I have ProTools LE 8.02 cs on a Win 7 64-bit PC, and a Digi 002 Rack. The rack has 4 mic/line inputs yet PT LE only recognises 2 inputs?
Does anyone know how I can utilise the remaining 2 inputs on the rack in ProTools? |
For running Win7 x64, you should be using PT version 8.0.4cs2. In any case, go to Setup>IO>Input tab and click the default button. Take a good look at the GRID on that page and notice how it works. You can freely assign input paths and sub paths as you want/need for your setup. You can also rename inputs to fit your setup(for instance, mine are labeled with what is patched, like "Motif'(for a Motif es8 on stereo inputs), "ISA 1", "ISA2"(for my Focusrite ISA preamp). Some outputs I have named "Phones 1", "Phones 2", etc. You actually have 8 inputs on the 002 that you can use right now. 5 thru 8 are line inputs with a switch for -10 or +4 operation. In -10, they might work fine for keyboards or a CD/Cassette player. In the +4 position, you could patch in some better external mic preamps.
Gigabyte X79/intel i7 3930K, 32GB RAM, HD/Native, 192 IO https://www.facebook.com/search/top/...0sound%20works The better I drink, the more I mix ![]() BTW, my name is Dave, but most people call me.........................Dave |
Hobee, found it .. right under my nose, so obvious.
Happy recording! Thanks .. Richard G |
need help with digirack | yoleyfisher | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 06-01-2006 06:42 AM |
What's best Mac to buy 4 PT LE 6.4 Digirack 002? | lonlonmilklover | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 01-14-2006 12:05 AM |
New Digirack EQ III - | Produce_Dept | Pro Tools TDM Systems (Mac) | 55 | 03-21-2005 01:57 PM |
TDM vrs DIGIRACK | Muhfahsa | Pro Tools TDM Systems (Mac) | 2 | 08-16-2004 08:35 PM |
It can be done with Digirack | Sugarite | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 08-24-2001 02:39 PM |
