ProTools can't detect Tascam 3200
Hi all, I have Protools 9, Mac OS 10.6.8, connected to Tascam 3200 through firewire 400. However, every time I start up ProTools, the firewire card of Tascam 3200 can't be detected. The default interface option of ProTools 'playback engine' is 'Built-in digital output'. I have to select Tascam 3200 manually. What's going on?
Re: ProTools can't detect Tascam 3200
Doubt this is a pro tools issue! so you can manually select the tascam as the audio engine but it wont stick when you naxt boot PT? Have you got the latest Tascam driver? Are you booting your Mac in 32 or 64 bit kernel? tascam haven't written drivers for Mac in 64 bit Chris
When are you turning on the DM?
Before boot or after boot? Have you selected the DM as your default OS X audio device? Those would be the first things is check.
www.montabonsound.com www.29counts.com Pro Tools HD 2019.12 | HD Native PCIe & HD Native Thunderbolt | Lynx Aurora 16 HD | HD I/O | Digi 192 | 2010 Mac Pro 12 Core 3.46ghz | macOS Mojave 10.14.4 | 48 gigs RAM | Tascam DM3200 | Crane Song Avocet II | Antelope Isochrone OCX | Universal Audio Quad & Duo | Waves Mercury + Studio Classics v10 & Abbey Road Collection |
Every time I connect an external firewire HD, Protools quits and can't detect TASCAM
Sounds like a FireWire bus issue/conflict.
Have you got the latest FireWire driver for mkII? I would also try a different FireWire port if you have one available. I came from a PC using Pro Tools and with my PC if I plugged anything into the FireWire ports while the DM was running the DM connection became very unstable. When I made the move to a Mac I kept some of that paranoia so I never tried using a FireWire device while the DM is running. Have you also tried posting on the tascamforums.com?
PLEASE HELP! HUI and TASCAM DM 3200 | mertenaudio | Pro Tools M-Powered (Win) | 4 | 02-25-2014 05:45 AM |
Eleven rack/Protools/Tascam DM-3200 | guitarbin | Pro Tools 10 | 3 | 11-28-2013 09:24 PM |
PT9 and TASCAM DM-3200 | critictalk | macOS | 17 | 09-29-2012 11:06 AM |
Here is How to setup DM-3200 with ProTools 9 - the old Tascam pdf doesn't work | noah330 | Pro Tools 9 | 1 | 11-06-2010 02:50 PM |
Anyone using the Tascam DM 3200? | Johnny2Laps | Pro Tools TDM Systems (Mac) | 0 | 05-05-2006 12:13 PM |
