Old 02-28-2022, 12:22 PM
guitrman guitrman is offline
Default Playback stopped working correctly after windows update
I am a new member of the community so please be gentle. I've had this system up and running for 2 years without any issues. I'm pretty sure a windows update is causing the issue. When I hit the spacebar to start playback it stutters, and eventually plays correctly. I rolled back the update but am still having the same issue. I tried re-installing PT but that didnt help. At a total loss at this point, any help would be greatly appreciated.
I'm running PT 10.3.4 on a windows 10 pro system, with an Intel(R) Core(TM) i7-9700K CPU @ 3.60GHz, 32 GB Ram. My interface is the Scarlett 2i2, Not sure what other info is needed to help figure this out.
Old 02-28-2022, 02:02 PM
EGS's Avatar
EGS EGS is offline
Default Re: Playback stopped working correctly after windows update
PT10 works on Win7, not Win10. Pro-Tools was not tested/supported on Win10 until Pro Tools version 12.5. If you've been running 10 on 10, then you've been lucky until now. Get 12.5 or newer. Also, do ALL steps of the Optimizations and ALL steps of Troubleshooting here (don't skip a single one): https://avid.secure.force.com/pkb/ar...ndows-10-Guide
Desktop: PT 2020.5 / Win11 / Intel 11th Gen i9 5.1GHz / 64Gb DDR4-3600 / Gigabyte Z590 Vision D / Focusrite LS56
Laptop: PT 2020.5 / Win10 / older HP ProBook with i7 quad / U-PHORIA UMC1820
Legacy (works!): PT 5 & 6 / OS9 & OSX / Mac G4 / DIGI001
Click for audio/video demo
Old 02-28-2022, 02:52 PM
junkgear's Avatar
junkgear junkgear is offline
Also make sure you have the latest Focusrite drivers for your interface installed. Then like EGS said, go through all of the steps in the Help Us Help You thread.
Will
System Details
Old 02-28-2022, 04:04 PM
Thank you so much for the fast reply! So strange that it would work for all this time without a glitch. I’m going to try all the things that you guys recommended I’ll let you know what happens, thank you very much again for your help
Old 02-28-2022, 04:11 PM
sw rec sw rec is offline
One thing those Windoze updates tends to do is reset your power preferences. Try going into device manager, and disabling power management on ALL of your usb ports.
Old 03-01-2022, 08:19 AM
That^^^ and double-check that Windows is NOT using the interface as its default playback device
Old 03-02-2022, 10:33 AM
Tried it all, nothing worked. Thinking about restore computer from factory settings and then reinstalling everything. Your thoughts? Anything else you can suggest before I start over?? Thank you.
Old 03-02-2022, 12:15 PM
junkgear's Avatar
Have you taken a look at your CPU usage when you start playing audio and the playback struggles? I would first look at system usage in PT, but I would also open the Windows Task Manager and monitor the CPU to see if there are any spikes when you hit play. If there are, then you need to narrow it down to what is causing these spikes.
There are tools like Windows Performance Recorder/Analyzer, which can give you a better snapshot of system health when the glitching is occurring, but it's easy to decipher all the data they spit out.
Will
System Details
Old 03-04-2022, 09:17 AM
TOM@METRO's Avatar
Does this happen on a project created from scratch on the current system?
~ tom thomas
Formerly hobotom
Pro Tools Ultimate 2022 HDX
HD Omni and 192 I/Os
Windows 10
Intel Hexcore i7
All Samsung Pro SSDs
Ampex MM1200 2" 24 trk tape
www.metrostudios.com
Old 03-04-2022, 12:46 PM
Yes it happens with any sessions, new or old.
Fader on S1 stopped working after update Rammelt Avid S1, S3, Dock and Control App 2 11-07-2021 09:20 PM
PRO TOOLS 8LE was working on windows 8, stopped working after 8.1 update... Jon Vandenbor 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 01-01-2015 02:10 PM
Playback function not working correctly essdog7 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 09-17-2004 01:15 PM
Playback of selection not working correctly vocomotion Pro Tools TDM Systems (Mac) 3 02-16-2004 07:53 AM
