Hi. Tried a bunch of stuff mentioned in this forum: Run as Administrator, delete DAE prefs & digidesign databases, tried running firewire as legacy driver, tried running Pro Tools in the "Run programs made for previous versions of Windows" option in the control panel, and the Allowcookies addition in the internet Settings part of the regedit.
The application loads up fine. Even super small sessions load up ok..ones with a couple tracks. Anything more than that, and it crashes and I get this: "Pro Tools Application has stopped working" "A Problem caused the program to stop working correctly..." I also tried creating a blank session and importing all the tracks from a large session individually to try to isolate the problem to a particular plug-in or track, but they all import OK. I had all the tracks from a large session import ok, and could work in and play the session. Then, I save, exit the session, and upon attempting to reload the session, Pro Tools crashes. Any ideas?? using Win 7 Ultimate, PT LE 8.0.3, DIGI003 rack Whole system works beautifully on Windows XP sp1, sp2, & sp3 SiSoftware Sandra Computer Model : MSI MS-7246 Workgroup : WORKGROUP Host Name : Studio-PC User : Studio Processor Model : Intel(R) Core(TM)2 CPU 6300 @ 1.86GHz Speed : 2.21GHz Cores per Processor : 2 Unit(s) Threads per Core : 1 Unit(s) Type : Dual-Core Integrated Data Cache : 2x 32kB, Synchronous, Write-Thru, 8-way, 64 byte line size L2 On-board Cache : 2MB, ECC, Synchronous, ATC, 8-way, 64 byte line size, 2 threads sharing Computer Mainboard : MSI MS-7246 BIOS : Phoenix Technologies, LTD 6.00 PG 11/09/2006 Bus(es) : ISA X-Bus PCI PCIe IMB USB FireWire/1394 i2c/SMBus Multi-Processor (MP) Support : No Multi-Processor Advanced PIC (APIC) : Yes Total Memory : 4GB DIMM DDR2 Chipset Model : MSI 82975X Memory Controller Hub Front Side Bus Speed : 4x 316MHz (1.26GHz) Total Memory : 4GB DIMM DDR2 Memory Bus Speed : 2x 316MHz (632MHz) Memory Module(s) Memory Module : Kingston 1GB DIMM DDR2 PC2-4300U DDR2-534 (4-4-4-12 2-16-4-2) Memory Module : Kingston 1GB DIMM DDR2 PC2-4300U DDR2-534 (4-4-4-12 2-16-4-2) Memory Module : Kingston 1GB DIMM DDR2 PC2-4300U DDR2-534 (4-4-4-12 2-16-4-2) Memory Module : Kingston 1GB DIMM DDR2 PC2-4300U DDR2-534 (4-4-4-12 2-16-4-2) Video System Video Adapter : NVIDIA GeForce 7300 GT (8 PS3.0, 4 VS3.0 351MHz, 256MB DDR3 2x333MHz, PCIe 1.00 x16) Video Adapter : NVIDIA GeForce 7300 GT (8 PS3.0, 4 VS3.0 351MHz, 256MB DDR3 2x333MHz, PCIe 1.00 x16) Graphics Processor Storage Devices sessions A (H:) : 298GB (NTFS) @ Initio WD3200JB-00KFA0 (320GB, FireWire/1394, 3.5", 11568rpm, NCQ, 8MB Cache) ST380815AS (80GB, SATA150, 3.5", NCQ, 8MB Cache) : 75GB (C:) ST3750640A (750.2GB, USB, 3.5") : 699GB (F:) WDC WD3200JB-00KFA0 (320GB, USB/ATA100, 3.5", 7200rpm, 8MB Cache) : 298GB (G:) LITE-ON DVDRW LH-20A1H (ATA66, DVD+-RW, CD-RW, 2MB Cache) : N/A (D:) PIONEER DVD-RW DVR-107D (ATA33, DVD+-RW, CD-RW, 64kB Cache) : N/A (E:) Logical Storage Devices System Reserved : 100MB (NTFS) Vault (F:) : 699GB (NTFS) @ ST3750640A (750.2GB, USB, 3.5") Backup (G:) : 298GB (NTFS) @ WDC WD3200JB-00KFA0 (320GB, USB/ATA100, 3.5", 7200rpm, 8MB Cache) Hard Disk (C:) : 74GB (NTFS) @ ST380815AS (80GB, SATA150, 3.5", NCQ, 8MB Cache) Optical Drive (D:) : N/A @ LITE-ON DVDRW LH-20A1H (ATA66, DVD+-RW, CD-RW, 2MB Cache) Optical Drive (E:) : N/A @ PIONEER DVD-RW DVR-107D (ATA33, DVD+-RW, CD-RW, 64kB Cache) Peripherals LPC Hub Controller 1 : MSI 82801GH (ICH7DH) LPC Interface Controller LPC Legacy Controller 1 : T0 00-00h Audio Device : MSI 82801G (ICH7) High Definition Audio Audio Codec : Realtek Semiconductor High Definition Audio Serial Port(s) : 1 Parallel Port(s) : 1 Disk Controller : MSI 82801G (ICH7) Ultra ATA Storage Controller Disk Controller : MSI 82801GB/GR/GH (ICH7) Serial ATA Storage Controller Disk Controller : MSI JMB361 AHCI/IDE USB Controller 1 : MSI 82801G (ICH7) USB Universal Host Controller USB Controller 2 : MSI 82801G (ICH7) USB Universal Host Controller USB Controller 3 : MSI 82801G (ICH7) USB Universal Host Controller USB Controller 4 : MSI 82801G (ICH7) USB Universal Host Controller USB Controller 5 : MSI 82801G (ICH7) USB 2.0 Enhanced Host Controller USB Controller 6 : VIA VT82xxxxx UHCI USB 1.1 Controller (All VIA Chipsets) USB Controller 7 : VIA VT82xxxxx UHCI USB 1.1 Controller (All VIA Chipsets) USB Controller 8 : VIA VT6202 USB 2.0 Enhanced Host Controller FireWire/1394 Controller 1 : Avlab Technology TSB43AB23 1394a-2000 OHCI PHY/link-layer Controller SMBus/i2c Controller 1 : Intel 801xx/63xx SMBus Printers and Faxes Printer : Microsoft XPS Document Writer (600x600, Colour) Printer : HP Officejet 5600 series (1200x1200, USB, Colour) Fax : Microsoft Shared Fax Driver (200x200) Scanners and Cameras Scanner : Hewlett-Packard HP Officejet 5600 (Scanner, USB) Network Services Network Adapter : Intel(R) PRO/1000 PL Network Connection (Ethernet, 100Mbps) Power Management Mains (AC) Line Status : On-Line Operating System Windows System : Microsoft Windows 7 Ultimate 6.01.7600 Platform Compliance : x64 Windows Experience Index Current System : 4.2 Performance Tips Tip 2546 : Large memory modules should be ECC/Parity. Tip 2 : Double-click tip or press Enter while a tip is selected for more information about the tip. ![]() ![]() |
yes. I thought I would try the 8.0.3 forum first. But since the issue could not be resolved from that forum, maybe someone here in this more general forum will have some different suggestions.
FYI: "Multiple identical postings in the same forum or more than one forum of the same message are not allowed and may be considered spam and removed."
Help Us Help You Chris __________________________________________________ Focusrite Liquid Saffire 56 FocusritePro 40 (2) TCE Studio Konnekt 48 Rascal Audio Tonebuss 24 Slate Digital VRS8 Gigabyte GA-Z170-HD3P i7 6700K 4.1 GHz 32GB DDR4 macOS 10.15.7 UAD-2 Octo Core PCIe Pro Tools Ultimate 2022.12 |
![]() Quote:
Well I get a similar issue although mine seems to be more random.. it can happen just loading PT LE. I'm using the 8.0.4b driver for my 002r... it has happened only 2 times on me.. once with just PT and once with loading a session(which loaded the next time i rebooted). I'm attributing it to the driver being Beta... but i could be wrong...
-AIM: RS Recordings -Skype: RSRecords | Pro Tools 8 Native | Windows 7 64-bit| Q6600 @ 3.0ghz | 8GBs RAM | Digi002r | Studio Site: Red Sneaker Records |
Backup (G:) : 298GB (NTFS) @ WDC WD3200JB-00KFA0 (320GB, USB/ATA100, 3.5", 7200rpm, 8MB Cache) What's with all the USB hard drives, and are you recording to them? They're not recommended OR supported. |
Try uninstalling/reinstalling the 8.0.4b drivers with the unit turned off. Power the pc off, power up the 002/003 then boot up your pc. If that doesn't work, I'd try reinstalling LE.
I have found that repairing the .04 drivers fixed this (at least temporarily) for me. And running as administrator seems to be a must.
~ tom thomas Formerly hobotom Pro Tools Ultimate 2022 HDX HD Omni and 192 I/Os Windows 10 Intel Hexcore i7 All Samsung Pro SSDs Ampex MM1200 2" 24 trk tape Outboard: UREI, Eventide, Lexicon, Yamaha, TC Electronics, Orban, ART, EchoAudio, Dolby, Hughes, API, Neve, Audio Arts, BBE, Aphex, Berringer, MOTU, dbx, Allison, etc. Plug-ins: Too many to talk about. www.metrostudios.com |
protools 11.01 close session crashes on load next session | eddie lamb | Pro Tools 11 | 2 | 09-07-2013 02:51 AM |
Pro Tools LE 8 crashes when trying to load new or existing session | jgerards | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 01-07-2011 09:26 AM |
Analog Factory crashes PT 8cs3 on session load | DrFord | Pro Tools TDM Systems (Mac) | 4 | 09-11-2009 03:29 PM |
pro tools le 7.3.1 cs 5 session load up crashes | streetcorna | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 12-14-2007 07:03 AM |
PT 7.0 crashes when I load a particular session | phentalmyst | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 08-09-2006 12:58 AM |
