Go Back   Avid Pro Audio Community > Pro Tools Software > Pro Tools 2021
  #21
Old 04-26-2021, 12:55 PM
Wolfgang Eller Wolfgang Eller is offline
Default Re: PT mixer headroom severely reduced to 20dB over 0dBFS. Bug?
If a freak is doing an accident like this it's worth to ruin his work.
www.srs-mastering.de
Mac Pro 6.1-8core, OS 10.15, PT2021, HDX2, Sonnet Echo Express III-R, Madi Interface.
  #22
Old 04-26-2021, 04:35 PM
Top Jimmy's Avatar
Another facet of this issue is that if you import a floating point file with audio above +20dBFS, you cannot use the Audiosuite Gain plugin to decrease the gain of the file. Using AS Gain results in a permanently distorted file.
James Cadwallader
Hackintosh - Gigabyte Z77X-UP5TH, Intel Core i7-3770K, 32GB 1600Mhz DDR3, 2x SATA 6Gb/s 240GB SSD, 3x SATA 6Gb/s 1TB HDD, 1x Glyph 2TB USB3 HDD, Mojave 10.14.6.
Pro Tools Ultimate 2021.3, HD Native, Focusrite Red 8Pre (Mac)
Pro Tools 2020.12, Mbox3 (Win)
  #23
Old 04-26-2021, 11:32 PM
XJENSEN XJENSEN is offline
Yes, these floating point issues with AS gain are known to Avid. I have already reported them way back. Correct and consistent audio processing doesn't seem a priority for Pro Tools.
  #24
Old 04-27-2021, 01:33 AM
Whilst I'm in agreement with the posts that say, "Why would you need to push the level that hard?", the fact that this is yet another aspect of the software that's broken for no apparent reason is really, really depressing. It doesn't inspire confidence that other critical things won't get broken down the line.
  #25
Old 04-27-2021, 10:32 PM
seanmccoy seanmccoy is offline
For post projects I have on several occasions needed to add over 20 dB of gain to ultra-soft field recordings. So this is a potential issue on a practical level.
ADK Core i7 4.20, 32GB RAM, W10 Pro, PT HD 2021.6.1, HD Native, OMNI, Digi 192, AJA Kona LHi, UAD-2 Octo; Mac Pro 12-core 3.46, 64GB RAM, Mojave, Logic Pro 10.5.1, Apogee Rosetta 800, UAD-2 Quad, MOTU 2408 Mk II: MBP mid-2012, 16GB RAM, Mojave, MOTU 8-Pre-ES, Pro Tools 2021.3.1
  #26
Old 04-28-2021, 01:32 AM
An ultra-soft field recording is not leveled at 0dbfs.
The problem is if you gain a file 20db over 0dbfs.
  #27
Old 04-28-2021, 07:06 AM
Hi Sean - the issue is not adding 20dB or more of gain to something - that of course is fine - if it wasn't the world would spin off its axis. The issue occurs when gaining a clip up more than 20dB *over* full scale - the floating point engine should be able to recover signals *hundreds* of dB over "full scale" without clipping, but something weird is going on. Admittedly an edge-case, but still seems like an odd bug.
http://www.richbreen.com
MacPro 5,1 Dual Hex, OS 10.14, PT 2021.3 HDX, Avid HD I/Os and Metric Halo ULN8, Avid C24, 3xS1/Dock.
Also running a 2013 nMP / HDX / S6
  #28
Old 04-28-2021, 10:05 AM
Hey, Rich, good to know. Now can somebody tell me when one might need 20dB over full scale? Talk baby talk.
  #29
Old 04-28-2021, 11:07 AM
daeron80 daeron80 is offline
Apparently, some of us work only on audio we produced ourselves. But others of us receive wildly horrendous audio from clients, and sometimes have to finish jobs in a massive hurry due to circumstances beyond our control. The floating point engine is there (in part) to handle things when things get crazy. It's broken, and it needs to be fixed.
David J. Finnamore
Nyquist was right.
PT 2021.6 Ultimate | Omni | macOS Catalina in a Trashcan 32GB
PT 2021.6 | Saffire Pro 40 | Win10 latest, HP Z440 64GB
  #30
Old 04-28-2021, 11:56 AM
But still, why is there any need to gain a file 20db above 0dbfs?
Any 32bit float file I get from a client I convert it by import into a 24bit fixed.
For me there is no reason for using 32 float.
I have learned to use gain structure.
Avid reports severely disappointing 3rd quarter peter5992 General Discussion 11 10-31-2012 01:34 PM
Phase invert and -10/20db pad? Pherson ICON & C|24 2 09-17-2008 12:49 PM
Peaking above 0dBFS rems 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 08-16-2005 01:06 PM
OSX - 001 crashing and severely distorting Brian West 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 07-04-2003 08:40 AM
5.1 - really severely uncool region bug destruktobot MIDI 0 07-28-2001 04:32 PM
