Old 02-04-2005, 06:31 AM
fm_xtk fm_xtk is offline
Default Sync I/O Varispeed not working
Hi everybody,
I am having trouble with the varispeed on a client's rig: (G4 DP1.25/1.25GB RAM/OS10.3.4/HD3 Accel/3X192/Nanosync)
When activating varispeed in the session setup window, moving the slider doesn't change the playback speed.
The Sync I/O is set to Internal/VSO (locked LED on front comes on) and I can move the slider but nothing happens. I have trashed the preferences to no avail. I also deselected/reselected the Sync I/O in the peripherals dialogue without any luck.
Any help appreciated
2x Hackintosh X79
HD7 Accel PCIe, Magma EB7 chassis
PT 10.3.10 Mac OS 10.9.5
SSL Delta Link HD 160 I/O
COCKOS REAPER (latest)
RME MADIFX (192 I/O)
ProControl (32 channel)
Old 02-04-2005, 11:11 AM
Tweakhead Tweakhead is online now
Default Re: Sync I/O Varispeed not working
Remove the nanosync until you are finished varispeeding.
Old 02-04-2005, 12:26 PM
I did. Switched it off. Didn't make a difference, unfortunately.
2x Hackintosh X79
Old 02-04-2005, 01:15 PM
Check your loop sync cables.. seems like they're not working right to me.
Rail
Platinum Samples
www.platinumsamples.com
Engineered Drums for BFD
Old 02-04-2005, 01:32 PM
You were right, thanks - it was the clocking.
We did have a faulty D to A card replaced and our maintenance engineer hooked the top 192 up to 256X clock i/p rather than loop sync........
stupid me for not double checking
2x Hackintosh X79
SYNC HD Not Working Epik Productions Pro Tools TDM Systems (Mac) 2 02-12-2024 03:16 PM
Sync not working Nathan W. Pro Tools TDM Systems (Mac) 1 06-08-2011 03:15 PM
Varispeed Not Working Fansplastic Pro Tools TDM Systems (Mac) 7 03-21-2005 12:13 PM
Is 9 pin working from the Sync I/O? John McDaniel Post - Surround - Video 1 05-28-2002 08:32 AM
Sync I/O not working with Mix Plus! johnnyv Pro Tools TDM Systems (Mac) 8 05-08-2002 09:23 AM
