Mini Grand sustain pedal punch issue
As a new PT 2021 / HDX there is one little issue I've encountered that is driving me bonkers. I often use the Mini Grand as the piano for scratch, template recording in sessions with clients. Low latency, low CPU usage, etc. But there seems to be an issue with punching in & the sustain pedal. If you punch in on a MIDI or Instrument track with Mini Grand, any subsequent sustain pedals controller breakpoints get inserted, but it stays permanently on. When I lift my foot off the pedal, it does not return to the "off" position. Sort of maddening. This issue can also just as mysteriously go away after messing around for a while. I think it's just the Mini Grand. I tried using the Electric Grand instrument and that worked fine as far as sustain pedal recording. Anyone else notice this? I've attached a screenshot. You can see where the punch is, and where the sustain pedal stops going to the "off" position (In many years of using the Mini Grand in PT 10HD with my same MIDI keyboard I never once had this issue...) EDIT: Seems if you punch while the pedal is in the "ON" position, it is unable to go back to the "OFF" position, even though the breakpoints are recorded. If I manually move a pedal "OFF" breakpoint just prior to where I am punching, it works fine.
-------------------------------------------- 2009 Mac Pro 5,1, PT 2021.3.1, HDX, Mojave, RX 560, Apogee AD/DA-16X, HD I/O 8x8 Last edited by innerbooty; 07-26-2021 at 09:30 AM. |
Re: Mini Grand sustain pedal punch issue
It is a long standing bug and sometimes you can get rid of it by toggling midi merge on and off
Ok, thanks. Never happened in PT 10 HD, but that was obviously many versions ago...! I'm a little disappointed that having jumped straight from PT 10 to 2021, I was hoping MIDI would have gotten less clunky and more user friendly in PT. But it seems about the same...
-------------------------------------------- 2009 Mac Pro 5,1, PT 2021.3.1, HDX, Mojave, RX 560, Apogee AD/DA-16X, HD I/O 8x8 |
Sustain Pedal Issue with Protools and studio logic SL88 | [email protected] | Pro Tools 2018 | 5 | 12-22-2023 05:39 AM |
Issue with mini grand and sustain pedal | greenpasta | Virtual Instruments | 2 | 03-15-2018 12:08 AM |
Mini Grand VI in PT11 sustain pedal problem | OutbackStudios | Pro Tools 11 | 3 | 01-03-2017 06:54 PM |
mini grand & sustain pedal issue | cplaza | Virtual Instruments | 6 | 09-27-2014 09:15 AM |
Sustain pedal not working with Mini Grand | Gothboy | Virtual Instruments | 0 | 06-22-2009 10:31 AM |
