Opening projects on a new computer?
Hi people, long time member, first posting.
I just bought a new computer, PC, after my old one couldn't handle the size of my sessions. I thought I could just install and download everything and open my projects from the cloud easypeasy but nothing shows up in my dashboard. I moved the whole project cache folder over to the new computer to the appropriate spot and changed the setting in the "operations" tab but nothing. I see them all in Avid Link but I just can't open anything. When I try to import from the cache folder via "import session data" it just said something about it being the wrong version. Please help! I have a gig after a week |
Re: Opening projects on a new computer?
Zero system info = zero help. “New computer” means nothing if it isn’t qualified.
https://duc.avid.com/showthread.php?t=300050 |
Sorry,
Processor AMD Ryzen 9 5900HX with Radeon Graphics 3.30 GHz Installed RAM 32.0 GB (31.4 GB usable) Device ID D3031B17-762F-4209-A901-D5AC4BAD5737 Product ID 00342-20816-70880-AAOEM System type 64-bit operating system, x64-based processor Edition Windows 11 Home Version 21H2 Installed on 20/08/2022 OS build 22000.856 Better? |
Pro Tools to the best of my knowledge has never been “qualified” with AMD processors. That doesn’t mean it won’t work, but you won’t get much support.
I’ll post this link again, because we still don’t know about your specific Pro Tools version, hard drive configuration, interface……see “Sandra Report” in this link. https://duc.avid.com/showthread.php?t=300050 |
Description Disk drive
Manufacturer (Standard disk drives) Model WDC PC SN530 SDBPNPZ-1T00-1114 Bytes/Sector 512 Media Loaded Yes Media Type Fixed hard disk Partitions 3 SCSI Bus 0 SCSI Logical Unit 0 SCSI Port 2 SCSI Target ID 0 Sectors/Track 63 Size 953.86 GB (1,024,203,640,320 bytes) Total Cylinders 124,519 Total Sectors 2,000,397,735 Total Tracks 31,752,345 Tracks/Cylinder 255 Partition Disk #0, Partition #0 Partition Size 260.00 MB (272,629,760 bytes) Partition Starting Offset 1,048,576 bytes Partition Disk #0, Partition #1 Partition Size 952.60 GB (1,022,844,993,536 bytes) Partition Starting Offset 290,455,552 bytes Partition Disk #0, Partition #2 Partition Size 1.00 GB (1,073,741,824 bytes) Partition Starting Offset 1,023,135,449,088 bytes SiSoftware Sandra ID Host Name : MajorPink Workgroup : WORKGROUP Computer Model : Acer Nitro AN515-45 Nitro 5 Serial Number : NHQBSEL0072*********** Chassis : Acer Notebook Mainboard : CZ Scala_CAS Serial Number : NBQBS110032*********** BIOS : Insyde V1.08 07/21/2021 TPM - Trusted Platform Module : AMD 2.0 2018 (24PCR 64Ses 2Obj) System Memory Total Memory : 31.5GB DDR4 Processors Processor : AMD Ryzen 9 5900HX with Radeon Graphics (8C 16T 4.47GHz, 1.6GHz IMC, 8x 512kB L2, 16MB L3) Socket/Slot : FP4 (µBGA) Chipset Memory Controller : AMD F19v5M (Ryzen-M VanGogh) Root Complex 16x 100MHz (1.6GHz), 2x 16GB DDR4 3.2GHz 128-bit Memory Module(s) Memory Module : Hynix M471A2K43EB1-CWE 16GB DDR4 PC4-25600U DDR4-3200 Memory Module : Hynix M471A2K43EB1-CWE 16GB DDR4 PC4-25600U DDR4-3200 Video System Monitor/Panel : BOE Generic PnP Monitor (1920x1080, NV156FHM-N4K , 15.5") Video Adapter : AMD Radeon(TM) Graphics (512S 8C SM6.6 2.1GHz, 7.9GB DDR4 128-bit, Integrated Graphics) Graphics Processor CUDA : NVIDIA GeForce RTX 3080 Laptop GPU (6144S 48C SM8.6 1.25GHz, 4MB L2, 8GB 12GHz/12GHz 256-bit) OpenCL : NVIDIA GeForce RTX 3080 Laptop GPU (6144S 48C SM3.0 1.25GHz, 4MB L2, 8GB 12GHz/12GHz 256-bit) OpenCL : AMD Radeon(TM) Graphics (512S 8C SM2.0 2.1GHz, 12.1GB DDR4 128-bit, Integrated Graphics) D3D 11 : NVIDIA GeForce RTX 3080 Laptop GPU (6144S 24C SM12.1 1.25GHz, 4MB L2, 7.9GB 12GHz/12GHz 256-bit) OpenGL : NVIDIA GeForce RTX 3080 Laptop GPU/PCIe/SSE2 (6144S 24C SM4.60 1.25GHz, 4MB L2, 8GB 12GHz/12GHz 256-bit) Storage Devices Disk : WDC PC SN530 SDBPNPZ-1T00-1114 (1TB, PCIe3x4/NVMe) Logical Storage Devices Acer (C:) : 953GB (NTFS, 4kB) @ WDC PC SN530 SDBPNPZ-1T00-1114 (1TB, PCIe3x4/NVMe) Recovery : 1024MB (NTFS, 4kB) @ WDC PC SN530 SDBPNPZ-1T00-1114 (1TB, PCIe3x4/NVMe) ESP : 256MB (FAT32, 4kB) @ WDC PC SN530 SDBPNPZ-1T00-1114 (1TB, PCIe3x4/NVMe) Storage System Storage Pool : Primordial (953.87GB) Peripherals LPC Hub Controller : Acer FCH LPC Bridge Audio Device : Acer GA104 High Definition Audio Controller Audio Device : Acer F17v1 (Ryzen-M) DRAM Controller Disk Controller : Sandisk WD Blue SN550 NVMe SSD Disk Controller : Acer FCH SATA Controller [AHCI mode] Disk Controller : Acer FCH SATA Controller [AHCI mode] USB Controller : Acer Ryzen F17v4M (Renoir) USB 3.1 USB Controller : Acer Ryzen F17v4M (Renoir) USB 3.1 SMBus/i2c Controller : AMD SB900 SMBus Printers and Faxes Printer : Send to Microsoft OneNote 16 Driver (1200x1200, Colour) Printer : Microsoft XPS Document Writer v4 (600x600, Colour) Printer : Microsoft Print To PDF (600x600, Colour) Fax : Microsoft Shared Fax Driver (200x200) Biometrics Voice : Analog NUI Voice Virtual Sensor (Voice) Network Services Network Adapter : Killer E2600 Gigabit Ethernet Controller (Ethernet) Network Adapter : Bluetooth Device (Personal Area Network) (Ethernet) Wireless Adapter : MediaTek Wi-Fi 6 MT7921 Wireless LAN Card (Wifi4 (802.11n/HT), AES-CCMP, 144.4Mbps) Power Management Battery : SMP AP18E7M 59.23Wh/3.41Ah Operating System Windows System : Microsoft Windows 11 Personal 10.0.22000 Platform Compliance : x64 Pro Tools 2022.7 System ID: 51131385 Presonus AudioBox USB96 sorry about that, is this enough? |
But at the simplest level your problem is caused by you deciding to use buggy unreliable crappy Cloud projects instead of reliable local sessions. DUC is full of posts about problems with cloud projects. But not being able to open a Cloud project is unlikely to have much to do with the type of computer/specs you have. So this has been a waste of time so far. DUC is full or people mostly newbie users having all sorts of problems with Cloud Collaboration, including I expect many users losing their work. And many hundreds of posts were deleted when Avid deleted the Pro Tools First forums. You should be using sessions, you should always have been using sessions, not cloud projects. If you've been a long term reader of DUC you should have seen many of those posts. You have any of the previous work backed up? Like to a session? Then copy that session over and get going. Why would you manually move cache folders vs. just reload the session via the cloud? This stuff is fragile as crap already. Are you running Pro Tools First? If so get off that dead killed off for a reason buggy crap. You need to contact Avid support they may be able to help you out recovering your cloud projects. Purchase an ASC if you don't have a current subscription/update program. https://www.avid.com/learn-and-suppo...-music-support. Avid support is also paid to put up with folks who can't bother noting error messages etc. And if there is not much content there then be willing to toss it away and start over using Pro Tools (standard) or Pro Tools Artist or Pro Tools Studio with local session files. And if that sounds harsh, I am trying to get you from stopping self harm. Stop using cloud crap and get onto sessions like everybody else uses. Last edited by Darryl Ramm; 08-21-2022 at 01:27 PM. |
Pro tools crashing when opening projects. | chiv33s | Windows | 4 | 04-27-2013 05:14 AM |
issues opening projects on newly installed computer | deathmetalguy | Windows | 1 | 12-11-2011 04:56 PM |
Problem opening some Projects | madrocks | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 05-29-2010 07:58 AM |
PT 7 crashing when opening PT 6 projects??? | JenTraz | Pro Tools TDM Systems (Mac) | 3 | 01-22-2007 08:48 AM |
Opening v7.1 projects in LE v6.4? | floatingpoint_32bit | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 10-03-2006 11:47 AM |
