10.3.5 on a Mac; display and PB problems
Mac 10.7.5 - after upgrading to 10.3.5, I'm running into two problems.
Sometimes after recording, a portion of the file viewable on the timeline remains red. Eventually it turns to the proper track color. Today I recorded on one track, edited the file, and consolidated it. It stayed light brown and would not output any sound when "played." I recorded another file on another track and it was fine. I recorded another file on the problem track, edited and consolidated and it was also fine. Wazzup? Ty Ford |
Re: 10.3.5 on a Mac; display and PB problems
Do you have Elastic Audio enabled on the track that is giving you trouble?
Thanks Jonathan, no it's off.
Ty |
Do you have an HD license or the CPTK add-on? If so, is your Disk Cache (Settings-->Playback Engine) set to something other than Normal?
Running native. No add ons that I am aware of.
Thanks, Ty |
Are you recording to an external drive formatted as Mac OS Extended, Journaled?
Hmm,
no, but that's an interesting idea. I do have two external 400 FW drives attached for a separate project. I'll have to see how/if they are being impacted. This is not a constant thing, but just popped up after I went to 10.3 and 10.3.5 Perhaps trashing the non prefs and other files would comb it all out. What teh name of that little app that does that? Thanks, Ty |
It should be in a sticky at the top of the forum.
Problems With Display Need More Help | wolfman_rob | Pro Tools TDM Systems (Mac) | 5 | 12-16-2007 03:49 PM |
Display problems | Scintillaterich | Pro Tools M-Powered (Win) | 3 | 05-22-2007 08:24 AM |
?s to all that have been having display problems.. | Craig F | Pro Tools TDM Systems (Mac) | 0 | 11-11-2004 05:48 PM |
display problems | cutman707 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 05-04-2001 08:21 PM |
DUC Display Problems | Avid | General Discussion | 0 | 09-17-2000 06:35 PM |
