Does LE and Maudio LE use the same driver
Anyonw know if Maudio ProTools uses the DAE Driver?
Re: Does LE and Maudio LE use the same driver
All ProTools versions use DAE. PTLE has drivers that support Mboxes and 002s, MPowered has drivers that support M-Audio hardware. MPowered software is licenced through the iLok (same as HD) while LE is still using a registration code for licensing.
Is there something in particular you want to know? If you're wondering if M-Audio hardware will work with PTLE, it won't. |
No i was wondering if you could have Le for a 002, and the maudio version both installed on the same partition and system?
And all Digi need to do to make 001 still in the game is to let the DAE support 001 HW. And PT >> 6.4 would be reality.
Digi 002 Mbox 1 Digi001 (retired to shelf) Asus P5K Premium v3, Q6600, 2x2GB Corsair Tyan Thunder n3600B (S2927A2NRF) 2xAMD OPTERON 2214 2.2GHZ Win XP Pro SP3 |
Agentmo,
You can't have LE and M-Powered installed on the same system as far as I know - I imagine the DAE would get pretty mussed up. Might be a good question to ask digi directly though if you really need a solid answer. |
You must have separate partitions for an M-powerd install and a LE install. (for example.. if you try to install the M-powered demo on your LE partition, the software installer app is smart enough to recognize there is an existing PTLE DAE there and will not install) But you can have both devices plugged in when active in one or the other partition without a problem. If you wanted to run both apps at the same time, you would need to have two computers and likely link the M-powered mix over the 002 via SPDIF or other.. (also a KVM switch to switch your control between the two computers) Ive heard it being done this way, ive not done it myself.
17" MBP i7, 4GB RAM, Profire 2626, PT-MP 8 |
unable to uninstall maudio 6.0.6 driver | jrmusic | Pro Tools SE and Essential (Win) | 0 | 09-19-2012 03:39 PM |
New PT10 User. MBox3, MAudio Fast Track Ultra, MAudio Fast Track 8R? | epu | Pro Tools 10 | 3 | 06-13-2012 03:55 PM |
From V8 Maudio to V8 HD | Ianneve | Pro Tools TDM Systems (Win) | 0 | 07-18-2009 06:05 PM |
Maudio Driver Question | Agentemo1 | Pro Tools M-Powered (Mac) | 2 | 11-16-2005 08:21 PM |
Does LE and Maudio LE use the same driver | Agentemo1 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 11-16-2005 10:30 AM |
