Old 11-20-2014, 06:57 AM
force76 force76 is offline
Default Save Copy as without Audio Files
For some reason whenever I create a session in Pro Tools 11 and save copy as "Pro Tools 5-9" it automatically checks off the items to copy audio files box and I can't unselect it. I just need the .ptf session file so I can open up the session at work on Pro Tools 8. I use to be able to do this in the past but for some reason I can't do it now.
Old 11-20-2014, 07:12 AM
Drew Mazurek's Avatar
Default Re: Save Copy as without Audio Files
Likely caused by interleaved stereo files or 32bit float files that aren't supported in earlier versions of PT.
www.drewmazurek.com
Old 11-20-2014, 07:51 AM
Thanks for the reply. Is there any work around for that issue?
Old 11-20-2014, 09:06 AM
Yes, don't record at 32bit and don't use interleaved files.
www.drewmazurek.com
Save Copy in not copying all files Robert Jackson macOS 2 04-24-2013 03:26 PM
Save Copy In not copying all files viaspiaggia macOS 2 11-21-2011 12:47 PM
even a save session copy in wont find audio files tsd 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 12-20-2005 10:25 AM
Is anyone doing "save a copy in with files" in 5.1 tomcat Pro Tools TDM Systems (Mac) 2 03-19-2001 05:00 AM
Save Session copy w/audio files (invalid sample rate error) Farmer Dave Pro Tools TDM Systems (Mac) 1 02-16-2000 04:48 PM
