Error message when i try to record. "track could not be record-enables...."
Okay so i just upgraded to PT 10 from 9. I also just upgraded to the Mbox pro 3. Im trying to recored a track on it and when i go to activate the track to recored it comes up with the error message "the track could not be recored-eneabled because it doesn't have both an active input and output assigned." HELP! What do i do to get it to work iv been trying to figure it out for hours. I tried to change the output in playback engine. and messed with stuff in the I/O. . Can someone give me some steps on how to fix it or something.
Pro Tools 10 MBox Pro 3 IMac OS X 10.7.2 2.7 GHz Intel Core i5 4Gb Ram |
Re: Error message when i try to record. "track could not be record-enables...."
Your audio track should output to main and your main should output to 1/2....this is a default setting.
Your audio track input should be the MBox inputs, 1/2 for stereo and L or R for mono. Is this what you see?
Sam |
where are these settings?
I Got it to work now! thanks so much!
Error message when i try to record. "track could not be record-enables...." | znera143 | macOS | 2 | 01-02-2012 07:41 PM |
Pro Tools error message "Session must be an audio record volume" | DeejayMaurice | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 8 | 09-10-2011 06:42 AM |
Can't Save, I get "Audio Record Volume Message" | elijahtrotsky | General Discussion | 1 | 03-10-2009 08:44 AM |
"Track" as a synonym for "record" | John Link | General Discussion | 2 | 08-19-2002 11:54 PM |
Trying to Record into PT, but getting "Fractured" message | AdrianGray | Digidesign Hardware & Software | 2 | 04-04-2002 11:16 AM |
