Carbon Expanded - ADAT
Does anyone know if in the future the Carbon Pre ADAT ports will be usable in a Carbon Expanded system? The documentation says they are not available to 'preserve bandwidth' but network bandwidth over 1Gb ports is nowhere close to being utilized if all analog + ADAT ports worked simultaneously. I suspect this is either an intentional decision made by the Product team to limit the I/O or there is some other limitation within the system.
Re: Carbon Expanded - ADAT
Where does it say that? I can't find it in the generic Carbon documentation.
It makes no sense to put loads of ADAT ports on the Pre, and then not let you use them. As you say, there shouldn't be a bandwidth constraint with only 3 units. Dominic
MacBookPro M1Max 16" 10/32 64GB 2TB, Ventura 13.6.6, Pro Tools 2023.12.1, Carbon. |
ADAT I/O is not available in Pro Tools with Pro Tools | Carbon Pre when it is part of a Pro Tools | Carbon Expanded system. However, ADAT I/O remains available on the Pro Tools | Carbon primary device in a Pro Tools | Carbon Expanded system. If you're using the Carbon Pre as a standalone device the ADAT ports are available. |
That’s outrageous. £3000 for 8 channels of I/O.
I’d better check I haven’t given anyone bad advice - I made the assumption all ports would be functional. What a con. Dominic
It is shocking to be honest. And I don’t think it’s obvious to most people buying into Carbon Expanded and they’ll find out too late. I would love to hear from Avid’s Carbon Product Manager on why they chose to do this. There are many other interfaces on the market with all different host connection types that let you stack units for expansion whether Ethernet, Thunderbolt, USB-C.
Well the Carbon originally came with two ethernet ports but could not use the second one until the Pre came out ?
I wonder if it might have something with the current AVB mapping ??
System : Studio - Avid Carbon interface , PT Ultimate 2023.12 Mid 2020 (intel) iMac 27" Ventura 13.2 .1 Mobile - 2021 14 " MBP M1 Pro PT Ultimate 2023.12.1 Sonoma 14.4 Enjoy the Journey.... Kev... |
Pro tools Carbon and ADAT | Rob Hannon | Pro Tools | Carbon | 10 | 02-09-2023 12:18 PM |
Can I use Carbon ADAT OUT with 8 Preamps Simultaneously | langa101 | Pro Tools | Carbon | 4 | 01-22-2023 02:17 PM |
use Carbon and Carbon Pre together as one interface in Logic/Cubase ? | pm mastering studio | Pro Tools | Carbon | 0 | 12-22-2022 01:54 AM |
Adat detection Problems With Carbon | Mike_sound | Pro Tools | Carbon | 14 | 10-23-2021 06:28 PM |
16 channels of ADAT i/o from an un-expanded 192 | GKF | Pro Tools TDM Systems (Mac) | 4 | 03-22-2007 04:09 AM |
