Old 07-06-2022, 01:14 PM
newcomerp newcomerp is offline
Default Re: 003Rack driver still OK with Pro Tools 2022.4 and 002Rack on Win 10?
Problem fixed:
Like i said the digi 003 rack was not used in the Windows Playback settings but i did not checked the Recording settings and there the inputs 1 and 2 was used by default. I did not think that this section was that important. So i deactivate all the digi 003 outputs and inputs in the Windows Playback and Recording settings and now i can have all the buffers when Pro tools is launched. Thanks albee1952 and EGS for the help.
Old 07-29-2022, 09:53 AM
EGS's Avatar
EGS EGS is offline
Originally Posted by newcomerp View Post
... 003 rack was not used in the Windows Playback ... inputs 1 and 2 was used by default...
Audio interface should not be selected for Windows System Sound Playback.
Audio interface should not be selected for Windows System Sound Recording.
Control Panel--->Sound--->Playback (I use Realtek Digital Output)
Control Panel--->Sound--->Recording (I use none)
(... unless you use interface loopback feature - but that's a different conversation ...)
Desktop: PT 2020.5 / Win11 / Intel 11th Gen i9 5.1GHz / 64Gb DDR4-3600 / Gigabyte Z590 Vision D / Focusrite LS56
Laptop: PT 2020.5 / Win10 / older HP ProBook with i7 quad / U-PHORIA UMC1820
Legacy (works!): PT 5 & 6 / OS9 & OSX / Mac G4 / DIGI001
Click for audio/video demo
Old 07-29-2022, 03:07 PM
Well....Don't you find yourself funny with how yow quotes? You only quote what you want out of their context.
I was not aware that the Digi was used in the recording section....and your first quote, refering to Albee1952 was talking only about the playback section...
You needed to write what you have written last, first, instead of a vague comment and before i find the solution my friend...
Anyway thanks for your big help.
Old 07-29-2022, 03:35 PM
EGS's Avatar
EGS EGS is offline
No disrespect intended. I was trying to point out you need BOTH play and rec set properly.
Old 07-29-2022, 04:03 PM
Well... Read yourself again.. If someone understand what you were pointing out in your first comment, it was only related to the playback section... But anyway thanks for your help.
  #16
Old 08-02-2022, 07:06 PM
hernangil hernangil is offline
Hi, Im still using my 002 console, rock solid till now with pro tools 10, I want to upgrade to the last version of PT, will it be compatible in windows 10?
Installing 003rack + with protools 12 driver error ahardoy Pro Tools 12 4 11-04-2015 10:34 PM
003Rack+ Driver-Less, PT LE 8 Superwoodle 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 01-22-2012 06:48 PM
003rack + windows7 64bit = asio driver problems johnut 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 8 05-25-2011 07:28 AM
DIGI 002Rack to DIGI 003Rack ? shanabit 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 03-11-2009 03:47 PM
Digi 002Rack to 003rack or 003 shanabit 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 8 12-18-2007 07:41 PM
