Problem with DIM-function talkback
When dubbing cartoons for television our directors like to work with an open talkback system, so they can talk with the voice-talents all the time. With the Pro Control there is no way to completely bypass the DIM. This is very irritating because we should purchase seperate monitor/talback systems to achieve this. Does anyone or Digidesign know a solution for this?
regards, Geert, Meta Sound Studios |
Re: Problem with DIM-function talkback
How about using an aux input with a mic input in the control room? Don't put the control room mic out to the control room monitors and make your cue mix using sends (not mix to cue). Put an on /off switch on the mic or mute when not used to keep the mix from bleeding in the cues all the time.
Our studio came across the same problem.
So, we bought a Mackie submixer and ran ProTools MixL/R out into two channels of the Mackie mixer. Then, plugged a mic into an another open channel in the Mackie. Finally, feed Mackie Main mix out to Cue amp--which includes both the Open TB info as well as the ProtTools info. |
Thanks for the reply Roy&Airwave, we've thought about both options too, while the first option is the cheapest and quite easy to do. I hoped that Digi could make a fix for this, so we could use the Pro Control like it is supposed to be used.
Regards, |
Also you have have the mic going through the PB monitors but it would be at such a low level anyways (the talent should hear it plenty loud in their cans) that it shouldn't feedback. If you have any questions just email me & I'll send you a diagram.
Chris Thom ChrisThom.net Time flies like the wind; Fruit flies like bananas. ~ Groucho Marx |
Tanks for the reply Chris, we will probably end up doing it the way you described (which is in fact the same Roy described.) But you don't need the signal going to your control room monitors, just mute the aux channel with mic input and put the send to the can on pre-fader. I make cue-mixes via sends almost all the time, so that's not a problem.
Digi can you bypass or make the DIM-level 0dB? regards, |
and BTW, this DIM-problem is the same with a Control24 we use.
regards, |
============================================== Wait, my mistake. I double-checked my routing. I did NOT use an additional external mic, but rather, I used the ProControls mic. I connected the SLATE out of the ProControl to the Mackie submix. Now, when I press TB on the ProControl, it does NOT dim or disrupt any PT information feeding any of the Cue mixes or control room PB. Feed back Does not ocurr in CR PB because SLATE/TB is assigned Soly to cue mix via Mackie Mixer. |
>>>Digi can you bypass or make the DIM-level 0dB?<<<
That would be important for me too. I am considering the purchase of a ProControl and I would hate a fixed DIM level that is lower than 0dB. For the same reasons Geert described. Don't tell me that I have to buy a Mackie in addition to a ProControl just to make this happen. Please? Bill |
If you press the dim switch and turn up the control monitor level then the volume in the control room doesn't change when you push the talkback switch. Ie. the dim is always "On". That seems to work for us. We've also replaced the talkback switch with a latched version from the same manufacturer. Now it's simple. Dim on, talkbalk on , record, play, ta da.
SC48 Talkback and another problem. | TheMAXX7 | VENUE Live Sound Systems | 11 | 09-18-2012 10:09 PM |
auto talkback DIM function annoyance | Matt Chan | ICON & C|24 | 1 | 01-10-2007 06:32 PM |
Problem with talkback | Pythagor | ICON & C|24 | 3 | 12-10-2005 01:00 PM |
C24 Listenback and talkback problem | RCKPROD | ICON & C|24 | 0 | 11-29-2004 12:07 PM |
any way to bypass the talkback dim function? | pmueller | ICON & C|24 | 4 | 11-19-2003 03:06 PM |
