Old 11-19-2023, 08:36 AM
ViciousLullabyz ViciousLullabyz is offline
Default Pro Tools 2023.12 Integrated Renderer Issue
Keeping it brief and hoping for a quick fix:
At AES NY 2023 we got to see a preview of the new version of Pro Tools (advertised as 2023.12) with the new integrated Dolby Atmos Renderer.
For some reason, this renderer only supports 7.1.4 OR 9.1.6 layouts, but NOT 9.1.4.
I've calibrated dozens of rooms for Dolby here in Europe and a large number of those studios (especially for Atmos Music) have 9.1.4 setups, since the Wides make a big difference.
I know there probably won't be a chance for this to make it into 2023.12, but is there a possibility to fix this for 2024.03 or something please?
Should I submit a separate bug report?
Thank you!
Old 11-19-2023, 09:06 AM
JCBigler's Avatar
JCBigler JCBigler is offline
Default Re: Pro Tools 2023.12 Integrated Renderer Issue
Those studios should just add two more height speakers. Problem solved!
Justice C. Bigler
www.justicebigler.com
Lenovo P50: quad-core i7-6820hq, 64GB, 2TB SSD, Win 10 Pro / Protools Ultimate 2023.6 / HD|Native-TB
2018 MacBook Pro: six-core i9, 32GB, 1TB, Monterey / Protools Studio 2023.6, / DVS / DAR, L-ISA Studio
Home/mobile: Focusrite Red 8Pre+HD32R / Clarett 4Pre
Road/hotel: Roland OctaCaputre / Apogee One
Old 11-20-2023, 12:08 AM
Not really needed and/or wanted to create or experience enveloping music mixes and playback.
Having the flexibility to enjoy all speaker formats for Atmos UP to 9.1.6 in PT Ultimate would be appreciated and (to be quite honest) expected.
Old 11-20-2023, 12:35 AM
BScout BScout is offline
You want to submit a "bug report" on something not released and you aren't even a beta tester? Not to mention, isn't a "bug" at all?
Might want to reconsider how things work.
They've already mentioned the integrated renderer will not replace an external renderer. That answers your worries.
Pro Tools Ult 2024.10.2, HDX 2, MTRX/SPQ, SyncHD, DNxiQ, RME BBF Pro + MADIface ProS1 x 2, Fire Max11 x 2, Dock, iPad Air5 Mac Mini 14,12, 12 core, macOS 14.7.2RAM 32GB, SSD 4TB, GPU 19 coreQNAP TVS-872XT 148TB TB3
Old 11-20-2023, 12:46 AM
This does in fact not answer my worries, no, but thanks for your enthusiasm.
I'm not looking to replace the external renderer and I'm well aware of the fact that the integrated one is not aimed to be a full replacement.
Since 9.1.4 is already a supported format in PT Ultimate for auxes and busses, would you consider that a bug to be fixed by your 'logic' then?
Having the same formats that are already available in PT for bussing also available as outputs seems reasonable to me.
Bringing back the ability to work on HDX/HD Native without Aux I/O is one of the major benefits of having an integrated renderer, so flexibilty in speaker configs does play a role in that.
And it not being released shouldn't stop us from talking about it early, since that hopefully gets it into a development pipeline sooner rather than later.
Old 11-20-2023, 12:50 PM
Since 9.1.4 is already a supported format in PT Ultimate for auxes and busses, would you consider that a bug to be fixed by your 'logic' then?.
No. That is not a bug. A feature you want that isn't there is never a bug.
It's a feature request.
Old 11-21-2023, 12:26 AM
Fair enough. So, if we can get past the semantics, we can agree that having 9.1.4 as a direct output format in PT Ultimate but not via the Integrated Renderer is definitely an oversight in need of correction, right?
Old 11-21-2023, 02:51 AM
LDS LDS is offline
The integrated renderers have always had limitations compared to the standalone renderer applications. From memory, while Logic Pro, Da Vinci Resolve and Nuendo all support larger bus widths internally (9.1.4, 9.1.6, etc), they all top out at 7.1.4 speaker layouts.
The 9.1.4 busses in Nuendo don't even work with Atmos. Those extra two channels are left center, and right center screen channels, not atmos wides.
A lot of this stuff won't be up to Avid. It gets dictated by Dolby.
Pro Tools Ultimate 2024.6. OSX 13.6.6. Win 10. Avid Carbon. Lynx AES16e. i9-13900KF. ASRock Z690 Steel Legend. 64GB Ram. AMD Vega 64. BM Decklink. Dolby Atmos Renderer 5.2. Trinnov D-Mon. D-Command.
Old 11-21-2023, 04:28 AM
That's true, yes, the others so far were limited to 7.1.4 speaker layouts.
I just found it odd to support up to 9.1.6 now, but skip the step in between.
And the speaker positions for 9.1.4/9.1.6 bussing in PT are definitely already using the Wides, not Lc/Rc.
2023.6 Pro Tools Ultimate with Dolby Renderer 5 bounce error PhiltheGreek1 Pro Tools 20 11-30-2023 11:09 AM
Pro Tools Studio 2023.6 freezes and cause force shutdown (not CPU issue) antony.chourot macOS 7 08-12-2023 03:29 PM
Pro Tools 2023.3 - UI/Clip Zoom/Waveform Centerline Issue ZoaSoundworks Pro Tools 4 04-15-2023 07:03 AM
Pro Tools 2023.3 - Macro Issue ZoaSoundworks Pro Tools 1 04-13-2023 11:49 AM
Integrated Atmos renderer JanuS Post - Surround - Video 3 03-14-2022 04:33 PM
