Old 09-11-2009, 10:11 AM
Voice Crafters Voice Crafters is offline
Default PT keeps shutting when I open a session
Hi all,
I'm sure this has happened to many of you...
There's that one session that you try to open. Whenever you do, that wonderful "Pro Tools has encountered an error and must shut down" window pops up.
Unfortunately, I forgot to set the "auto backup" option on in my preferences, and this session (which I just finished mixing ) will not open.
Does anyone have any creative solution? other than try to piece all the audio files back together again (which needless to say would be a nightmare)...
Thanks!
Mony
Voice Crafters
www.voicecrafters.com
Audio Buzz
https://www.audiobuzz.com
PT 2019.5
Interface - Focusrite Clarett 8Pre
Mac Mini Running OSX 10.13.5
3.1 GHz Intel Core i7
16 GB 1600 MHz DDR3 RAM
External 4TB OWC drive
Old 09-11-2009, 10:14 AM
danander11 danander11 is offline
Default Re: PT keeps shutting when I open a session
Create a new session and import everything into it from the one that will not open.
Here I am,
after time not long...
and thankful for the break,
What I found when I got there,
was that I couldn't stay away!
Hobo Shave!
Old 09-11-2009, 10:51 AM
Thanks. But do you mean import the audio files and try to reconstruct everything?
Is there any way to salvage the session file?
Voice Crafters
Audio Buzz
PT 2019.5
Old 09-11-2009, 11:20 AM
SeedGuy SeedGuy is offline
You can import session data, which will allow you to import all the tracks with any plugs, automation, sends you have.
Which version of Pro Tools are you using?
Old 09-11-2009, 12:05 PM
I'm using PT 8.0
I try to import session data but I get a message about disk allocation and the the program just hangs.
Can you tell me what you do step by step?
Thanks!
Mony
Voice Crafters
Audio Buzz
PT 2019.5
Old 09-11-2009, 05:14 PM
Never mind. Got it! Thanks very much for the help. It worked!!!
Voice Crafters
Audio Buzz
PT 2019.5
Try holding the SHIFT key while you open the session. That will disable all the plugins(but not delete or change them). If the session now opens, you can go thru and enable plugins(I do one row at a time, holding the Alt key to enable the entire row). The save/close and reopen. If it opens, move on to the next row of plugins. If it does not open with a row enabled, you know that some plugin(used in that row of inserts) is bad/corrupt or outdated.
Old 09-12-2009, 05:21 AM
Well... The session does open when I do that but the plugins are all inactive, not bypassed. There's nothing I can do to get reactivated...
Voice Crafters
Audio Buzz
PT 2019.5
Old 09-12-2009, 11:00 AM
The Weed's Avatar
The Weed The Weed is offline
Ctrl+Start+Click on any disabled plug-in and it should be enabled.
Cheers,
Demos: brucehayward dot com
SonoBus
Source-Connect: brucehayward
Options for Remote Direction
Old 09-12-2009, 01:49 PM
You can also right-click on any plugin and select Make Active(or hold the Alt key and do all tracks, one insert slot/row at a time). This is how I was able to figure out that Waves was causing several sessions to not load(Pro Tools would abruptly close). Turns out I needed an update.
One Session Is Shutting down After each record pass..Why? As Is 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 03-13-2008 06:00 PM
session shutting down PT queenstonmusic 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 09-30-2007 05:45 PM
Shutting down PTLE with no session open... max cooper 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 11-03-2005 06:11 PM
Computer Shutting Down When I try to open PT phdlowlife 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 04-16-2005 04:22 PM
Keyboard keeps shutting down during session curve666 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 03-28-2004 04:48 PM
