A bit stumped by this one but its very frustrating having to restart everytime..
Machine specs are HD2, 192 i/o, Sync HD, D-Command, Mac Pro, OS 10.5.8, Harpertown 8-core, 8GB RAM, Protools HD v. 8.0.5, plugins are up-to-date as of 10 days ago. Basically on this one session, as soon as I close it, ProTools beach balls and crashes. I've tried the following: Deleted prefs etc Passed all the disks through Diskwarrior and Tech Pro Tools in case of drive errors Did a save copy in on the session Deleted all fade files and had pt's rebuild them Opening session with all plugins deactivated and then closing it I'm at a loss and the only other culprit is a corrupt audio file but how do you find it? Its not like plugins where you can introduce them one at a time (there's 1000 files!) Any ideas are appreciated Thanks |
A suggestion....
Open session, delete one track at a time. Clear unused audio files. close session. Eventually you may delete a track/clear audio and the session closes fine. Make note of which track it is. If this works, then make a new track, and pipe the audio from Bad Track into New Track, and record it as a take. Whack the bad track/Remove unused audio/Clear and do a Save Session Copy. I've done this when I had a corrupt track or two. pain in the butt. but better than nothing. Two quick qs.... is this a 2TB Hitachi drive? And was the session created in an earlier v of PT? Sorry if you mentioned this earlier.
Brian www.brianjanthony.com MacPro 6 core 3.46 Cheese Grater HDX and HD NATIVE 48 gig Ram PT 2019. Something Sierra 192 IO and 96 IO TDM user way back. PT user since 98. I'm either working, sick, or both. ![]() |
Personally I would create a new session and import session data from the original session, 8 (or so) tracks at a time. At some point the culprit will raise its ugly head, and you'll be able to narrow it down from 1 of 8 tracks....
Thanks guys. Both good suggestions that i'll give a shot - import session track by track hadn't occurred to me as a way to weed out the bad files.
Are you using Auto Tune EVO? Happens here on multiple systems virtually every time when using EVO
Nope, I actually sold all but my Antares Mutator license a while back as those plugs used play havoc with sessions
protools 11.01 close session crashes on load next session | eddie lamb | Pro Tools 11 | 2 | 09-07-2013 01:51 AM |
PT 8 crashes on close, old session - crash log incl | jaguffain | Pro Tools TDM Systems (Mac) | 6 | 02-14-2011 09:38 AM |
Pro Tools crashes when I close the programme | ajcsound | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 01-04-2011 12:46 PM |
Pro tools 8 crashes when i close a session | Raoul23 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 11-19-2009 03:35 PM |
Guitar Rig 2 causing "close session" crashes | nz | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 05-08-2006 05:31 AM |
