Hello guys,
I had a power surge this week and my motherboard got fried, so now I need to get a replacement. I had an ASUS P5B (See specs here), and I'd love to get back the same motherboard, since my system was running smoothly and I was fine with it. However, I can't find the P5B in stock anywhere, so I'll have to get something similar (Intel socket 775) that will allow me to use all the stuff I had in the P5B (unless you know where I can buy a P5B). Which motherboard do you guys recommend? Here's my pre-power-surge Sandra report (I switched to Win 7 64bit after this report, but I didn't make another one): SiSoftware Sandra Computer Model : System manufacturer System Product Name Workgroup : WORKGROUP Host Name : Jamplified-PC User : Jamplified Processor Model : Intel(R) Core(TM)2 Quad CPU Q6600 @ 2.40GHz Speed : 2.4GHz Cores per Processor : 4 Unit(s) Threads per Core : 1 Unit(s) Type : Quad-Core Integrated Data Cache : 4x 32kB, Synchronous, Write-Thru, 8-way, 64 byte line size L2 On-board Cache : 2x 4MB, ECC, Synchronous, ATC, 16-way, 64 byte line size, 2 threads sharing Computer Mainboard : Asus P5B BIOS : AMI 1102 01/30/2007 Bus(es) : ISA X-Bus PCI PCIe IMB USB FireWire/1394 i2c/SMBus Multi-Processor (MP) Support : No Multi-Processor Advanced PIC (APIC) : Yes Total Memory : 3GB DIMM DDR2 Chipset Model : ASUS P5B Front Side Bus Speed : 4x 267MHz (1GHz) Total Memory : 4GB DIMM DDR2 Channels : 2 Memory Bus Speed : 2x 401MHz (802MHz) Memory Module(s) Memory Module : Kingston 2GB DIMM DDR2 PC2-6400U DDR2-800 (5-6-6-18 3-24-6-3) Memory Module : Kingston 2GB DIMM DDR2 PC2-6400U DDR2-800 (5-6-6-18 3-24-6-3) Video System Video Adapter : NVIDIA GeForce 7300 SE/7200 GS (Microsoft Corporation - WDDM) (2 PS3.0, 2 VS3.0 450MHz, 256MB DDR3 2x675MHz 64-bit, PCIe 1.00 x16) Video Adapter : NVIDIA GeForce 7300 SE/7200 GS (Microsoft Corporation - WDDM) (2 PS3.0, 2 VS3.0 450MHz, 256MB DDR3 2x675MHz 64-bit, PCIe 1.00 x16) Graphics Processor Storage Devices WDC WD3200AAJB-00J3A0 (320GB, ATA133, 3.5", 7200rpm, 8MB Cache) : 298GB (K:) WDC WD1600AAJB-56WRA0 (160GB, ATA100, 3.5", 7200rpm, 8MB Cache) : 149GB (W:) WDC WD800AAJS-00PSA0 (80GB, SATA300, 3.5", 7200rpm, 8MB Cache) : 75GB (C:) WDC WD3200AAKS-00UU3A0 (320GB, SATA300, 3.5", 7200rpm, 16MB Cache) : 298GB (I:) WD 10EAVS External 1TB (USB) : 932GB (B:) TSSTcorp CDDVDW SH-S203D (SATA150, DVD+-RW, CD-RW, 2MB Cache) : N/A (E:) TSSTcorp CDDVDW SH-S203D (SATA150, DVD+-RW, CD-RW, 2MB Cache) : N/A (F:) Logical Storage Devices Jamp Prod (K:) : 298GB (NTFS) @ WDC WD3200AAJB-00J3A0 (320GB, ATA133, 3.5", 7200rpm, 8MB Cache) CLIENT (W:) : 149GB (NTFS) @ WDC WD1600AAJB-56WRA0 (160GB, ATA100, 3.5", 7200rpm, 8MB Cache) Hard Disk (C:) : 75GB (NTFS) @ WDC WD800AAJS-00PSA0 (80GB, SATA300, 3.5", 7200rpm, 8MB Cache) Jamp Rec (I:) : 298GB (NTFS) @ WDC WD3200AAKS-00UU3A0 (320GB, SATA300, 3.5", 7200rpm, 16MB Cache) 1TB BACKUP (B:) : 931GB (FAT32) @ WD 10EAVS External 1TB (USB) Optical Drive (E:) : N/A @ TSSTcorp CDDVDW SH-S203D (SATA150, DVD+-RW, CD-RW, 2MB Cache) Optical Drive (F:) : N/A @ TSSTcorp CDDVDW SH-S203D (SATA150, DVD+-RW, CD-RW, 2MB Cache) Peripherals LPC Hub Controller 1 : ASUS P5B LPC Legacy Controller 1 : Winbond W83627DHG Audio Device : ASUS P5B Audio Codec : Analog Devices 1988h Disk Controller : ASUS 82801H (ICH8) 4 port SATA Controller Disk Controller : ASUS 82801H (ICH8) 2 port SATA Controller Disk Controller : ASUS P5B [JMB363] USB Controller 1 : ASUS P5B USB Controller 2 : ASUS P5B USB Controller 3 : ASUS P5B USB Controller 4 : ASUS P5B USB Controller 5 : ASUS P5B USB Controller 6 : ASUS P5B USB Controller 7 : ASUS P5B FireWire/1394 Controller 1 : Avlab Technology TSB43AB23 1394a-2000 OHCI PHY/link-layer Controller <<<== This is really a SIIG NN-440012 }} SMBus/i2c Controller 1 : Intel 801xx/63xx SMBus Printers and Faxes Printer : Microsoft XPS Document Writer (600x600, Colour) Fax : Microsoft Shared Fax Driver (200x200) Network Services Network Adapter : Realtek RTL8168B/8111B Family PCI-E Gigabit Ethernet NIC (NDIS 6.20) (Ethernet, 100Mbps) Power Management Mains (AC) Line Status : On-Line Operating System Windows System : Microsoft Windows 7 Ultimate 6.01.7600 Platform Compliance : x86 Windows Experience Index Current System : 3.4 **********************
Music Is Life |
It might be hard to find DDR2 boards these days, so you might need to swap the RAM as well. P45 boards are hard to find.
This P45 Giagabyte DDR3 775 board on newegg is the only one I think might work, and I'm not sure how well. http://www.newegg.com/Product/Produc...82E16813128496 If it was me, I'd use the surge as an excuse to upgrade to an i7 for the PT system. Get some super cheap board + 1TB drive + Case for the old 775 and use it as a gaming/HTPC machine. Thats what I did with my old Q6600, only I had no surge ;-0
i7 2600K @ 4.4GHZ -- Intel DP67BG B3 -- 8GB DDR3 1600 -- Crucial SSD PTLE 8.0.4cs2 -- DIGI 003R -- DV toolkit -- Waves 9 |
![]() Quote:
Gigabyte X79/intel i7 3930K, 32GB RAM, HD/Native, 192 IO https://www.facebook.com/search/top/...0sound%20works The better I drink, the more I mix ![]() BTW, my name is Dave, but most people call me.........................Dave |
Thanks guys.
I was really hoping to keep the RAM I already have, but if I must swap them out, then so be it. I was looking at that gigabyte board earlier, and I did a search of the forum, but it didn't show up anywhere... Do any of you guys know of any successful builds with that particular board? Or if not, do you guys have any other board suggestions? I'd hate to be running an experiment with one if there's a board that's proven to be more stable with PT.
Music Is Life |
That board is a newer version Gigabyte made of a P45 775 board. Its unlikely that anyone will post a new build using it since the 775 is dated. If you go ahead with that option you will be the first confirmed build.
OK... Understood.
Do you see any reason why it wouldn't work though?? Forgive me for being cautious... I just REAAALLLY hate dealing with down time and system instability (especially coming from a rock-solid sytem).
Music Is Life |
Oh, and I'm thinking about getting this memory to go with the board you recommended:
G.SKILL Ripjaws Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1333 (PC3 10666) Desktop Memory Model F3-10666CL9D-8GBRL What do you guys think?
Music Is Life |
looks good to me.
![]() Quote:
http://www.amazon.com/gp/offer-listi...&condition=all It uses ddr 2 ram too.
Windows 7 ultimate 64 sp1. intel i5 2500k 3.30 ghz. asus p8p67 evo rev 3. 16g kingston ddr3 1600. Asus engtx 560dc2 oc. Seagate Barracuda 7200 9 SATA 80-GB Hard Drive. 2x WD caviar black 7200 500 GB. 1x WD caviar black 7200 1 TB. Seagate Freeagent 7200 1 TB usb 2.0. SIIG NN-440012-S8. PT 10. SIB 7. ProjectMix I/O. Focusrite Liquid Saffire 56. Focusrite Saffire pro 40. Genelec 8040. Axiom pro 61. Alesis Dm8 pro. Spector ns2000/5. Old vintage Vantage electric guitar. Bunch of VI's and plugins
Thanks guys.
I'll order the board and memory today then. @Nightworker - The board available on Amazon is used. Thanks though. On another note... All this talk about re-building my system got me thinking... I'll use this Core 2 Quad system as my backup system when I get the parts above, and I'll just build a new i7 system to be the main system for my 003 while I'm at this. Here's the thread for the i7 build if you want to help with it: http://duc.avid.com/showthread.php?t=308662 Suggestions appreciated.
Music Is Life |
Motherboard suggestions? (Intel Socket 775 - Asus P5B Replacement) | Fireball71 | Pro Tools HDX & HD Native Systems (Win) | 1 | 09-30-2011 10:19 AM |
Asus M2N Sli or P5Q LGA 775 Intel P45 ATX Intel Motherboard? | pcmusicpro | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 08-07-2008 11:11 PM |
AM2 Socket Asus | georgej | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 12-19-2006 10:53 PM |
478 socket motherboard compatibility | lotecorp | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 17 | 09-29-2005 06:55 PM |
ASUS A7V Socket A VIA Motherboard + Digi 001 - Will It Work? | T-Bird | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 11-18-2000 01:42 AM |
