch Number="7" Name="Clavinet" ProgramChange="7" /> <Patch Number="8" Name="Celesta" ProgramChange="8" /> <Patch Number="9" Name="Glockenspiel" ProgramChange="9" /> <Patch Number="10" Name="Music Box" ProgramChange="10" /> <Patch Number="11" Name="Vibraphone" ProgramChange="11" /> <Patch Number="12" Name="Marimba" ProgramChange="12" /> <Patch Number="13" Name="Xylophone" ProgramChange="13" /> <Patch Number="14" Name="Tubular Bells" ProgramChange="14" /> <Patch Number="15" Name="Dulcimer" ProgramChange="15" /> <Patch Number="16" Name="Drawbar Organ" ProgramChange="16" /> <Patch Number="17" Name="Perc Organ" ProgramChange="17" /> <Patch Number="18" Name="Rock Organ" ProgramChange="18" /> <Patch Number="19" Name="Church Organ" ProgramChange="19" /> <Patch Number="20" Name="Reed Organ" ProgramChange="20" /> <Patch Number="21" Name="Accordion" ProgramChange="21" /> <Patch Number="22" Name="Harmonica" ProgramChange="22" /> <Patch Number="23" Name="Bandoneon" ProgramChange="23" /> <Patch Number="24" Name="Nylon Str Gtr" ProgramChange="24" /> <Patch Number="25" Name="Steel Str Gtr" ProgramChange="25" /> <Patch Number="26" Name="Jazz Guitar" ProgramChange="26" /> <Patch Number="27" Name="Clean Guitar" ProgramChange="27" /> <Patch Number="28" Name="Muted Guitar" ProgramChange="28" /> <Patch Number="29" Name="Overdrive Gtr" ProgramChange="29" /> <Patch Number="30" Name="Distorted Gtr" ProgramChange="30" /> <Patch Number="31" Name="Gtr Harmonics" ProgramChange="31" /> <Patch Number="32" Name="Acoustic Bass" ProgramChange="32" /> <Patch Number="33" Name="Fingered Bass" ProgramChange="33" /> <Patch Number="34" Name="Picked Bass" ProgramChange="34" /> <Patch Number="35" Name="Fretless Bass" ProgramChange="35" /> <Patch Number="36" Name="Slap Bass 1" ProgramChange="36" /> <Patch Number="37" Name="Slap Bass 2" ProgramChange="37" /> <Patch Number="38" Name="Synth Bass 1" ProgramChange="38" /> <Patch Number="39" Name="Synth Bass 2" ProgramChange="39" /> <Patch Number="40" Name="Violin" ProgramChange="40" /> <Patch Number="41" Name="Viola" ProgramChange="41" /> <Patch Number="42" Name="Cello" ProgramChange="42" /> <Patch Number="43" Name="Contrabass" ProgramChange="43" /> <Patch Number="44" Name="TremoloStrings" ProgramChange="44" /> <Patch Number="45" Name="Pizzicato Str" ProgramChange="45" /> <Patch Number="46" Name="Plucked Harp" ProgramChange="46" /> <Patch Number="47" Name="Timpani" ProgramChange="47" /> <Patch Number="48" Name="Ensemble Strs" ProgramChange="48" /> <Patch Number="49" Name="Slow Strings" ProgramChange="49" /> <Patch Number="50" Name="SynthStrings 1" ProgramChange="50" /> <Patch Number="51" Name="SynthStrings 2" ProgramChange="51" /> <Patch Number="52" Name="Choir Oohs" ProgramChange="52" /> <Patch Number="53" Name="Voice Oohs" ProgramChange="53" /> <Patch Number="54" Name="Synth Vox" ProgramChange="54" /> <Patch Number="55" Name="Orchestra Hit" ProgramChange="55" /> <Patch Number="56" Name="Trumpet" ProgramChange="56" /> <Patch Number="57" Name="Trombone" ProgramChange="57" /> <Patch Number="58" Name="Tuba" ProgramChange="58" /> <Patch Number="59" Name="Muted Trumpet" ProgramChange="59" /> <Patch Number="60" Name="French Horn" ProgramChange="60" /> <Patch Number="61" Name="Brass Section" ProgramChange="61" /> <Patch Number="62" Name="Synth Brass 1" ProgramChange="62" /> <Patch Number="63" Name="Synth Brass 2" ProgramChange="63" /> <Patch Number="64" Name="Soprano Sax" ProgramChange="64" /> <Patch Number="65" Name="Alto Sax" ProgramChange="65" /> <Patch Number="66" Name="Tenor Sax" ProgramChange="66" /> <Patch Number="67" Name="Bariton Sax" ProgramChange="67" /> <Patch Number="68" Name="Oboe" ProgramChange="68" /> <Patch Number="69" Name="English Horn" ProgramChange="69" /> <Patch Number="70" Name="Bassoon" ProgramChange="70" /> <Patch Number="71" Name="Clarinet" ProgramChange="71" /> <Patch Number="72" Name="Piccolo" ProgramChange="72" /> <Patch Number="73" Name="Flute" ProgramChange="73" /> <Patch Number="74" Name="Recorder" ProgramChange="74" /> <Patch Number="75" Name="Pan Flute" ProgramChange="75" /> <Patch Number="76" Name="Blown Bottle" ProgramChange="76" /> <Patch Number="77" Name="Shakuhachi" ProgramChange="77" /> <Patch Number="78" Name="Whistle" ProgramChange="78" /> <Patch Number="79" Name="Ocarina" ProgramChange="79" /> <Patch Number="80" Name="Square Wave" ProgramChange="80" /> <Patch Number="81" Name="Sawtooth Wave" ProgramChange="81" /> <Patch Number="82" Name="Synth Calliope" ProgramChange="82" /> <Patch Number="83" Name="Chiff Lead" ProgramChange="83" /> <Patch Number="84" Name="Charang" ProgramChange="84" /> <Patch Number="85" Name="Solo Vox" ProgramChange="85" /> <Patch Number="86" Name="Fifths SawWave" ProgramChange="86" /> <Patch Number="87" Name="Bassead Syn" ProgramChange="87" /> <Patch Number="88" Name="Fantasia Lead" ProgramChange="88" /> <Patch Number="89" Name="Warm Pad" ProgramChange="89" /> <Patch Number="90" Name="Poly Synth Pad" ProgramChange="90" /> <Patch Number="91" Name="SpaceVoice Pad" ProgramChange="91" /> <Patch Number="92" Name="BowedGlass Pad" ProgramChange="92" /> <Patch Number="93" Name="Metallic Pad" ProgramChange="93" /> <Patch Number="95" Name="Halo Pad" ProgramChange="94" /> <Patch Number="95" Name="Sweep Pad" ProgramChange="95" /> <Patch Number="96" Name="Ice Rain" ProgramChange="96" /> <Patch Number="97" Name="Soundtrack" ProgramChange="97" /> <Patch Number="98" Name="Crystal" ProgramChange="98" /> <Patch Number="99" Name="Atmosphere" ProgramChange="99" /> <Patch Number="100" Name="Brightness" ProgramChange="100" /> <Patch Number="101" Name="Goblins" ProgramChange="101" /> <Patch Number="102" Name="Echo Drops" ProgramChange="102" /> <Patch Number="103" Name="Sci-fi Pad" ProgramChange="103" /> <Patch Number="104" Name="Sitar" ProgramChange="104" /> <Patch Number="105" Name="Banjo" ProgramChange="105" /> <Patch Number="106" Name="Shamisen " ProgramChange="106" /> <Patch Number="107" Name="Koto" ProgramChange="107" /> <Patch Number="108" Name="Kalimba" ProgramChange="108" /> <Patch Number="109" Name="Bagpipe" ProgramChange="109" /> <Patch Number="110" Name="Fiddle" ProgramChange="110" /> <Patch Number="111" Name="Shanai" ProgramChange="111" /> <Patch Number="112" Name="Tinkle Bell" ProgramChange="112" /> <Patch Number="113" Name="Agogo" ProgramChange="113" /> <Patch Number="114" Name="Steel Drums" ProgramChange="114" /> <Patch Number="115" Name="Woodblock" ProgramChange="115" /> <Patch Number="116" Name="Taiko Drum" ProgramChange="116" /> <Patch Number="117" Name="Melodic Toms" ProgramChange="117" /> <Patch Number="118" Name="Synth Drums" ProgramChange="118" /> <Patch Number="119" Name="Reverse Cymbal" ProgramChange="119" /> <Patch Number="120" Name="Gtr Fret Noise" ProgramChange="120" /> <Patch Number="121" Name="Breath Noise" ProgramChange="121" /> <Patch Number="122" Name="Seashore" ProgramChange="122" /> <Patch Number="123" Name="Birds" ProgramChange="123" /> <Patch Number="124" Name="Telephone" ProgramChange="124" /> <Patch Number="125" Name="Helicopter" ProgramChange="125" /> <Patch Number="126" Name="Applause" ProgramChange="126" /> <Patch Number="127" Name="Gun Shot" ProgramChange="127" /> </PatchNameList> <PatchNameList Name="User Voices" > <Patch Number="1:000" Name="User Voice" ProgramChange="0" /> <Patch Number="1:001" Name="User Voice" ProgramChange="1" /> <Patch Number="1:002" Name="User Voice" ProgramChange="2" /> <Patch Number="1:003" Name="User Voice" ProgramChange="3" /> <Patch Number="1:004" Name="User Voice" ProgramChange="4" /> <Patch Number="1:005" Name="User Voice" ProgramChange="5" /> <Patch Number="1:006" Name="User Voice" ProgramChange="6" /> <Patch Number="1:007" Name="User Voice" ProgramChange="7" /> <Patch Number="1:008" Name="User Voice" ProgramChange="8" /> <Patch Number="1:009" Name="User Voice" ProgramChange="9" /> <Patch Number="1:010" Name="User Voice" ProgramChange="10" /> <Patch Number="1:011" Name="User Voice" ProgramChange="11" /> <Patch Number="1:012" Name="User Voice" ProgramChange="12" /> <Patch Number="1:013" Name="User Voice" ProgramChange="13" /> <Patch Number="1:014" Name="User Voice" ProgramChange="14" /> <Patch Number="1:015" Name="User Voice" ProgramChange="15" /> <Patch Number="1:016" Name="User Voice" ProgramChange="16" /> <Patch Number="1:017" Name="User Voice" ProgramChange="17" /> <Patch Number="1:018" Name="User Voice" ProgramChange="18" /> <Patch Number="1:019" Name="User Voice" ProgramChange="19" /> <Patch Number="1:020" Name="User Voice" ProgramChange="20" /> <Patch Number="1:021" Name="User Voice" ProgramChange="21" /> <Patch Number="1:022" Name="User Voice" ProgramChange="22" /> <Patch Number="1:023" Name="User Voice" ProgramChange="23" /> <Patch Number="1:024" Name="User Voice" ProgramChange="24" /> <Patch Number="1:025" Name="User Voice" ProgramChange="25" /> <Patch Number="1:026" Name="User Voice" ProgramChange="26" /> <Patch Number="1:027" Name="User Voice" ProgramChange="27" /> <Patch Number="1:028" Name="User Voice" ProgramChange="28" /> <Patch Number="1:029" Name="User Voice" ProgramChange="29" /> <Patch Number="1:030" Name="User Voice" ProgramChange="30" /> <Patch Number="1:031" Name="User Voice" ProgramChange="31" /> <Patch Number="1:032" Name="User Voice" ProgramChange="32" /> <Patch Number="1:033" Name="User Voice" ProgramChange="33" /> <Patch Number="1:034" Name="User Voice" ProgramChange="34" /> <Patch Number="1:035" Name="User Voice" ProgramChange="35" /> <Patch Number="1:036" Name="User Voice" ProgramChange="36" /> <Patch Number="1:037" Name="User Voice" ProgramChange="37" /> <Patch Number="1:038" Name="User Voice" ProgramChange="38" /> <Patch Number="1:039" Name="User Voice" ProgramChange="39" /> <Patch Number="1:040" Name="User Voice" ProgramChange="40" /> <Patch Number="1:041" Name="User Voice" ProgramChange="41" /> <Patch Number="1:042" Name="User Voice" ProgramChange="42" /> <Patch Number="1:043" Name="User Voice" ProgramChange="43" /> <Patch Number="1:044" Name="User Voice" ProgramChange="44" /> <Patch Number="1:045" Name="User Voice" ProgramChange="45" /> <Patch Number="1:046" Name="User Voice" ProgramChange="46" /> <Patch Number="1:047" Name="User Voice" ProgramChange="47" /> <Patch Number="1:048" Name="User Voice" ProgramChange="48" /> <Patch Number="1:049" Name="User Voice" ProgramChange="49" /> <Patch Number="1:050" Name="User Voice" ProgramChange="50" /> <Patch Number="1:051" Name="User Voice" ProgramChange="51" /> <Patch Number="1:052" Name="User Voice" ProgramChange="52" /> <Patch Number="1:053" Name="User Voice" ProgramChange="53" /> <Patch Number="1:054" Name="User Voice" ProgramChange="54" /> <Patch Number="1:055" Name="User Voice" ProgramChange="55" /> <Patch Number="1:056" Name="User Voice" ProgramChange="56" /> <Patch Number="1:057" Name="User Voice" ProgramChange="57" /> <Patch Number="1:058" Name="User Voice" ProgramChange="58" /> <Patch Number="1:059" Name="User Voice" ProgramChange="59" /> <Patch Number="1:060" Name="User Voice" ProgramChange="60" /> <Patch Number="1:061" Name="User Voice" ProgramChange="61" /> <Patch Number="1:062" Name="User Voice" ProgramChange="62" /> <Patch Number="1:063" Name="User Voice" ProgramChange="63" /> <Patch Number="1:064" Name="User Voice" ProgramChange="64" /> <Patch Number="1:065" Name="User Voice" ProgramChange="65" /> <Patch Number="1:066" Name="User Voice" ProgramChange="66" /> <Patch Number="1:067" Name="User Voice" ProgramChange="67" /> <Patch Number="1:068" Name="User Voice" ProgramChange="68" /> <Patch Number="1:069" Name="User Voice" ProgramChange="69" /> <Patch Number="1:070" Name="User Voice" ProgramChange="70" /> <Patch Number="1:071" Name="User Voice" ProgramChange="71" /> <Patch Number="1:072" Name="User Voice" ProgramChange="72" /> <Patch Number="1:073" Name="User Voice" ProgramChange="73" /> <Patch Number="1:074" Name="User Voice" ProgramChange="74" /> <Patch Number="1:075" Name="User Voice" ProgramChange="75" /> <Patch Number="1:076" Name="User Voice" ProgramChange="76" /> <Patch Number="1:077" Name="User Voice" ProgramChange="77" /> <Patch Number="1:078" Name="User Voice" ProgramChange="78" /> <Patch Number="1:079" Name="User Voice" ProgramChange="79" /> <Patch Number="1:080" Name="User Voice" ProgramChange="80" /> <Patch Number="1:081" Name="User Voice" ProgramChange="81" /> <Patch Number="1:082" Name="User Voice" ProgramChange="82" /> <Patch Number="1:083" Name="User Voice" ProgramChange="83" /> <Patch Number="1:084" Name="User Voice" ProgramChange="84" /> <Patch Number="1:085" Name="User Voice" ProgramChange="85" /> <Patch Number="1:086" Name="User Voice" ProgramChange="86" /> <Patch Number="1:087" Name="User Voice" ProgramChange="87" /> <Patch Number="1:088" Name="User Voice" ProgramChange="88" /> <Patch Number="1:089" Name="User Voice" ProgramChange="89" /> <Patch Number="1:090" Name="User Voice" ProgramChange="90" /> <Patch Number="1:091" Name="User Voice" ProgramChange="91" /> <Patch Number="1:092" Name="User Voice" ProgramChange="92" /> <Patch Number="1:093" Name="User Voice" ProgramChange="93" /> <Patch Number="1:094" Name="User Voice" ProgramChange="94" /> <Patch Number="1:095" Name="User Voice" ProgramChange="95" /> <Patch Number="1:096" Name="User Voice" ProgramChange="96" /> <Patch Number="1:097" Name="User Voice" ProgramChange="97" /> <Patch Number="1:098" Name="User Voice" ProgramChange="98" /> <Patch Number="1:099" Name="User Voice" ProgramChange="99" /> <Patch Number="1:100" Name="User Voice" ProgramChange="100" /> <Patch Number="1:101" Name="User Voice" ProgramChange="101" /> <Patch Number="1:102" Name="User Voice" ProgramChange="102" /> <Patch Number="1:103" Name="User Voice" ProgramChange="103" /> <Patch Number="1:104" Name="User Voice" ProgramChange="104" /> <Patch Number="1:105" Name="User Voice" ProgramChange="105" /> <Patch Number="1:106" Name="User Voice" ProgramChange="106" /> <Patch Number="1:107" Name="User Voice" ProgramChange="107" /> <Patch Number="1:108" Name="User Voice" ProgramChange="108" /> <Patch Number="1:109" Name="User Voice" ProgramChange="109" /> <Patch Number="1:110" Name="User Voice" ProgramChange="110" /> <Patch Number="1:111" Name="User Voice" ProgramChange="111" /> <Patch Number="1:112" Name="User Voice" ProgramChange="112" /> <Patch Number="1:113" Name="User Voice" ProgramChange="113" /> <Patch Number="1:114" Name="User Voice" ProgramChange="114" /> <Patch Number="1:115" Name="User Voice" ProgramChange="115" /> <Patch Number="1:116" Name="User Voice" ProgramChange="116" /> <Patch Number="1:117" Name="User Voice" ProgramChange="117" /> <Patch Number="1:118" Name="User Voice" ProgramChange="118" /> <Patch Number="1:119" Name="User Voice" ProgramChange="119" /> <Patch Number="1:120" Name="User Voice" ProgramChange="120" /> <Patch Number="1:121" Name="User Voice" ProgramChange="121" /> <Patch Number="1:122" Name="User Voice" ProgramChange="122" /> <Patch Number="1:123" Name="User Voice" ProgramChange="123" /> <Patch Number="1:124" Name="User Voice" ProgramChange="124" /> <Patch Number="1:125" Name="User Voice" ProgramChange="125" /> <Patch Number="1:126" Name="User Voice" ProgramChange="126" /> <Patch Number="1:127" Name="User Voice" ProgramChange="127" /> </PatchNameList> </MasterDeviceNames> </MIDINameDocument> </pre><hr />
PT 2024.3 DP 11.31 VEP 7.x with various VIs NI Komplete Audio 6 on HP Envy 8G i7 Quad Laptop Win11 MOTU 828es ADA8200 MTP-AV on HP Z2 G4 Xeon Workstation Win11 MOTU M4 on MacBook Air M2 2023 Sonoma.4.1 |
Thanks Chucks,
Awesome help, since I couldn't join the cubase forum :-( I'm gonna try it rightnow. Marcel |
It worked!!!
Thanks so much. Marcel |
Digi002 -> Mackie Universal Control -> Kurzweil pc1x | Dannyboy70 | MIDI | 2 | 12-17-2007 09:46 AM |
Hybrid/Indigo Preset Names: How do you get them back? | Willard | Pro Tools TDM Systems (Mac) | 0 | 07-14-2007 01:04 PM |
Kurzweil K2500X as controller for Protools TDM 5 | roeder | Pro Tools TDM Systems (Mac) | 0 | 10-11-2005 02:13 PM |
Kurzweil PC1X anyone? | pk_hat | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 04-04-2005 10:40 PM |
Preset names | Greene | MIDI | 1 | 02-16-2003 11:06 AM |
