8.0.4 works great for me in W7 64bit except for 2 persistent problems:
1. I still get the error message "Access violation - no RTTI data!" after processing an AudioSuite plugin. I can hit OK and it will go away and I can work again - but it's very annoying. I have no idea if this is a hardware/Windows/plugin issue?? Seems to happen with all AudioSuite plugins though the main ones I use are Normalize and AutoTune. Anyone ever figure this one out?? ![]() 2. When Bouncing To Disk, if I click anywhere on the screen Pro Tools locks up. I'm not able to cancel the bounce as the screen turns white. I can perform other tasks in Windows, but ProTools is unresponsive until the bounce is completed. I've seen both of these issues posted by other users (and myself) and have never seen a solution. Makes me think it's some Windows or ProTools setting, or maybe something in the BIOS as apparently most users are not experiencing them. Any help would be greatly appreciated!
Help Us Help You Chris __________________________________________________ Focusrite Liquid Saffire 56 FocusritePro 40 (2) TCE Studio Konnekt 48 Rascal Audio Tonebuss 24 Slate Digital VRS8 Gigabyte GA-Z170-HD3P i7 6700K 4.1 GHz 32GB DDR4 macOS 10.15.7 UAD-2 Octo Core PCIe Pro Tools Ultimate 2022.12 |
I have been getting the BTD lockout since 8.0. I think (IMO) that's its because PT takes all functions off line and windows thinks it's unresponsive when you click outside of PT. I would imagine it's a windows thing, but I don't know if Mac users get it or not.
Well it only happens to me in Windows 7 - both of these issues actually. I don't experience these problems in XP.
![]() Quote:
What other software (please be specific with version numbers) do you have installed? Not just music software, ANYthing. That definitely narrows it down. W7 up to date?
![]() Quote:
bassist...deep pocketz anyone???!!! ![]() ![]() The Basschakra Lucid Soul Trip i7 Builds - Specs and Results HDNative | Omni | i7-3930K OC'd 4.0GHZ | ASUS X79 Sabertooth | 32GB GSkill DDR3 2133 ram | mo' stuff |
I'm checking on the installed plugins and software. Do you mean a repair as in going to Uninstall-Repair which reinstalls Pro Tools, or a Windows 7 repair?
yes i'd run a repair on PTLE...via add/remove programs.
Found the culprit of the "No RTTI Data" problem - a program called UltraMon I was using to configure dual monitors. I used it more in XP and don't really need it for Winodws 7. Once I removed it the Access Violations went away - reinstall it and they come back.
Good find!
Maybe DigiTechSupt will add it to the list of incompatibilities for W7? (or maybe not). I will probably use this thread as an example of "other software" being installed that can screw up a Pro Tools install. ![]() ![]()
Has 8.0.4cs2 fixed the response issues with the 003 | converted | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 7 | 10-29-2010 10:36 PM |
Will the FW800 issue/Mbox Pro issues ever be fixed?? | biujee | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 14 | 11-05-2009 01:31 PM |
Cs 2 fixed my graphic issues | zeeman | Pro Tools TDM Systems (Mac) | 0 | 02-25-2009 11:54 AM |
10.4.8 fixed my Mac Pro/PTLE 7.1.1 issues! | acmost | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 10-20-2006 05:04 PM |
Audio volume issues fixed in LE 7.1? | avaldes | Storage Subsystems | 0 | 03-19-2006 06:20 PM |
