Is the Clip Gain the same as a Trim Plugin?
Was wondering if it was easier and sound wise better to use Clip Gain than the trim plugin? Trying out static mix if that's what everyone calls it. Where you put every fader to unity and get it close, then start adding your plugs etc.. Just wondering if there was any + and - to using either one or are they the same thing?
PT 11, PT LE 6.0, DIGI 001, DIGI 003, 27" Late 2012 Intel iMac, Blue and White G3, Reason 7, Celemony, Waves, A.I.R., Softube, XLN Audio, IKmultimedia, Massey Alesis Masterlink, Alesis Adat LX20, , Yamaha Motif ES8, Sure SM58, Sure KSM27, Byerdynamic MC 834 N, Event Project Studio 6, Pod Line 6, Focusrite Trakmaster Pro DI, Glyph Drives, Lexicon, Fender Strats, Ibanez Acoustic, Ibanez Bass, Ibanez Electric. http://www.johnackermusic.com/ [email protected] Live and Let Live |
Re: Is the Clip Gain the same as a Trim Plugin?
Clip Gain is between the disk drive and the first insert slot so you not eating up a slot.
Aaaaaaaaaaa😳
You very wise. Me learn. Thumps chest😜
As far as I can tell Clip Gain is like real time, automatable AudioSuite Gain. And it's Pre Fader.
Cheers,
Correct, clip gain is pre fader- the first step in the process, so whatever you do in clip gain will effect everything else "down stream" (EQ, Dynamics, Sends etc.) also, the CG is non-destructive and can be altered at any time, Audiosuite will create a new file and rep[lace the existing original - probably not quite as flexible, depending on your situation.
And the Trim Plugin?
AudioSuite Gain/Normalize also on Clip Gain | A-n-d-i | macOS | 0 | 03-13-2014 12:46 PM |
Gain plugin bug? Writes distortion to start of first processed clip | iain_m | Pro Tools 10 | 18 | 06-03-2013 03:41 PM |
Clip gain on clip groups: bug or feature? | idris | Post - Surround - Video | 6 | 01-02-2013 10:48 PM |
Clip Gain doesn't follow trim edits bug? | JR Fountain | Post - Surround - Video | 0 | 02-17-2012 06:28 AM |
Is it better to use a Trim plugin or Gain plugin? | SpinningDisk | Tips & Tricks | 5 | 01-19-2010 02:43 PM |
