Hi all,
Just got a Dock and I'm struggling to find a command that will allow me to select the next (or previous) track via the Dock so I can move the focused track to the Dock fader without leaving the dock (ie not using the keyboard, mouse or touchscreen.) Basically the equivilent of "p" and ";" but also important for me to work in the mix window as well. Thanks ben
Ben Rubin Producer//Mixer//Bassist//Composer benrubin.com ------------ PT Ultimate 2024.3, Mac Studio M1 Max, 64Gb RAM, Mac OSX 13.6.4, SSD sample drive, Neve 8816, HD Native Thunderbolt, (2) Lynx Aurora 16, Benchmark DAC-1/ADC-1 |
Make one using any of the customizable vertical or horizontal strips.
You can also just tap on the track using the tablet and Avid Control. Or. Create a new Eucon softkey that will populate any of the colored softkeys just below the tablet. |
Thanks for the reply. It's the "make one" part of it that I don't know how to do.
Thanks. But unfortunately that video no longer works. PE lost a lost of videos when their host shut down.
I get how to program the softkeys. But what is the specific command(s) that will let me go from one selected track to the next in both the mix and edit windows.
I don't know one that works in the mix window. I use the touchscreen for that.
Anyone else?
~Will |
![]() Quote:
https://youtu.be/9N2pfNHl65E?feature=shared You create a softkey that uses the keyboard shortcut key. |
What good is "Save Copy In..." options "Session Plug-in Settings Folder" and "Root"? | ZerglingPhilosophy | Getting Started | 1 | 09-02-2022 03:43 PM |
Keyboard Shortcut for "Track List", "MIDI Editor Pane", and "Clip List" | EdgarRothermich | Pro Tools 12 | 2 | 10-04-2017 02:18 PM |
"Bounce To Disk" Track is "Lower in Volume" | LSNY | Pro Tools 12 | 18 | 06-05-2017 08:45 PM |
Toggle Track view ("Opt"+"-") doesn't work | LukeFromBerlin | macOS | 3 | 04-01-2012 04:43 AM |
If I "Remove Unused Regions" after "Consolidate", track won't play? | el biciclista | Pro Tools TDM Systems (Mac) | 10 | 04-02-2003 10:17 AM |
