Old 09-15-2015, 11:47 PM
harrismix harrismix is offline
Default El Capitan Support for Artist Series
Hi, Any news on when an El Capitan compatible version of EuControl might be on the way? I just updated to 3.3.1 but the same as other versions, the OLED displays are not working . . . . I'm on the latest firmware . . Thanks
Old 09-17-2015, 05:40 PM
Fishbone Fishbone is offline
Default Re: El Capitan Support for Artist Series
Same here. Artist Mix display lits up as 8 solid squares. Installed and reinstalled 3.3.1 but no luck.
Old 09-17-2015, 09:48 PM
Kyle Splittgerber's Avatar
Kyle Splittgerber Kyle Splittgerber is offline
Hey Guys,
Yes, we are aware of this issue and are currently working on a fix. For this reason, El Capitan is not yet qualified. We'll get the fix out as soon as we can.
Thanks,
Kyle Splittgerber
Senior Principal Product Designer
Berkeley, CA
Old 09-18-2015, 12:32 PM
maaaquemeseyo maaaquemeseyo is offline
Hi, thx for the heads up! I was about to install El Capitan... Is PT working fine?
Old 09-18-2015, 12:39 PM
What is the race to upgrade OS X versions?
Lots of audio interfaces/devices are *not* working fine. From Avid and others. You would easily see that by looking around on DUC.
Old 09-18-2015, 12:46 PM
I'm on Mavericks now, I have to do a clean re-install of Mavericks or move on to El Capitan. Right now there are some apps (like OneNote) and syncs fuctions with iOS that doesn't work with Mavericks...
Old 09-18-2015, 01:03 PM
Well it's your choice, read up on known issues. At most go grab a blank drive and do a clean test install of El Capitan. Maybe you end up with multiple boot partitions if you really need to be able to use incompatible things on different OS X releases.
I get the pain, where there is a hard need to be on a new release, I need latest OS X releases for X Code/Swift for example. I keep Pro Tools and audio drivers etc. on stable old OS X releases. And new stuff on separate boot drives. But too frequently folks here go sticking their head in the upgrade woodchipper for no good reason. And when they do upgrade they do it in-situ (bad idea) and with no roll back/recovery plan. Sounds like you are a little more aware there.
Old 09-21-2015, 11:54 PM
@tention @tention is offline
Why can't Apple just release a new system font and leave us alone? Would not break audio every year.
SOUND!
Old 09-22-2015, 05:17 PM
Originally Posted by Kyle Splittgerber View Post
Hey Guys,
Thanks,
Good to know!
Thanks for dropping a note
Old 09-22-2015, 05:23 PM
Nothing much, just that I like to have another partition to test new things to be ahead in the curve, just in case I need it or worth the jump.
Don't see anything wrong in exchange some info about it here in the users forum, since it's exactly what it was supposed to be used for, right?
Cheers
Artist series, Eucontrol, Support: Sorry, I don't get it. OTARI Artist Series 15 08-09-2013 08:07 AM
artist series and mac osx 10.8? trock Artist Series 2 09-07-2012 05:01 AM
Artist Series vs C|24 Bill Denton Artist Series 2 01-30-2011 01:37 PM
CSCooper MCS Series vs EU Artist Series? GrievousAngel Artist Series 1 12-01-2010 01:10 PM
