Old 03-28-2011, 06:36 AM
larsmeijer larsmeijer is offline
Default Audio Driver Problem on HP Laptop with Pro Tools 9
The next thing is giving me problems in PT9 on my laptop
After installing the crossover from PT8 to PT9 I could not change the H/W buffersize of mine Realtek IDT High Definition Audio Codec (protools was crashing because I could not change this). After that I installed the latest Asio 4 all drivers and now Pro tools knows the ASIO Driver (in the playback engine) but it isn't possible to select the ASIO as an output on your tracks (it still remains as the normal output)
Now there is no sound at all while I see the VU-meters are working.
Does some one has any idea what this could be or having the same problems/solution?
SiSoftware Sandra
Computer
Model : HP HP Pavilion dv7 Notebook PC
Workgroup : WORKGROUP
Host Name : lars
User : Lars
Processor
Model : Intel(R) Core(TM) i7 CPU Q 720 @ 1.60GHz
Speed : 1.73GHz
Cores per Processor : 4 Unit(s)
Threads per Core : 2 Unit(s)
Type : Mobile, Quad-Core
Integrated Data Cache : 4x 32kB, Synchronous, Write-Thru, 8-way, 64 byte line size, 2 threads sharing
L2 On-board Cache : 4x 256kB, ECC, Synchronous, ATC, 8-way, 64 byte line size, 2 threads sharing
L3 On-board Cache : 6MB, ECC, Synchronous, ATC, 12-way, Exclusive, 64 byte line size, 16 threads sharing
Computer
Platform Compliance : Intel Centrino Mobile Technology
Mainboard : HP 365C
BIOS : HP F.16 01/22/2010
Bus(es) : PCI PCIe IMB USB i2c/SMBus
Multi-Processor (MP) Support : No
Multi-Processor Advanced PIC (APIC) : Yes
Total Memory : 4GB DDR3 SO-DIMM
Chipset
Model : HP Core (Clarksfield/Lynnfield) DMI
Front Side Bus Speed : 2x 2.4GHz (4.79GHz)
Chipset
Model : HP Core Mobile (Clarksfield) UnCore
Front Side Bus Speed : 2x 2.13GHz (4.26GHz)
Channels : 2
Memory Bus Speed : 2x 665MHz (1.33GHz)
Memory Module(s)
Memory Module : Hynix (Hyundai) HMT125S6BFR8C-H9 2GB DDR3 SO-DIMM PC3-10700S DDR3-1334 (9-9-9-25 4-34-10-5)
Video System
Video Adapter : NVIDIA GeForce GT 320M (16 SM4.1, 1GB DDR3 128-bit, PCIe 2.00 x16)
Graphics Processor
Compute Shader Processor : NVIDIA GeForce GT 320M (16SP, 1GB DDR3 128-bit)
Storage Devices
WDC WD6400BEVT-60A0RT0 (640.1GB, SATA300, 2.5", 5400rpm, 8MB Cache) : 596GB (C:) (D:) (E:)
hp CDDVDW TS-L633N (SATA150, DVD+-RW, CD-RW, 2MB Cache) : 3GB (F:)
ELBY CLONEDRIVE (SCSI, SCSI-2, BD-R, HD-DVD-R, DVD-R, CD-R, 256kB Cache) : N/A (H:)
Logical Storage Devices
SYSTEM : 199MB (NTFS)
Hard Disk (C:) : 579GB (NTFS) @ WDC WD6400BEVT-60A0RT0 (640.1GB, SATA300, 2.5", 5400rpm, 8MB Cache)
RECOVERY (D:) : 17GB (NTFS) @ WDC WD6400BEVT-60A0RT0 (640.1GB, SATA300, 2.5", 5400rpm, 8MB Cache)
HP_TOOLS (E:) : 99MB (FAT32) @ WDC WD6400BEVT-60A0RT0 (640.1GB, SATA300, 2.5", 5400rpm, 8MB Cache)
AudioMClass (F:) : 3GB (CDFS) @ hp CDDVDW TS-L633N (SATA150, DVD+-RW, CD-RW, 2MB Cache)
Optical Drive (H:) : N/A @ ELBY CLONEDRIVE (SCSI, SCSI-2, BD-R, HD-DVD-R, DVD-R, CD-R, 256kB Cache)
Peripherals
LPC Hub Controller 1 : HP PM55 LPC Interface Controller
Audio Device : HP P55/PM55/3400 High Definition Audio
Audio Codec : Integrated Device Tech 7603h
Audio Device : HP High Definition Audio Controller
Audio Codec : nVidia 000Ah
Disk Controller : HP P55/PM55/3400 6 port SATA AHCI Controller
USB Controller 1 : HP P55/PM55/3400 USB2 Enhanced Host Controller
USB Controller 2 : HP P55/PM55/3400 USB2 Enhanced Host Controller
SMBus/i2c Controller 1 : Intel ICH SMBus
Printers and Faxes
Printer : Xerox WorkCentre PE114_16_16e (600x600, USB, Colour)
Printer : Send To Microsoft OneNote 2010 Driver (1200x1200, Colour)
Printer : Microsoft XPS Document Writer (600x600, Colour)
Printer : HP Deskjet F300 Series (1200x1200, USB, Colour)
Printer : Canon Inkjet MP210 series (600x600, USB, Colour)
Printer : Canon Inkjet iP3600 series (600x600, USB, Colour)
Printer : Adobe PDF Converter (4000x4000, Colour)
Printer : HP Deskjet F300 Series (600x600, USB, Colour)
Printer : Canon Inkjet MP160 Printer (600x600, Parallel, Colour)
Printer : Canon MP160 Printer (USB, Colour)
Network Services
Network Adapter : Bluetooth-apparaat (Personal Area Network)
Wireless Adapter 1 : Broadcom 43225 802.11b/g/n (802.11g (ERP), 48Mbps)
Power Management
Mains (AC) Line Status : Off-Line
Battery No 1 : 32%
Operating System
Windows System : Microsoft Windows 7 Home 6.01.7600
Platform Compliance : x64
Windows Experience Index
Current System : 5.7
Old 03-29-2011, 04:04 AM
Default Re: Audio Driver Problem on HP Laptop with Pro Tools 9
Ok after installing the Asio 4 All Driver again Pro Tools is now not clipping and crashing anymore.
The only thing is that I only can listen true a headphone and not by the speakers of the laptop(not that I would prefer this but it should be working also I think)
I'll keep you posting!
Old 03-29-2011, 04:31 AM
still problems but I have sound on my headphone. Now if I want to change something in the ASIO driver or clicking on it Pro Tools is crashing!
The only thing I can do is launch Pro Tools and work in it for how long it takes. The thing is also that the ASIO driver only works when PT is launched.
Also when I change for example the H/W in PT there isn't any sound comping out of my output
don't no where to seek for the problem (maybe in ProTools maybe in Asio Driver or inside the original driver of the HP Laptop)
Old 03-29-2011, 07:53 AM
bootybandit bootybandit is offline
Try dumping the files in the DAE Preferences folder...........
Healing the world through music.................
Sony Vaio Laptop|2 Core P8700 2.53 Ghz 8 Gb Ram|Win8 x64
PT 9.0.6|Cubase 7|Samplitude Pro X|Reason 5|Spectrasonics|Komplete
RME BabyFace|AxiomPro49|Akai LPD8
Old 09-19-2011, 03:26 PM
I have found the main Issue. It was my HP pavillion and sold it. Next month going further on a Mac Book pro and hope that this one will take it
PLEASE HELP! Just upgraded to Pro Tools 8, AUDIO DRIVER PROBLEM DJ BurninLz 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 13 12-27-2012 09:29 AM
8.04 MBox 2 Audio Driver problem Qusic 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 07-10-2010 09:52 AM
Audio Driver problem adlib311 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 12-19-2009 01:36 PM
Audio or Driver problem? laboya 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 08-16-2006 08:36 PM
new core audio driver problem gugu Pro Tools TDM Systems (Mac) 11 09-17-2003 12:41 PM
