what the hell is that noise?
every now and again my 002r randomly makes a low brrrrrrrrr kind of noise. it doesnt do it when running protools, only the core audio manager. it only started last week. when it happens, i quit the manager and the noise stops. it very spookie
any ideas what it is? here is the info... powerbook 15' 1.67, 002r, OSX 10.3.9, CoreAudio driver 6.9 |
Re: what the hell is that noise?
Is it the 002 unit itself, or is it a noise that's coming through your speakers?
-Andrew |
its coming from the speakers.
I have my 002, a Lacie D2 and an iPod all hooked up to my computer. Since I only have two firewire ports, I use the other port on the back of my Lacie for the iPod. I've noticed that when I connect or disconnect the iPod with my 002 on, I often here a sort of high, electrical-staticy sort of sound come through my monitors. It's fairly quiet, but definitely there- it usually stops after a minute or two...
Do you have something in your setup that could be causing the same sort of thing? Cheers, Andrew |
i have just one firewire cable running from the computer direct to the 002r. i believe it is caused by some sort of software glitch... and its loud. today i left the room and returned to a almost deafening noise. its like a square wave kind of thing at about 500hz... maybe lower. i only had safari open with the manager. I quit safari, the noise was still there. I quit the manager and it disappears.
luckly i use a tdm system in the studio, so its not making this noise at clients. that would be embarrassing anyone else had this? |
Turn off your cell 'phone.
Rail
I GET BUZZING NOICE WHEN I TURN ON THE PHANTOM POWER ON MY M=BOX
Apple: MBP 2.53 - 4G RAM HDD 500G, iMac 27 inch 1TB ProFire 2626, MBox Micro, PTMP 8, NIs, Strike, POD Farm, Logic 9, EJ Strat, 52 Tele RI, MB Mk 3, PRS CE22, Epi Casino, PBass, Variax, L6XTL, M13, DRRI, BM iGuitar, GR-33, KeyStation 88, Axiom 49 |
Try making a new user and see if it happens on that account.
If the noise no longer appears try dumping you Digi Prefs first. If it returns could be a wierd O.S problem try copying you entire Prefs folder to the desktop then delete the one in the Libary folder restart this should rebuild all your O.S prefs, is the noise gone? You could then copy all the none rebuilt prefs back from the original prefrence folder now on the desk top, test it again if it remians gone problem solved delete the pref folder on the desktop empty trash restart. |
thanks for the suggestions, i tried a few of these things, the hard part is that it only comes every other day... so there is no real way of testing if its fixed. it didnt do it at all today, so maybe trashing preferences helped. will see if its back tomorrow.
and its not a cell phone noise. its a constant tone. |
DFH - drumkit from hell - installation from hell!! | polf | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 6 | 11-01-2011 07:57 PM |
NOISE from hell | DHS | Pro Tools TDM Systems (Mac) | 0 | 03-19-2006 11:11 AM |
Fuzz Noise from Hell | Sradio | Pro Tools TDM Systems (Mac) | 4 | 09-11-2005 01:17 PM |
Drumkits From Hell? Install From Hell. | Sparks | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 24 | 04-13-2005 06:11 AM |
Attn: Drumkit from Hell experts: noise noise noise | Smelt | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 10 | 07-30-2003 06:31 AM |
