Old 04-06-2013, 08:06 AM
bryced87 bryced87 is offline
Default Mbox2 cutting in and out
Hello
I got the Mbox2 back in 2005 so this might be that the Mbox2 is failing but just wanted to make sure. Recently over the past few weeks my Mbox2 will cutout on both my monitors as well as the headphone output. I've tried a different USB cable (which connects the Mbox2 to my computer) thinking that was the problem but it still is cutting out. I've never had it cutout while using Pro Tools only other applications which is weird. I run my Mbox2 output for YouTube Final Cut and iTunes and just recently It's been cutting out. The only way to fix it is if I disconnect the USB cable from the Mbox2 and plug it back in. It will work for another 15 minutes that cut out again. I have to constantly disconnect the USB cable and reconnect for it to work. I am running Mountain Lion but don't see how this could cause it as I've had Mountain Lion for about 6 or 7 months.
Macbook Pro
Mac OS 10.10.3
Mbox 2,
Pro Tools 11
Old 04-06-2013, 01:42 PM
Default Re: Mbox2 cutting in and out
Anyone know????
Macbook Pro
Mac OS 10.10.3
Mbox 2,
Pro Tools 11
Old 04-06-2013, 05:55 PM
Meads Meads is offline
When there's a cutout, do the LEDs on the MBox go off?
Are you using a USB-hub? Do you have several other bus powered stuff hooked up at the same time? Have you tried another USB port on your computer?
Post more information.
http://duc.avid.com/showthread.php?t=193636
iMac Pro
- MacOS 10.14.6
- Pro Tools U HDN 2019.6
- Avid HD Omni + HD I/O 8x8x8
- C|24 | S3 | Dock
Old 04-07-2013, 09:40 PM
I have a USB hub. it's a7 port USB hub. Is that the problem?
The LED lights don't cut out
Macbook Pro
Mac OS 10.10.3
Mbox 2,
Pro Tools 11
Old 04-08-2013, 04:53 PM
bigfootjim bigfootjim is offline
I am having the same problem. I'm using ProTools 10 with the latest updates on a MacBook Pro running Mountain Lion 10.8.3 When I close down ANY audio program and open another Audio Program the 2 lights on the MBox 2 input channels go out and I loose all audio. (The USB Light on the MBox 2 stays on) The only way to get it back is to reboot. I have the MBox selected in my System Preferences as my Audio Device for input and output. Any ideas?
Old 04-12-2013, 01:47 PM
It's happening on Pro Tools 10 as well? My lights never go out. I used to have an older USB hub and it never happened until I bought the 7 port USB Hub. It doesn't happen in Pro Tools as much as it happens when watching YouTube or listening using iTunes.
Macbook Pro
Mac OS 10.10.3
Mbox 2,
Pro Tools 11
Old 04-12-2013, 02:06 PM
Do not connect the MBox to a hub.
iMac Pro
- MacOS 10.14.6
- C|24 | S3 | Dock
First Measure Cutting Off eklektos 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 11-03-2008 01:18 PM
Busses cutting out! Shanegrla 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 8 10-10-2008 05:17 PM
Control 24 Cutting Out?1? zerodb ICON & C|24 2 01-16-2003 07:58 AM
Cutting a hot CD out of PT!? nemisis63 Pro Tools TDM Systems (Mac) 9 07-04-2002 10:34 AM
need help cutting the bull... Chamber Muse 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 06-23-2000 10:27 AM
