Moving volume automation on separate clips
I've looked around a lot and as far as I can tell there is no way to do this but it seems like you should be able to. I'd like to select multiple clips on the same track, but clips that are unattached. I can do this with the grabber object tool. Then I would like to lower the volume automation (or volume trim) on those selected clips only, because, I want to copy that move and paste it onto another track's volume automation. Is there anyway to do that? I know you can gain with audio suite and I know you can move clip gain up or down but I need to move multiple clips volume automation. Is that possible?
Re: Moving volume automation on separate clips
maybe :
track view to volume trim select all unattached clips lower volume trim add volume trim to volume automation (i think right clicking track name menu) track view of both tracks to volume copy volume automation on the one track, paste it to the other
PT 11.3.2 HD , RME Fireface 800 , Genelec 5.1 , Win7 64bit Professional , i7 3930 Hexcore , 48GB Ram , SSD System + SSD PT Session/Audio + SSD Video (all Samsung 840 Evo) + Spinner 1TB Data , 2x Radeon HD 5450 \\ SD 633 Femto MKH8060 MKH8070 MKH30/MKH40 DPA4060 |
nice try but that doesn't work. The issue is that once you select all separate clips with the object grabber you can shift volume in the clips (or volume trim) without all the highlighted clips being joined. There has to be a way..
You want to make a selection of unattached clips (that means clips with silence inbetween) and than just lower the volume within the boundaries of the clips and no volume change in the space between the clips ?
correct...
Then , right now, I can only think of :
track view volume trim select first clip - lower volume trim - C (copy) Ctrl+Tab (next clip selected) - Cmd+Alt+V (repeat to fill) , Cmd+Alt+T (thin automation) Ctrl+Tab (next clip selected) - Cmd+Alt+V (repeat to fill) , Cmd+Alt+T (thin automation) and so on. Right-click track name - add trim automation select first to last clip - track view volume - C (copy) paste to the other track Not at once, but pretty quick.
Right. I'll try it and get back... thanks for the suggestion.
Separate volume automation for each playlist? | sssonic | Pro Tools 9 | 8 | 03-31-2016 12:37 AM |
Moving clips when in Volume Track View ... | ptfigg | macOS | 5 | 02-28-2014 08:03 AM |
PT11 loses automation when moving clips | Frank Kruse | Pro Tools 11 | 4 | 02-20-2014 12:54 PM |
Moving all of volume automation | PSimpso | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 10 | 04-30-2009 06:40 PM |
Full scale volume when moving clips | Frank Kruse | Post - Surround - Video | 7 | 05-15-2008 03:49 AM |
