Anyone figure out how t get rid of the static from there MBox 3 mini?I've read a hundered complaints but no solutions some issue with the volume knob.
if you know the answer or a fix I would greatly appreciate it. |
116 views and not one answer.GREEEEAAT!!!!Thanks Protools/Mbox for making my life difficult. Someone has to have figuered out the solution by now. Come On! Someone step up to the plate and help US.
This problem is an design mistake!
You can actually decrease the noise or take it fully away! But for that you need to tear it down, dismantle it! First you need to unscrew all screws from the backside...even the the nut-screw from the monitor outputs needs as well to be taken away On the front you need to pull out the 2 gain knobs, the volume headphone knobs and the big volume knob. Then you need to carefully take away the plastic stands and unscrew those 4 screws. After that you should be able to pull out the whole card...Now look at the volume knob pot...and the cabling is very close to the iron that is holding the front-panel stable...now you understand that the cable is way too close and that gives the crackling of the volume knob. I just took insulation tape and teared it around the iron peg/rod several times.... This helped me! |
Static "Playback" with Protools and Static "Playback" with windows files | 39lashesmedia | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 05-20-2011 05:57 AM |
Nothing but static | RoverRadio | Pro Tools 9 | 5 | 11-14-2010 08:23 PM |
help me ... STATIC | cleavelandjones | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 02-13-2006 06:29 PM |
ok still i have static what can i do | streets | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 06-16-2004 06:32 AM |
!!!Static!!! | Severe | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 16 | 07-02-2002 09:29 AM |
