Avid Driver Replacer requires Reboot Each time!
Please help! I have an MBox 3 (regular) and PT 10.3.5 with MBox Driver 1.0.22 on a Windows 7 machine.
Pro Tools and the MBox 3 work fine, however, every time I reboot or cold start, I get two boxes on my desktop telling me that I must restart to apply changes, and the Title bar of the message says Avid Driver Replacer. Searching the forums, I found one thread pertaining to this issue which recommends reinstalling the driver using "As Administrator", which I have done several times but I am still getting these message boxes! Has anyone from Avid seen this problem yet? How do I correct the problem? I have unplugged the device while performing the uninstall/install and plugging back in AFTER the reboot is done, however once I plug the MBOX 3 device in the message reappears! |
Re: Avid Driver Replacer requires Reboot Each time!
I believe when switching usb ports windows will try to automatically install the drivers for the device, so keeping the mbox on one port should solve this issue.
System Specs: http://duc.avid.com/member.php?u=108915 Audio Reel: http://www.wacc.net/ https://soundcloud.com/13guatamas13 |
guatamas, thank you for the reply... I do keep it on one port, so that is not a problem... it was fine for a while, then I uninstalled some old programs and the messages started appearing. Repairing the installation does not do anything!
I'm going to pass this along to get some insight on this. Stay tune.
@Emcha_audio,
Thank you. Further info is that I have uninstalled/rebooted and reinstalled several times but it still shows the message box to Restart to apply the changes. FYI the MBOX and PT10 are working. It just gets annoying having the message box come up on restart! It does seems to slow down my computer quite a bit until the message appears. |
Would be nice if any one else have experienced this issue to post in this thread this way maybe we can help a few at a time.
Just thought I would let you know that I again uninstalled the driver, rebooted, reinstalled the driver (all while the MBOX3 was unplugged), then plugged in the device to the USB. Windows showed a message that the drivers were installed successfully.
The same message came up after a few minutes, telling me to reboot to apply the changes. I did, and the message box came back twice, and it shows two times every time I reboot. |
2 questions for you: Is this computer connected to the internet all the time?
Have you disabled the power management feature on all USB ports?
I was not having this issue until I upgraded from PT9 to PT10. I already had been using the 1.0.22 driver with PT9... |
Regardless of the firewall, I would run a suite of anti-virus and anti-malware programs(avast, spybot-search&destroy, and Malwarebyte's anti malware). To the best of my knowledge, no firewall is impervious, and any PC becomes a target within minutes of having a connection. AFter running those programs, feel free to disable or remove them(assuming the system is clean).
Then, go to Device Manager or Power settings and institute all the required system tweaks, including the USB power management feature. troubleshooting takes time and perseverance, and getting the obvious stuff out of the way is part of that process. And you might try disabling the internet connection and the firewall as part of troubleshooting. I would also post a Sandra report at this point as it might help(and couldn't hurt). Help us Help You - READ THIS Before Posting!
The license Pro Tools 10+9 Bundle [Avid] requires surrender of the following licenses | Kin3tix | Pro Tools 10 | 1 | 05-06-2013 07:15 PM |
ER requires a reboot every use | LoneLizard | Eleven Rack | 2 | 12-23-2011 08:48 AM |
This software requires installation of device driver TPkd (HELP) | Mista808 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 02-19-2010 06:58 PM |
The software requires installation of device driver TPkd and | shilshoolon | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 01-16-2008 04:20 PM |
Time Signatures (Warning-requires some theory!) | Evil Jack | Pro Tools TDM Systems (Mac) | 13 | 09-13-2004 01:25 AM |
