Old 05-07-2006, 02:39 PM
nz nz is offline
Default Guitar Rig 2 causing \"close session\" crashes
I have been using Guitar Rig 2 a lot on a new project that I am doing. I notice that if GR2 is enabled in the session, when I go to close the session out, PT will crash. I look at the report that is generated and it is a Kernal error and Guitar Rig is named the culprit. I have the latest version of each application.
Is anyone else having an issue like this?
Thanks!
nz
Old 05-08-2006, 01:33 AM
Dozerbabar Dozerbabar is offline
Default Re: Guitar Rig 2 causing \"close session\" crashes
I might be the same issue as I have with Waves tune. I've been told that I will have to close ReWire before quitting PT. Do you use Rewire with Guitarrig? If so, try it.
www.molotow.no
Old 05-08-2006, 05:31 AM
nz nz is offline
Guitar Rig 2 is simply a plug in and Rewire is not used at all.
nz
protools 11.01 close session crashes on load next session eddie lamb Pro Tools 11 2 09-07-2013 01:51 AM
PT's crashes after I close a session D'Animation Pro Tools TDM Systems (Mac) 5 06-24-2011 09:52 AM
PT 8 crashes on close, old session - crash log incl jaguffain Pro Tools TDM Systems (Mac) 6 02-14-2011 09:38 AM
Pro tools 8 crashes when i close a session Raoul23 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 11-19-2009 03:35 PM
SampleTank SE causing PTLE 6.1.1 to close? Pako 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 7 10-08-2003 11:26 AM
