Multiple redundant playlists when prefroming ADR
Ok so I have a line of dialogue that needs replacing.
Say the actor has 5 attempts at creating a line of dialogue, this results in 5 playlists. Then 2 minutes later they have another line. This time they do it in 3 attempts. Is there any way to not add an extra 3 playlists? I.e. Cant I just use 3 of the 5 I have already created and then comp then on a clip basis? Basically if the maximum amount of attempts they take to do a specific line is say, 8 for example, I only ever want there to be 8 playlists, not an ever increasing number every time they have to do a new line. |
Re: Multiple redundant playlists when prefroming ADR
What I do here is this. Show the playlists. Record each take on the top playlist and simply drag the new clip down to another playlist and keep recording to the one on top If you're worried about placement on the timeline when you move the clip, just highlight it and hit Ctrl-X, move the cursor down to where you want to drop the clip(using the : key) and Ctrl-V to paste.
Im not sure I completely understand. Is there no way to have it not automatically create new playlists everytime?
Preferences/Operation/Recording un check the automatically create new playlist when loop recording.
Ray Trujillo Freelance Audio Engineer |
You started out saying you already had 5 playlists. My method allows you to keep recording, at any place on the timeline, and use the playlists that already exist. If you use Loop-Record with Auto-Playlist creation, every time you loop record a section, you will(AFAIK) get a new batch of playlists created, and before long, you will have dozens(not my idea of fun editing)
So i create 5 playlists. Then I move further on and create 3, then further along again and create 6 and then further along again and create 4 so it should give me: Quote:
You aren't turning off loop recording. It's just not making new playlists.
look on idea scale to see if it's been suggested to change that behavior. I don't split out takes until later using the matching takes function.
It is a PITA to Start(Ctrl)-drag new takes to the lower playlists everytime a new loop recording was done.
PT 11.3.2 HD , RME Fireface 800 , Genelec 5.1 , Win7 64bit Professional , i7 3930 Hexcore , 48GB Ram , SSD System + SSD PT Session/Audio + SSD Video (all Samsung 840 Evo) + Spinner 1TB Data , 2x Radeon HD 5450 \\ SD 633 Femto MKH8060 MKH8070 MKH30/MKH40 DPA4060 Last edited by joachim; 02-07-2014 at 12:11 PM. Reason: wrong dragging :-) |
Can't create/see multiple playlists | TheBaron | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 7 | 03-13-2010 02:55 PM |
multiple automation playlists | jeff markham | Pro Tools TDM Systems (Mac) | 5 | 10-28-2006 06:06 AM |
Multiple playlists at once? | tj_davies | Pro Tools TDM Systems (Mac) | 7 | 09-23-2004 05:09 AM |
Editing Multiple Playlists | pa247 | Tips & Tricks | 3 | 03-27-2004 06:22 PM |
Editing multiple playlists | pa247 | Pro Tools TDM Systems (Mac) | 2 | 03-16-2004 09:34 AM |
