Re: Why does my iLok software have to up to date to run Pro Tools 2018?
You make excellent points, I would be equally upset.
15 years as PTHD User, Protools 2018 Ultimate, 24 Channel iCon D-Command, Avid Omni, Lynx Aurora 16, (2) BLA Modified 192 I/O’s, DigiPre, Way Too Many Outboard Compressors/EQ’s/ETC, where did all my money go???? |
Come again?!?! You're saying that ProTools has quit in the middle of a session because it needed iLok software to be updated? I've never in my life experienced that, even now with 2018.x.
And you are adding value here how? I am pretty fed up with your whiney special child attitude and having to tiptoe around answering your questions on DUC. And when I help you you say nothing but occasionally if you are misunderstanding something you refuse to listen and carry on like a petulant child.... like this post. Are you a teenager? God know how you get on with people in a work environment. Sent from my iPhone using Tapatalk |
The iLok technology as used by Pro Tools in recent releases is *not* just an iLok dongle that the application software directly interfaces with. The ILM package is both the application you see and driver technology that goes between the iLok and the application. It had had the ability through the ILM to remote revoke licenses, to automatically update license, and I would expect to do other anti-piracy things that I won't speculate on publicly. Some of that likely requires the ILM to be up to minimal revisions at certain times. There has been points in time in the past where minimal ILM versions were required for Pro Tools, like the transition to iLok 2 with Pro Tools. It may have been less visible in some cases by the ILM updates being bundled with Pro Tools. And you may find some of the other software you use does actually have minimal revisions of ILM, even if the vendors don't always explain it clearly, e.g. in the past SoundToys has certainly required ILM updates to work correctly. I understand you are upset, but my point is Avid is all-in with Pace/iLok licensing and the ILM and updates are therefore an integral part of their system. I am not defending that or saying they are right, but it is how it is, and they seem very committed to and dependent in the whole suite of Pace/iLok capabilities. Older software or other vendors may not be using those licensing features and their software therefore behaves differently with the ILM. Avid has made that commitment to Pace/iLok and likely need to do what they are doing if they want to securely support cloud licenses, rental licenses, have additional anti-piracy protection etc. I just expect complaining about the need for an up to date ILM which is central to these modern capabilities won't get you far. On the other hand if the ILM update is messing up a running session, that is *awful*. Its a bug that should be fixed and I want to encourage you to report it as so, to separate that issue from your other frustration about ILM... in the chance that it will then get attention and get fixed. You might get maximum attention on the messing with a session issue by asking if other users have seem that behavior... I personally have never. But if others have I expect everybody here will be wanting to see that bug fixed asap. Sent from my iPhone using Tapatalk |
What happens is it randomly decides ILM needs to be updated. It then prompts you to save the session or quit. When you press save it saves and just quits. Then you cannot relaunch Pro Tools until you update ILM.
www.HellfireBeats.com UAD 2 Apollo Quad w/Thunderbolt 3, UAD 2 Satellite Octo TB3, UAD 2 Octo PCIe, Avid S1, Neve R6 500 Chasis, Neve Portico 511, Neve Portico 551, Dangerous DBox+, Focal Trio6 Be, Neumann TLM49, Akai MPC 2000XL, Akai MPC X, Mackie 1202VLZ Pro, Akai Advance 61 Pro Tools 2021.12 Mac Pro 7,1 2019, 8 Core, 48GB RAM - MacOS 11.6.2 16" MacBook Pro 2021, M1 Pro, 16GB RAM - MacOS 12.1 27" iMac, Late-2012, 3.4GHz i7, 24GB RAM - MacOS 10.15 |
Anyway, I don’t actually expect them to change this. I just want to complain about it.
What version of iLok were you running before it shut down? Was it several versions out-of-date, like from years ago?
I've never had this happen before. I don't necessarily rush to update iLok when there is a new version, but I do get around to it within a few weeks or months. If PT 2018 did this to a relatively recent version of iLok, I would agree that this is inappropriate. |
Curious as well what version you had installed at the time. Any chance you can share the exact dialog text or a screenshot? There was a change back in August 2017 which was noted in Tech Alerts, in the KB, and on iLok.com that required an iLok update, so can look into this to see if there was something similar for 2018 versions.
So when I first made this thread, I had the first version of ILM that introduced cloud licensing. When I resurrected this thread the other day, I had the prior version installed to the most recent. Now I have the most recent. So when pro tools gives me this error, I’m always only one version behind. Didn’t take a screenshot tho. I will next time.
Seems like when a new version of ILM releases, the previous version eventually expires. I got this error on 6/11. The most current ILM released on 5/29. So it seems it expires after about 2 weeks, which is ridiculous.
I suspect it would have taken less time to simply install the iLok software update than to type several rants.
PT 2018.1 iLok weirdness | PMF Media | Licensing & Accounts | 7 | 01-31-2018 03:16 PM |
Expiration date of Pro Tools Plan doesn't match deposit date | retroandm | Licensing & Accounts | 2 | 01-04-2016 09:05 PM |
Pro Tools 10 says my software is up to date when it isn't | ryanstewartguitar | macOS | 4 | 04-20-2012 03:35 AM |
ilok detected on ilok.com but not with pro-tools software | emergems | Pro Tools M-Powered (Win) | 5 | 12-27-2010 10:36 AM |
Pro Tools 6.0 Software release date ? | Seller | Pro Tools TDM Systems (Mac) | 3 | 10-05-2002 09:42 AM |
