Old 06-17-1999, 09:51 PM
dylennon dylennon is offline
Default Sound cDev not showing AMIII board?
The SOUND control panel (ver. 8.0.5) on my B&W G3 doesn't offer a choice for I/O via my Audiomedia III board. SDII and MLCD both see and use the board. Just curious as to why it's not there in the cDev.
Any reason?
Anyone seen this?
Thanks, as always!
Old 06-23-1999, 12:05 AM
gqkelly gqkelly is offline
Default Re: Sound cDev not showing AMIII board?
Have you had any problems using the "Coaxial" output going to a DAT player? I read your response, and I dearly thank you for it. I only still have one problem, and that is that I cannot get my Sony DA 20 DAT machine to record a digital signal from the coaxial "out" from the card, and I know this has to be something that I don't have configured right with the software, becasue everything was fine until I upgraded to OS 8.5. Do you know if this has anythin gto do with Calibration, or if there is another init that I don't have on?
[This message has been edited by gqkelly (edited 06-22-99).]
Old 06-29-1999, 08:53 AM
ProdInfo ProdInfo is offline
dylennon,
If you are talking about OS 8.5, it was known to be buggy and we never got it through testing before a more stable 8.5.1 was released. I'd suggest loading the 8.5.1 upgrade to see if this fixes the problem.
Also, we have not tested OS 8.6 yet though some users are running it successfully.
T.J. Thomas
Digidesign
Old 07-03-1999, 12:34 AM
Avid's Avatar
Avid Avid is offline
Administrator
OS 8.6 was just qualified right after TJ wrote the above.
Make sure you have the Dig Sound Drivers installed in your Extensions Folder. If not, you can find it in the Software section of Support, linked below.
Bruce Paine
emarketing
Administrator
Cdev Digi and unable to save? stv Pro Tools TDM Systems (Mac) 2 09-06-2008 05:44 AM
Sound quality changes on AMIII Matej Sychra Pro Tools TDM Systems (Mac) 0 01-23-2005 10:17 PM
Digidesign CDEV thornrag Digidesign Hardware & Software 0 06-25-2003 02:42 PM
AMIII showing in "System Usage" window SimonThornton Pro Tools TDM Systems (Mac) 2 11-19-2001 11:18 AM
AMIII showing in "System Usage" window SimonThornton Pro Tools TDM Systems (Mac) 0 11-13-2001 03:43 PM
