Go Back   Avid Pro Audio Community > General Discussion & Off Topic > Buy & Sell
Old 12-11-2021, 04:15 PM
Default Digidesign MH477 expansion chassis plus SCSI card and Glyph Trip
In very clean condition, but untested as I have no other compatible hardware. The interface card is currently installed in a slot and I did find the cable. Make offers
Also just found a PCI SCSI card(after buying one). Its an ATTO with twin external connectors and dual internal ports. Mates with the Glyph Trip rack-mount drive case I have. It has SCSI ports for a pair of SCSI drive cages(has dual Seagate Cheetah 10K drives) and a FW400 port linked to a Sony AIT tape drive. The SCSI drives come up and read/write fine, but the tape drive doesn't seem to happy(when I load in a new/blank tape, lights flash for a few seconds and then the tape spits out).
Old 12-16-2021, 07:54 AM
Default Re: Digidesign MH477 expansion chassis and card
Bump
Old 12-16-2021, 08:46 AM
JFreak JFreak is online now
Possible buyer probably wants to know whether the connection is PCIX-to-PCIX or do you have the PCI-express card which would make old cards current. The host card, I mean. Does the host need to be PCIX or PCI-express.
Old 12-16-2021, 04:04 PM
The host card is also the older PCI(or PCIx) and is currently mounted in one of the chassis slots(assuming so it didn't get lost). I did do a quick search for a card that would(should) allow PCIx cards to connect to a PCIe computer, but could not not find a PCIe card with the same connection, so I'm not sure whether this can be done or not(and sadly, I know almost zilch about these chassis). I am hoping for someone that sees the hardware, knows exactly what it is, and has a need/purpose for it
Old 12-16-2021, 04:11 PM
It is in fact Digidesign/SBS 7slot expansion chassis and if memory serves me right it is only good for PT7.x and perhaps also PT8.0 (compatible with G4/G5 PPC systems)
Not sure if there is PCI-express card available for it due to its age, maybe it would have needed to be one generation newer for it.
Be aware that if you use 192kHz sampling rate the max number of cards available for PT is four. Lower sampling rates can use everything you put into it.
Old 12-17-2021, 03:06 PM
Good info! Thanks for that
Old 12-27-2021, 01:28 PM
To the top. If I get software squared away, I will probably mount HD3 and SCSI cards and give it a good test run(just waiting to see if a friend has a SCSI card so I can include a Glyph Trip drive case in the testing.
Old 01-02-2022, 01:03 PM
SCSI drives work fine and I have a PCI card to include if anyone wants the Glyph.
Old 01-16-2022, 09:38 AM
Bump
Old 01-23-2022, 05:45 PM
I actually have 3 SCSI cards, including an Avid-branded ultra-wide card. Will consider all offers(you will not insult me)
WANTED: Host card for Digidesign Expansion HD chassis (pcie ethernet card) topdiggy2 Buy & Sell 0 02-04-2015 08:22 AM
HELP: Drivers for Digidesign Expansion HD Chassis & pcie host card topdiggy2 Pro Tools TDM Systems (Mac) 3 02-03-2015 05:42 PM
WTB Digidesign Nubus Expansion Chassis with host card (PPC) wirefall Buy & Sell 0 01-01-2015 07:46 AM
Digidesign Expansion HD Chassis and PT8 help!!!!! akmusic Pro Tools TDM Systems (Mac) 10 01-10-2009 07:28 PM
Digidesign Expansion|HD Expansion Chassis work ok? Will Russell Pro Tools TDM Systems (Mac) 8 05-25-2006 02:19 PM
