Old 06-12-2002, 10:15 PM
Eric Lambert's Avatar
Default FilterBank settings not recalling?
I back up all my sessions to DDS3 DAT tape with Mezzo 4.03. Before that I used Mezzo 3.7. When I restore recent sessions all plugin settings are restored correctly, but when I restore older sessions that were backed up with Mezzo 3.7 or older the FilterBank and CompressorBank settings are set to their defaults. Every other plugin in the session has the correct settings. The other thing I should mention is that I'm now using ProTools 5.1.1 where before I was using 5.0.1.
Anyone else seeing this problem? It's driving me crazy - the mix was heavily modified by both plugins and without the proper settings the mix is way off.
Old 06-12-2002, 11:05 PM
Default Re: FilterBank settings not recalling?
Eric
I've used systems with newer versions of the McDSP plug-ins... if the sessions were originally saved with an older version on another system, they will only load with the default (no eq).
Not sure if you can install older versions of the plug-ins temporarily to get the settings.
Rail
Platinum Samples
www.platinumsamples.com
Engineered Drums for BFD
Recalling settings from track Gonk Eleven Rack 2 09-02-2013 12:25 PM
TC VSS3 TDM not recalling settings JSR Pro Tools TDM Systems (Mac) 42 09-09-2012 08:35 AM
EQ3 Not recalling/saving settings slaterweezer Pro Tools TDM Systems (Mac) 0 04-09-2012 10:42 AM
PQ User settings not recalling noclevername VENUE Live Sound Systems 6 06-21-2010 07:20 AM
Is there a Bugฎ with recalling zoom settings?? Bushpig Pro Tools TDM Systems (Mac) 11 07-13-2009 02:49 PM
