Cut Time Operation Erases Clipboard
When I am working on audiobook editing I have a clip of room tone copied to the clipboard so that I can paste it in wherever needed. However, when I use the cut time operation it removes my room tone clip from the clipboard and I have to copy it again. Wondering if anyone else experiences this and if there is a solution?
This issue does not occur when using the Insert Time operation. Thanks!
iMac 27-inch, 2017 3.4 GHz Intel Core i5 24 GB 2400 MHz DDR4 OS X 12.5.1 PT 2022.7 MOTU 828es OWC Thunderbolt 2 Dock |
Re: Cut Time Operation Erases Clipboard
I’ll set up a secondary track for room tones, then if the clipboard gets cleared (yes, it happens) you can ALT-click (or Option-click) and drag it from a previous “paste.” (same as copy-paste.)
This happens for me, and it is expected.
It has happened for me for years as far as I know. Workflows as I know them: "Copy" --> "Paste" (no timeline changes, clips and automation copied are duplicated at cursor) "Cut" --> "Paste" (no timeline changes, clips and automation cut are moved to cursor) "Copy" --> "Insert Time" --> "Paste" (one timeline change, clips copied are duplicated) "Cut Time" --> "Insert Time" --> "Paste" (two timeline change, effectively time and clips are "moved") As far as I know, we don't have "copy time" or "paste time". I have not had need to make more complex my clipboard history access, but I have seen others on here mention clipboard apps, that let you go back in time to prior clipboard entries. Such an app might work really well in this situation where you intermittently want to Cut Time then go back to your prior room tone clip.
___ >> me: nednednerB // ||main gig: editing audio voiceovers & testing software | 2nd gig: music software tutoring | hobby: electronic music // ||software: Sonoma 14.2 | PT Studio 2023.12 | Ableton Live 11 | iZotope RX, Ozone, Neutron | Arturia Pigments | Auto-Tune | Dubler2 // ||system: iMac (Retina 5K, 27", 2020) 10-Core-i9 | 128GB-DDR4 | 5700-XT-16GB | OWC Thunderbolt Hub and Thunderbolt 3 Dock // ||devices: RME Babyface Pro FS | Focusrite Clarett 2Pre | some AT mics | SM58 | Ableton Push 2 | Sennheiser HD 600 HP // Onkyo TX-8220 SR ||automation: SoundFlow | Stream Deck+ | Keyboard Maestro | SteerMouse | MacOS Shortcuts // Last edited by nednednerb; 08-22-2022 at 10:37 AM. Reason: clarity |
Would being in Shuffle, highlighting the amount of time you want to cut - you can enter it into any of the Counters and hit Enter - and then Deleting the highlighted area work for you? This shouldn't clear the Clipboard.
I've always found it useful that Pro Tools treats blank highlighted areas as if there was actually something there.
Yep, as Bruce suggested, Shuffle mode is a far better workflow, anyway. Cut Time is for music, when you need to cut tempo, meter, and key changes and all that. It's also great for making sure you cut an exact number of bars or beats. But for editing spoken word, just stay in Shuffle 99% of the time, and you'll be golden.
David J. Finnamore PT 2023.12 Ultimate | Clarett+ 8Pre | macOS 13.6.3 on a MacBook Pro M1 Max PT 2023.12 | Saffire Pro 40 | Win10 latest, HP Z440 64GB |
When I want to cut time and not shuffle, cut time is a better workflow haha. Of course shuffle has its use, but I want to "delete and slide all/ cut time" when I use cut time. Not just with music, but markers too for dialogue etc
___ >> me: nednednerB // ||main gig: editing audio voiceovers & testing software | 2nd gig: music software tutoring | hobby: electronic music // ||software: Sonoma 14.2 | PT Studio 2023.12 | Ableton Live 11 | iZotope RX, Ozone, Neutron | Arturia Pigments | Auto-Tune | Dubler2 // ||system: iMac (Retina 5K, 27", 2020) 10-Core-i9 | 128GB-DDR4 | 5700-XT-16GB | OWC Thunderbolt Hub and Thunderbolt 3 Dock // ||devices: RME Babyface Pro FS | Focusrite Clarett 2Pre | some AT mics | SM58 | Ableton Push 2 | Sennheiser HD 600 HP // Onkyo TX-8220 SR ||automation: SoundFlow | Stream Deck+ | Keyboard Maestro | SteerMouse | MacOS Shortcuts // |
Thanks sw rec and nednednerb for confirming this as a known issue and for the workaround ideas, much appreciated.
Thanks also for the idea of using shuffle mode, but my workflow relies on the use of markers, which as far as I know, will not stay locked in place with the audio unless using the cut time operation.
The marker lane needs to be selected for the markers to be shifted. (will work in Shuffle also)
Matt McKenzie-Smith mattrixx.net SourceConnect - mattrixx AVID Collab user - mattrixx MacStudio Ultra / LogicProX / IzotopeRX10+ / SourceConnect / MelodyneStudio5 / WAVES Mercury / NI KompleteUltimate / ProToolsUltimate / RME UFX, UFXII, Babyface / AVID S3 + DOCK / Barefoot MM27 gen2 / Barefoot FP01 |
Wow I didn't realize you could do that in shuffle mode, thanks mattrixx!
Seems like it could be a nice feature to be able to link the audio and ruler timelines in order to avoid having to shift + click the marker lane each time. But it's still faster than other workarounds I've been using so I'm grateful for that!
For sure, and users have been requesting that feature for years.
Moving region erases timeline | huiberssound | Pro Tools 10 | 1 | 05-09-2012 05:25 PM |
PT8 erases midi events after reopening! Bug? | andreªs | Pro Tools TDM Systems (Mac) | 0 | 08-10-2009 01:20 PM |
7.4 erases portions of the track when ctr+e sliding | GtrDude | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 12-02-2007 02:07 PM |
Copy start/end/length time to clipboard memory? | confucion | Pro Tools M-Powered (Win) | 1 | 06-09-2005 06:21 AM |
LE6.1.2 update erases 6.1.1 application! | dkrz | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 21 | 10-10-2003 07:28 PM |
