protools crashing on startup help please
I need some help. I am running 10.3.5, I know it's not qualified, BUT, all was working fine until I upgraded to the latest core audio driver. Now PT crashes upon launch and goes to the dreaded half dark monitor with the multi language warning about restarting your computer. I have read a couple of threads that say to downgrade my os, but does anyone know of an easier fix. I'll thank you all in advance.
the audioczar dual 1.2 1 gig ram oo2 rack 10.3.5 pt 6.4 |
Re: protools crashing on startup help please
It's one thing for Pro Tools to crash, but the very worst that should happen is that you get a message saying "The Application 'Pro Tools' has unexpectedly quit" If you are seeing a kernel panic, then there is something else evil lurking - that is not just due to Pro Tools. For example, I have a "Sawtooth" AGP 400 MHz G4 tower. I added a dual-500 MHz G4 processor upgrade. Initially I used to get kernel panics from time to time; I made sure the new CPU daughter card was seated properly, and the heat sink put on correctly, and have never seen the problem again (touch wood). Not sure that helps you much, but the bottom line is that if your system is healthy (HW and OS wise), you absolutely shouldn't see any kernel panic due to anything Pro Tools alone could be responsible for. Mark
iMac G5 2.1Hz /1.5 GB Ram OS X 10.4.10 MBox/PT LE 7.4 Reason 3.0.4 MOTU 828 Logic Express 8.0.0 Garage Band 4.1 |
Thanks for the help. I removed all external drives and unplugged and reninstalled all ram. Still no luck. But, after five minutes on the phone with Digi Support it turns out that a simple uninstall reinstall of Protools was all I needed to do. This board is always a great help and I appreciate it.
theaudioczar |
I am having the same problem, except that I uninstalled and reinstalled repeatedly with no success. There is no error message beforehand, just -wham- (kernel panick?)! So I checked my other programs, and I could load Logic and Peak with no problem, but not Digital Performer or Ableton Live (which came in a bundle with PT LE). So I uninstalled and reinstalled DP and again got a kernel panick; then removed and reloaded Live, and that one worked out. I was backing up my HD to reset to factory, but I haven't seen my Panther disks since I moved and figured I'd ask the board before downgrading.
Before this happened, I made no new additions to my computer, hardware or software, no upgrades. Just one day... Mac PowerBook G4 12", 384 MB memory, OS 10.3.5. Mbox, PT LE 6.1 Thanks so much!!! Montara |
Maybe you should upgrade PT to 6.4 rather than down-grading!As far as i know the combo of 6.4 on 10.3.5 isnt/hasnt been officially supported, but neither has 6.1 with 10.3.5!Give it a go & see if it works
I had to reinstall the old core driver.
ProTools 9 Keeps Crashing On Startup | rastro2 | Pro Tools 9 | 0 | 02-20-2014 01:17 PM |
Please Help!!! Protools 9.02 keep crashing during startup!!!!! | jothedrummer | macOS | 1 | 08-10-2011 07:34 PM |
Protools 9 crashing on startup | greenwall | macOS | 3 | 08-03-2011 12:28 AM |
Protools 6.4.1 Crashing at startup | thecave | Tips & Tricks | 2 | 11-10-2009 10:35 AM |
PT LE Crashing on Startup | beggehorn | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 6 | 05-18-2006 09:18 AM |
