Old 02-08-2005, 10:51 PM
drummerfreak33 drummerfreak33 is offline
Default re install
I have this error problem with loading pro tools. It still loads, but I get all these driver error messages before it finally loads. i was wondering if there is an easy way to uninstall pro tools and re install it again, without like wiping off my whole computer and starting from scratch.
Old 02-08-2005, 10:58 PM
Bastiaan Bastiaan is offline
Default Re: re install
Uninstall ptle, search and delete all instances of "dalwdm.sys", and re-install. Takes about 5 minutes.
What's that?
- That's the machine that goes "pling".
Bastiaan
Old 02-08-2005, 11:44 PM
how do I find all of the dalwdm.sys files? like where are they located? and what are those files?
Also what do I do with my session, audio, and fade files? will they stay in tact?
Old 02-09-2005, 01:01 AM
JMS40 JMS40 is offline
Start > Search > All files and Folders
Insert the file name.
Search your system drive.
High and delete any instances of dalwdm.sys listed.
Old 02-09-2005, 04:50 PM
So I have done that. i went through and deleted pro tools, through the "uninstall software" in the control panel. Than i searched for the dalwdm.sys files. I only found one of those, so i deleted that.
Im wondering about what is left in the digidesign folder. I have my songs of course, so thats good. But there are some pro tools folders like LE Session templates, and one called pro tools. i was wondering, should I delete those before I re install?
thanks
Old 02-09-2005, 04:58 PM
wolfskin wolfskin is offline
Of course, back-up all of your session files. Remove them from your system drive. As a good rule, you should keep all audio files on a dedicated drive. This will GREATLY improve your system performance. Be sure to remove the DAE folder in the 'program files/common files/Digidesign' directory as well.
Windows XP Pro SP3 & Vista Ultimate SP1 / 002R v8.0 w/ MPT2
AMD X2 4800+ Dual Core / 1000 FSB / 4 GB RAM
www.wolfskinrecords.com
www.voodoopilot.com
Old 02-09-2005, 11:20 PM
Be sure NOT to remove that folder. It has all your plugins in it....
What's that?
Bastiaan
Old 02-10-2005, 09:08 AM
ya unfortunately I didnt see your post before I removed it. But its all good. i already reinstalled the plugins. I see all of them when I open pro tools, except for sample tank. Im not sure how to get into that through pt
Mountain Lion/PT Install/Ilok install problems alex obradovic macOS 7 07-14-2013 07:19 PM
First install of Pro Tools 9 - Logic 9 already installed - PlugIn install questions b-pole macOS 2 08-31-2011 08:23 AM
Can't install Pro Tools 8! Clean install, new system, Vista! DJ Hellfire 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 31 01-09-2011 12:16 PM
Can't install Pro Tools LE - Insert disc but no option to install Paul McConnell 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 09-22-2010 09:13 AM
Newb install question: Install seems to complete and than freezes ginsuthaironchef 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 07-02-2009 04:39 PM
