HELP, Cannot Record to Pro Tools 10
OK, I got that off of my chest.
First of all, here is what IS working. Through my Lexicon Omega to Pro Tools 10: (1) I can here wav track playback through headphones into Omega or speakers, whichever I choose on my PC. No latency, no noise. Perfect playback. (2) I can hear my microphone in headphones or through speakers, perfectly. Here is what is NOT working: recording with the mic. I am convinced I have something screwed up in either Setup|Hardware with ASIO4All or Setup/I/O. I have gone around in circles for two weeks now and have not ever been able to get a microphone signal to a vocal track. Hopefully the forum audience can, at a minimum, give me suggestions to try. HELP. OK, I feel better. |
Re: HELP, Cannot Record to Pro Tools 10
Are you using a Mic that needs phantom power, if so do you have it switched on...if not do you have it switched off?
Too much blood in my drugstream Motherboard: Gigabyte Z690 AERO D CPU: Intel Alder Lake Core i9-12900K CPU Cooler: Noctua NH-D15S RAM: Corsair Vengeance DDR5 64GB (2x 32gb 5200MHz) Drives: 2 x Samsung 980 Pro 2TB NVME PCIE 4.0 M.2 SSD (Record & Samples) 1 x Samsung 980 Pro 1TB NVME PCIE 4.0 M.2 SSD (OS Win 11 Pro) GPU:Gigabyte GeForce RTX 3060 12GB GDDR6 PCIE 4 PSU: Corsair HX Series HX850 Platinim CASE: Fractal Define XL R2 PT 11HD (v11.3.2) Omni s/pdif <> AxeFxIII HD 96I/O |
No, it is an SM57 that I am using to test to see if I can get any mic to work. When I get it, I'll be using a Sterling that needs phantom power. But right now, no need.
PS. I discovered the problem when using the Sterling in the first place. No mic in my arsenal seems to work. |
Pro Tools 10 won't record | highspeedrecords | Windows | 2 | 02-27-2012 05:55 AM |
Pro Tools 8 LE will not record any vocals using pro tools 8 Le | MADMUZIK | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 10 | 03-27-2011 05:45 PM |
Pro Tools 9 record help! | Peter Dutton | Pro Tools 9 | 4 | 11-26-2010 08:09 AM |
Pro Tools LE 7.3 Help :: Will Not Record | anthonymunoz | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 11-11-2007 01:12 PM |
Pro Tools won't record!!! | colvaboy | Pro Tools TDM Systems (Mac) | 2 | 01-17-2007 08:27 AM |
