PC to show trax names in Flip mode
On the PC Main Unit and Fader Packs, is there any other way to see the trax names while in the FLIP mode without having to continue to press down the DISPLAY MODE button? This is extremely irritating!!
Can the DISPLAY MODE button somehow be Latched On while in the FLIP mode and then automatically be Latched Off when you exit the FLIP mode? Digi....please support us PC users. |
Re: PC to show trax names in Flip mode
Am I the only ProControl user that uses the FLIP the mode. Or is MY procontrol the only unit that forces you to have to continue to hold down the DISPLAY BUTTON to view the track names?
If nobody else is sees this as a problem...then tell me....when you put ProControl in the FLIP mode and your session is quite large(say,48 traxs) causing you to have to scroll through lots of channels to locate particular send levels, how are you able keep up with what channel your on without having to use both hands---Right Hand to scroll through the channels and the Left Hand to hold down the DISPLAY BUTTON. If the DISPLAY BUTTON could be Latched ON, then the engineer could work more efficiently...Right Hand could scroll through the channels while the Left hand could immediately adjust the Aux send level via channel fader. If DISPLAY BUTTON could somehow be latched ON, then it might be wise to make the DISPLAY BUTTON blink -- (better yet, change the green bulb to RED ie Mackie-type Rude Solo button) as a reminder that Procontrol is in FLIP mode. |
I'm with ya on this one,no idea if there's a solution ... hope so.If not big pita.
Chris
Hackintosh 3.6 GHz 8 Core Intel Core i9 - 12.6.4 Monterey -32 gigs Ram - Carbon - Protools 2024.3 Ultimate |
No track names in Flip mode | Mark Haliday | ProControl, Control|24, Command|8 | 2 | 07-05-2001 09:19 AM |
No track names in flip mode ?!? | Mark Haliday | ProControl, Control|24, Command|8 | 0 | 06-01-2001 12:35 AM |
Plugin flip mode | Mano | Tips & Tricks | 1 | 04-08-2001 08:24 PM |
Plugin flip mode | Mano | Tips & Tricks | 3 | 04-08-2001 08:13 PM |
5.1 Flip Mode Backwards | Kenny Gioia | ProControl, Control|24, Command|8 | 1 | 02-24-2001 07:17 PM |
